duke_ Posted June 24, 2022 Share Posted June 24, 2022 Amazing little details John! well done! S. Thunnus 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 24, 2022 Share Posted June 24, 2022 Lovely work, John! Kev Thunnus 1 Link to comment Share on other sites More sharing options...
Dpgsbody55 Posted June 25, 2022 Share Posted June 25, 2022 That cockpit will look great when you start putting it together. And maybe we'll see more of your work this time, unlike the 190D. Cheers, Michael Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted June 25, 2022 Author Share Posted June 25, 2022 Thanks guys! The big black box on the starboard side panel gave me a bit of pause. It has very shallow raised details which are hard to pick out with detail painting. I looked at the kit-supplied decal and it simply outlined the raised detail in white, which I didn't think would be very convincing and also would not match the rest of the cockpit. So I decided to use some dry-brushing. I like to use dry-brushing to show wear but I'm not really a fan of using it as a primary method of highlighting detail. I'd rather pick out details carefully by brush painting and then highlight them later with a wash. But there are situations like this where dry-brushing can come in handy. First using Testor Silver on a very dry brush, I try to pick up as much edge detail as I can. This will put the silver in places where you don't want but that is ok. After the silver, I go back with black and using both dry-brush and wet-brush techniques, I carefully remove the silver from the non-edge areas. It is an iterative technique, going from silver to black to silver again, reducing the errant silver marks and getting a cleaner presentation. White and red details are added to the buttons. After the black box is finished, the starboard panel is given a gloss coat and a dark brown pastel wash. A flat coat seals the completely painted panel. The painting of the port side wall is finished too. The two side walls will be weathered before I start assembling the cockpit components. The front bulkhead also serves as the gun deck and I've chipped the deck using hairspray. The floor is the furthest along and weathering has been completed by applying a brown pastel wash on the flat coat. scvrobeson, MikeMaben, Landrotten Highlander and 15 others 18 Link to comment Share on other sites More sharing options...
Thunnus Posted June 25, 2022 Author Share Posted June 25, 2022 I have started gluing together the cockpit components. Here is the front bulkhead with the gun bodies, instrument panel and foot pedals attached. The seat can attach directly and securely to the rear bulkhead so I sawed off the raised block on the bottom of seat so that it wouldn't interfere with the seat position. Model_Monkey, denders, mc65 and 18 others 21 Link to comment Share on other sites More sharing options...
Brett M Posted June 25, 2022 Share Posted June 25, 2022 Really nice work, as always, on your cockpit. Late night model building too Troy Molitor and Thunnus 2 Link to comment Share on other sites More sharing options...
dennismcc Posted June 25, 2022 Share Posted June 25, 2022 Really nice work going on here, lots of things I can use when I build mine. Cheers Dennis Thunnus and Troy Molitor 2 Link to comment Share on other sites More sharing options...
Troy Molitor Posted June 25, 2022 Share Posted June 25, 2022 Great looking pit John. Going fishing next week. Enjoy your fishing trip coming up. Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted June 25, 2022 Author Share Posted June 25, 2022 Thanks guys! Let's cobble together the cockpit components and see what the assembled cockpit looks like. Things get a bit claustrophobic once all four walls are put into place. Checking to see how the resin cockpit fits into the fuselage sides. Let's keep in mind that I have not introduced the resin nose yet so that might affect things later. Gunsight clearance seems ok with the canopy in place. Cockpit is not quite finished. Looking at these photos has raised some small flags that I want to explore before I call it done. Victor K2, Citadelgrad, KiwiZac and 17 others 20 Link to comment Share on other sites More sharing options...
CZPetrP Posted June 25, 2022 Share Posted June 25, 2022 Beautiful work. Thunnus 1 Link to comment Share on other sites More sharing options...
VintageEagle Posted June 25, 2022 Share Posted June 25, 2022 Outstanding work. You have a talent to turn every cockpit into a piece of art. I can't remember, but maybe you have already shared a mini-tutorial in one of your other WIPs about how you achieve this convincing looking chipping effect. Is it commercial hair-spray and a toothpick? I guess in the end it is down to practicing to figure out how to create the most realistic looking effect. I recently wanted to test this method for my Me 262 cockpit. I used AK interactive chipping fluid, but it did not stick to the surface at all and behaved like water. I had to remove it and am not sure if I should have a go with commercial hair spray instead or another brand. Roger Thunnus 1 Link to comment Share on other sites More sharing options...
Sturmbock Posted June 25, 2022 Share Posted June 25, 2022 I like your clear and precise way of building and painting John! Everything really fits. Great work and great photos! I'm wondering if the Aires cockpit for the Ki-61 might also fit the Alley Cat Modells Ki-100 conversion kit!? Lutz Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted June 25, 2022 Author Share Posted June 25, 2022 2 hours ago, CZPetrP said: Beautiful work. Thank you sir! 2 hours ago, VintageEagle said: Outstanding work. You have a talent to turn every cockpit into a piece of art. I can't remember, but maybe you have already shared a mini-tutorial in one of your other WIPs about how you achieve this convincing looking chipping effect. Is it commercial hair-spray and a toothpick? I guess in the end it is down to practicing to figure out how to create the most realistic looking effect. I recently wanted to test this method for my Me 262 cockpit. I used AK interactive chipping fluid, but it did not stick to the surface at all and behaved like water. I had to remove it and am not sure if I should have a go with commercial hair spray instead or another brand. Roger Thanks Roger! I use actual hairspray for my chipping. I've used AK chipping solution before but didn't see any noticeable difference so I've reverted back to the hairspray. I find it to be a very frustrating and inconsistent effect to achieve. The stuff tends to pool as it dries so it concentrates in certain areas making chipping easy and leaves other areas making chipping very hard. To activate the chipping, I use a paint brush with stiff bristles dipped in water and rub the brush repeatedly until the chips start to appear. I get the best results when I can go quickly from hairspray application to the chipping (within hours). 28 minutes ago, Sturmbock said: I like your clear and precise way of building and painting John! Everything really fits. Great work and great photos! I'm wondering if the Aires cockpit for the Ki-61 might also fit the Alley Cat Modells Ki-100 conversion kit!? Lutz Thank you Lutz! Not sure about the compatibility of the Aires K-61 cockpit with Alley Cat. If the Alley Cat conversion utilizes the kit cockpit tub seamlessly, I think there is a good chance that the Aires would fit. Like I said, I didn't like a few things that were apparent upon looking at the latest pics of the cockpit. For one, with the canopy in place, it looked like the back of the instrument panel would be visible so I thought some attempt at putting some wiring there would be appropriate. I also didn't like the color of the central box located right below the main instrument panel. The four main components of the cockpit have not been glued together yet so here they are in their separated state. I couldn't get the instrument panel off of the front bulkhead so I worked around it. First, I drilled a big hole through the gun deck. I then drilled holes in the instrument casings behind the instrument panel and routed some copper wiring from the back of the instruments to the hole in the deck. Here is a look at the revised panel. The center box has been painted to match the instrument panel. I re-did the reflector glass on the gun sight. The corners of the reflector glass are now rounded instead of sharp. And for good measure, I added some wiring from the gun bodies. Small details that will probably go unnoticed individually but I am a strong believer in the sum of the added details making for a better model. TAG, coogrfan, Landrotten Highlander and 14 others 17 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 25, 2022 Share Posted June 25, 2022 Superb work, John! Meticulous indeed. Kev Link to comment Share on other sites More sharing options...
KiwiZac Posted June 25, 2022 Share Posted June 25, 2022 John, you're not helping me resist my desire for the Tamiya 1/48 kit! This is beautiful work, thank you for sharing it in so much detail. She's gorgeous! Thunnus 1 Link to comment Share on other sites More sharing options...
