Gazzas Posted September 23, 2022 Author Share Posted September 23, 2022 Welcome back my friends. With the few hours not stolen from me by life's duties, I managed to get some things done. First of all...I sanded the dorsal and ventral seams. So that I won't have to scribe them later. I hate scribing... especially on a curved surface. Once that was done, I filled an excess filler port with black CA and discovered the first flaw.... Unfortunately, there is one on the port side as well. I'll get to them once the fuselage halves are solidly joined. Last night I put in the bare bones of the fuselage framing. Somebody mentioned being forced to add the tail gear before closing up the fuselage. It's just not so. All you have to do is swing it in at the correct angle so that the top and bottom locator lugs fit snugly. 6 Then you just add the fillet H-6 per the directions, as I have done below. (dry-fitted) You can even add the fuselage tub after sealing the back half together.... Though, I didn't use the fuel cell which may complicate things for the more detail-oriented person... though I doubt it. Happy modelling! rafju, CShanne, Paul in Napier and 26 others 29 Link to comment Share on other sites More sharing options...
duke_ Posted September 23, 2022 Share Posted September 23, 2022 very nice Gazzas! great progress .. ZM G-14 looks like a very detailed and high quality model!! Gazzas and Martinnfb 2 Link to comment Share on other sites More sharing options...
John1 Posted September 23, 2022 Share Posted September 23, 2022 13 hours ago, Gazzas said: That is the problem with researching the past. One person sees an occurrence and assumes it occurred all of the time. Whereas another person saw another occurrence and refuses to believe any other occurrence is possible. I'd be interested in seeing pictures of seatbelts with those large numbers printed. I'm just saying that I've never seen anything like that posted before. If you know of any pictures that back up HGW's interpretation of those markings, please feel free to post. Gazzas and Martinnfb 2 Link to comment Share on other sites More sharing options...
monthebiff Posted September 23, 2022 Share Posted September 23, 2022 Excellent progress Gaz, just checked mine and suffers from the same sink marks, bit of a shame! Regards. Andy Gazzas and Martinnfb 1 1 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted September 23, 2022 Share Posted September 23, 2022 2 hours ago, John1 said: I'd be interested in seeing pictures of seatbelts with those large numbers printed. I'm just saying that I've never seen anything like that posted before. If you know of any pictures that back up HGW's interpretation of those markings, please feel free to post. LSP_Matt, TAG, Pastor John and 14 others 10 7 Link to comment Share on other sites More sharing options...
Gazzas Posted September 23, 2022 Author Share Posted September 23, 2022 9 hours ago, duke_ said: very nice Gazzas! great progress .. ZM G-14 looks like a very detailed and high quality model!! Thank you! I'm really looking forward to dressing it up with positive rivets. duke_ and Martinnfb 2 Link to comment Share on other sites More sharing options...
Gazzas Posted September 23, 2022 Author Share Posted September 23, 2022 6 hours ago, Antonio Argudo said: Thank you, Tony! You are a treasure in the 109 Community. Antonio Argudo, Rocat, Martinnfb and 4 others 5 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 23, 2022 Share Posted September 23, 2022 Terrific progress, Gaz! Kev Gazzas and Martinnfb 1 1 Link to comment Share on other sites More sharing options...
Gazzas Posted September 24, 2022 Author Share Posted September 24, 2022 1 hour ago, LSP_Kevin said: Terrific progress, Gaz! Kev Thank you, Kev! LSP_Kevin and Martinnfb 2 Link to comment Share on other sites More sharing options...
Gazzas Posted September 24, 2022 Author Share Posted September 24, 2022 Didja buy it yet? I had mentally heralded the single-piece stabilizer as some great engineering. After years of wiggling and adjusting, finally a flat tailplane. But once I got to dry-fitting the entire empennage, the future wasn't looking so bright. My first thought was that this model had just become a G6 instead of a G14. So, I assembled the short horizontal stabilizer and discovered it wasn't very much different than the taller tail. My next thought was that I could saw the vertical stabilizer in half and reassemble it making it narrower. However, the fault is of different width at the bottom side of the vertical stabilizer assembly. So... There will be some modelling required. I will put some shims on the inside of the stabilizer to fill gaps. Then, I will file and sand the offending areas to shape. Heh... all of that stuff we have been hoping to avoid. In other news.... One of the great things about the directions is a blue highlighted area to point out gluing surfaces. So, I glued the cockpit in as directed. And then decided to check the directions regarding an interior frame I had purposely omitted. Seems you need it to hold on the ventral plate under the cockpit. So, I added it. i It also helps determine the height of the after end of the cockpit deck. Much to my chagrin. I discovered that the first aid access hatch was too easy to sink too deep into the side of the fuselage. So, I had to pry it out carefully and shim it up. So... I implore you. Don't follow the directions. Attach the first aid access hatch before you close the fuselage up. I also put Mr. surfacer over the sink marks I pointed out earlier. Now to let it dry. Meanwhile... I'll start back on the wings and ruminate further on the empennage mess. Happy modelling! Sepp, LSP_Matt, Fanes and 17 others 18 1 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted September 24, 2022 Share Posted September 24, 2022 Looks like you're having fun Gary. Gazzas and Martinnfb 2 Link to comment Share on other sites More sharing options...
Gazzas Posted September 24, 2022 Author Share Posted September 24, 2022 1 hour ago, MikeMaben said: Looks like you're having fun Gary. Well... I was... I mean... I like challenge and all. But reshaping basic structure was a bit more than I expected. Adding two plugs to widen the horizontal stabilizer fixed some of the problem. But I will still have to reshape the leading areas of the fairing between tail plane and fuselage. John1, MikeMaben, daHeld and 2 others 4 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 24, 2022 Share Posted September 24, 2022 8 hours ago, Gazzas said: Didja buy it yet? I had mentally heralded the single-piece stabilizer as some great engineering. After years of wiggling and adjusting, finally a flat tailplane. But once I got to dry-fitting the entire empennage, the future wasn't looking so bright. My first thought was that this model had just become a G6 instead of a G14. So, I assembled the short horizontal stabilizer and discovered it wasn't very much different than the taller tail. Rick Griewski, Martinnfb and Gazzas 3 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted September 24, 2022 Share Posted September 24, 2022 oh no, that tail gap! I hope they fix it on next versions, great work Gazzas HB252 and Gazzas 2 Link to comment Share on other sites More sharing options...
dutik Posted September 24, 2022 Share Posted September 24, 2022 Well, that stabilizer issue should never had happened given the pricetag of this kit. And the reputation of the manufacturer. You are loosing your face, Zoukai Moura. Regards - dutik fab, Gazzas and Antonio Argudo 3 Link to comment Share on other sites More sharing options...
