Lancman Posted August 5, 2022 Share Posted August 5, 2022 Hey folks I bought a Tamiya Spitfire MkXI kit and was wondering if there's a conversion kit so a pink spity could be built. Graham Link to comment Share on other sites More sharing options...
Juggernut Posted August 5, 2022 Share Posted August 5, 2022 If you're referring to the Tamiya Mk IXc kit, then I believe Pastor John (AIMS) has a conversion for the Mk. XI PR spitfire available (32P027). I think it's available from Hannants. Alleycat Models USED to have a Mk XI conversion but I dont' believe it's available any longer. Link to comment Share on other sites More sharing options...
ade rowlands Posted August 5, 2022 Share Posted August 5, 2022 I’m probably wrong but weren’t the PRU Pink ones Mk.IX anyway? FR.IX? They were armed. Just need some of Pastor John’s Monotone Spitfire Decals and the camera port fashioning in the Radio hatch door area. He also has a set of cameras should you wish to put one in the bay. It’s what I will be doing when the time comes anyway. But I’m lazy. Link to comment Share on other sites More sharing options...
whitt_a Posted August 5, 2022 Share Posted August 5, 2022 Hello Lancman, If you want a pink Spitfire from the Tamiya Mk. 9 kit, you don’t need a P.R. 11 conversion, because the version you are modelling is the F.R. IX. You just need the camera set, which is available separately. Hope this helps, Tony W. MikeMaben 1 Link to comment Share on other sites More sharing options...
Lancman Posted August 5, 2022 Author Share Posted August 5, 2022 Thanks for the reply guys, so just the decal sheet and the camera set. I am guessing it will be one of the F24 cameras needed? Graham Link to comment Share on other sites More sharing options...
jbrennan Posted August 5, 2022 Share Posted August 5, 2022 2 hours ago, whitt_a said: Hello Lancman, If you want a pink Spitfire from the Tamiya Mk. 9 kit, you don’t need a P.R. 11 conversion, because the version you are modelling is the F.R. IX. You just need the camera set, which is available separately. Hope this helps, Tony W. Please correct me if I,m wrong Tony but is it the 'Aims' conversion that has the F24 camera for the PR.IX. If so Lanceman be preppared to have a lot of other spare PR parts, as they do not sell the camera seperatly. Link to comment Share on other sites More sharing options...
Tony T Posted August 5, 2022 Share Posted August 5, 2022 (edited) 2 hours ago, ade rowlands said: I’m probably wrong but weren’t the PRU Pink ones Mk.IX anyway? FR.IX? They were armed. Just need some of Pastor John’s Monotone Spitfire Decals and the camera port fashioning in the Radio hatch door area. He also has a set of cameras should you wish to put one in the bay. It’s what I will be doing when the time comes anyway. But I’m lazy. That's what I'm intending to do with the new 1/24 Airfix IXc (and, failing that, the Revell 1/32 IXc). Just the one camera, so not an epic except the slightly convex left fuse camera port which should be ~9.3mm in diameter in 1/24 and 7mm in 1/32 — Aerocraft make a set of camera windows in 1/32. It puzzles me why Airfix haven't made the hatch a separate part on its new big Spitty, which would have facilitated an AM drop-in hatch. Oh well. If anyone wants just the one camera from the AIMs set I'll buy the remaining cameras and decals etc from them (for use on a PR Mossie). Tony Edited August 5, 2022 by Tony T adding stuff Link to comment Share on other sites More sharing options...
BloorwestSiR Posted August 5, 2022 Share Posted August 5, 2022 It's a straightforward conversion with the Tamiya IX kit. I did one a couple years ago. The camera port is quite dark so you can't even see if there's a camera in it which there isn't in my case. Carl Reuben L. Hernandez, John1, Dpgsbody55 and 7 others 10 Link to comment Share on other sites More sharing options...
jbrennan Posted August 5, 2022 Share Posted August 5, 2022 Very nice work if I may say Sir ! lovely clean finish. Link to comment Share on other sites More sharing options...
MikeC Posted August 5, 2022 Share Posted August 5, 2022 19 minutes ago, BloorwestSiR said: It's a straightforward conversion with the Tamiya IX kit. I did one a couple years ago. The camera port is quite dark so you can't even see if there's a camera in it which there isn't in my case. Carl Which is quite correct as the cameras were only fitted prior to a sortie and removed immediately on landing. Nice model. BloorwestSiR, Paramedic and Dpgsbody55 2 1 Link to comment Share on other sites More sharing options...
jbrennan Posted August 5, 2022 Share Posted August 5, 2022 55 minutes ago, Tony T said: That's what I'm intending to do with the new 1/24 Airfix IXc (and, failing that, the Revell 1/32 IXc). Just the one camera, so not an epic except the slightly convex left fuse camera port which should be ~9.3mm in diameter in 1/24 and 7mm in 1/32 — Aerocraft make a set of camera windows in 1/32. It puzzles me why Airfix haven't made the hatch a separate part on its new big Spitty, which would have facilitated an AM drop-in hatch. Oh well. If anyone wants just the one camera from the AIMs set I'll buy the remaining cameras and decals etc from them (for use on a PR Mossie). Tony The answer to the new Spitfire hatch - Cost ! Jon Link to comment Share on other sites More sharing options...
thierry laurent Posted August 5, 2022 Share Posted August 5, 2022 Hi, There IS a separate camera set: AIMS 1/32 32P25 RAF cameras https://www.largescaleplanes.com/reviews/review.php?rid=2440 Hth Thierry Link to comment Share on other sites More sharing options...
Lancman Posted August 5, 2022 Author Share Posted August 5, 2022 Nice spitty Carl, I'll just get the decal sheet. Graham BloorwestSiR 1 Link to comment Share on other sites More sharing options...
dennismcc Posted August 5, 2022 Share Posted August 5, 2022 Great looking Spitfire, always fancied a "Pink" Spitfire, but too little time too many models. Cheers Dennis BloorwestSiR 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 6, 2022 Share Posted August 6, 2022 Actually cameras were only in the plane right before the take-off and right after the landing. Otherwise, they never stayed in the plane. So, they are not mandatory. MikeC and Tolga ULGUR 1 1 Link to comment Share on other sites More sharing options...
