kkarlsen Posted June 21, 2022 Share Posted June 21, 2022 (edited) I'm having some issues with the Long Range Fuel Tanks of the Spitfire... I'm not sure witch Spitfire Mk the drawing here refers to? I'm guessing around Mk.XVIe'ish since these parts are from the Tamiya Mk.XVIe kit. So what did the Spitfire IX Long Range Fuel Tanks look like? Another drawing of a different Long Range Fuel Tank possibly a Mk. IX? The only photo I could find of a Mk IX with Long Range Fuel Tanks... I hope that someone can shed a little light on this subject? Maybe a photo of the Mk IX tanks uninstalled? P.S. (where is the oxygen tank) Cheers: Kent Edited July 18, 2022 by kkarlsen Link to comment Share on other sites More sharing options...
kkarlsen Posted June 30, 2022 Author Share Posted June 30, 2022 I have had contact with Spitfire.com at Goodwood Aerodrome close to Chichester. They provided me with this photo of the Long range fuel tank of their 'Silver Spitfire' renovation project. It's a modernized version of the first drawing of the tanks, close the one from the Tamiya kit. Cheers: Kent Link to comment Share on other sites More sharing options...
Kagemusha Posted June 30, 2022 Share Posted June 30, 2022 The initial drawing is of a Seafire, don't think Spitfire's were ever fitted with that type of drop tank. Martinnfb 1 Link to comment Share on other sites More sharing options...
waroff Posted June 30, 2022 Share Posted June 30, 2022 What I found about Mk IX kkarlsen 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted June 30, 2022 Share Posted June 30, 2022 3 hours ago, Kagemusha said: The initial drawing is of a Seafire, don't think Spitfire's were ever fitted with that type of drop tank. I think your right Andy, I've only ever seen pics of the slipper tank on Spitfires. MikeC 1 Link to comment Share on other sites More sharing options...
Pete Roberts Posted June 30, 2022 Share Posted June 30, 2022 (edited) The diagram you have posted Kent is of a Seafire long range tank. Slipper tanks were used on Mk IXs and another type of long range tank used was as per this example (this an Eduard Brassin set): Edited June 30, 2022 by Pete Roberts Link to comment Share on other sites More sharing options...
Kagemusha Posted June 30, 2022 Share Posted June 30, 2022 Yep it's definitely a Seafire XV, which came in both high back and bubble top, in fact you can see it referred to in the drawing top right - 41 Gall standard fuselage, 33 Gall rear view fuselage - you can also see the outlines of both canopy types, no doubt the reason for the fuel tanks being long range. Link to comment Share on other sites More sharing options...
kkarlsen Posted July 18, 2022 Author Share Posted July 18, 2022 On 6/30/2022 at 7:36 PM, waroff said: What I found about Mk IX Thank you! Cheers: Kent Link to comment Share on other sites More sharing options...
kkarlsen Posted July 18, 2022 Author Share Posted July 18, 2022 10 hours ago, MARU5137 said: (by the way Kent , your PM box says you can't receive messages... I tried sending a pm). Thank you. Thanks Marus137 for letting me know, the mailbox was 99% full Cheers: Kent Link to comment Share on other sites More sharing options...
MikeC Posted July 18, 2022 Share Posted July 18, 2022 The drawing (from AP 1565, which is basically the "bible" for the Merlin-engined Spits) seems to be a hybrid covering a number of marks. Note how the annotation in the top right refers to two different sizes of LR tank, one for use with the standard fuselage, one with the rear-view fuselage. That drop tank is one I've only seen on Griffon Seafires. CANicoll 1 Link to comment Share on other sites More sharing options...
