Hoss FL Posted June 11 Share Posted June 11 My rendition of Major Edward Giller's "The Millie G" is now complete. This was by far my most involved project with extra detailing for the engine, cockpit, landing gear bays and the MG bays. Here's a link to the build thread in the Works in Progress section: https://forum.largescaleplanes.com/index.php?/topic/92956-132-tamiya-p-51d-15-na-mustang-the-millie-g/ Thanks for all the comments and suggestions during the build. In summary, here were the aftermarket additions to the kit: Barracuda cockpit upgrade Barracuda instrument panel Barracuda cockpit sidewalls HGW seatbelts Eduard guy bay kit (late) Barracuda P-51D tires Eduard P-51 exterior detail kit Barracuda decals + placards Eduard canopy masks Eduard engine detail kit The main paints used were Mr. Color lacquers. Now for the final photos. All of the main markings were painted except the stars and bars and tactical lettering, which were decals. The stencils from the Barracuda decals were used instead of the kit stencils. The ailerons and elevators were glued in place. The rudder and flaps are movable and do a pretty good job of staying in place. The Eduard gun bay doors is an excellent upgrade over the kit doors. The ammo belts are from the Tamiya kit. The engine covers are all removable and fit reasonably well with Tamiya's magnet system. The starboard panel just under the exhaust is a little fiddly. The weathering was a combination of oils, airbrushed Tamiya acrylics (heavily thinned) used for local effects and with sponge chipping and spatter templates. Colored pencils and pastels were also used for various effects. Mr. Color GX100 was used for gloss coats and GX114 for flat coats. Great stuff. I used Mr. Color C330 RAF Dark Green for the fuselage. And a slightly darker version for the nose checks and spinner green. The NMF paints are Mr. Color Super Metallics. The checks on the nose were painted. The drop tank fuel and pressure lines were created from 0.5mm wire. I kept the weathering on the drop tanks relatively light since often they were single use items. All of the fastener holes in the engine panel frames were drilled out. Light colored oils were used on the NMF surfaces to depict varying amounts of oxidation on the panels. Eduard's engine upgrade contains PE hose clamps for all of the main hoses and piping in the engine. They are a pain to attach and paint but look pretty snappy when complete. Also, the edges of the gunsight glass were painted Tamiya clear green to simulate the look of the thick glass plate. The aluminum paint on the wings was rendered with a combination of the Mr. Color Silver and light gray. Mr. Surfacer was used to fill the rivets and panel lines on the forward 40% of the wings. Grime and wear was depicted using a combination of Tamiya acrylics, oil paints and colored pencils. Some wear is down to the primer and some is down to the base metal. The primer toward the back of the wing is ZCY and the primer toward the front is dark gray putty colored, based on the construction process. The Eduard gun bay doors really add a lot compared to the kit doors. The Eduard doors come with a hinge at the bottom of the door for gluing it permanently in place. I wanted to be able to remove them, so I made tabs similar to the kit doors and glued them onto the Eduard doors. I also added a support rod made out of 0.3mm wire. I really like the iconic 343 FS, 55th FG markings. Chipping around the panels and doors was done with acrylic paints and colored pencils. The cockpit detail from the Barracuda kit is quite good (details are on the build thread). One note was that I changed the wiring from the radio box behind the pilot seat because the cable harness would interfere with the canopy support bracket. So I converted to a strand of speaker wire and painted it black. Thanks for following along! Comments and critiques are more than welcome. Thanks again. TAG, Nikola Topalov, JayW and 38 others 40 1 Link to comment Share on other sites More sharing options...
rowin Posted June 11 Share Posted June 11 Hats off. Great P-51 model and photo session. Cheers Martinnfb, Hoss FL and MARU5137 1 2 Link to comment Share on other sites More sharing options...
Rod Bettencourt Posted June 11 Share Posted June 11 I like that!!!! Thanks for sharing. Rod Martinnfb, Hoss FL and MARU5137 2 1 Link to comment Share on other sites More sharing options...
zaxos345 Posted June 11 Share Posted June 11 Stunning!!! John MARU5137, Hoss FL and Martinnfb 2 1 Link to comment Share on other sites More sharing options...
Barry Posted June 11 Share Posted June 11 Beautiful model and fantastic photography! Looks quite real. Barry Martinnfb and Hoss FL 1 1 Link to comment Share on other sites More sharing options...
Zola25 Posted June 11 Share Posted June 11 That is just gorgeous! Absolutely beautiful work /Niels Martinnfb and Hoss FL 1 1 Link to comment Share on other sites More sharing options...
geedubelyer Posted June 12 Share Posted June 12 Holy smokes Are you kidding? What a fabulous model. That first picture.........just WOW Really, really great job. Thanks so much for sharing your beautiful creation Hoss FL and Martinnfb 1 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted June 12 Share Posted June 12 Beautiful piece of work Hoss Martinnfb, Hoss FL and MARU5137 2 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted June 12 Share Posted June 12 Great! show. Well done. Agreed. A thing of beauty. Sincerely, Mark Hoss FL and MARU5137 1 1 Link to comment Share on other sites More sharing options...
Michael931080 Posted June 12 Share Posted June 12 Stunning 'stang!! Hoss FL 1 Link to comment Share on other sites More sharing options...
TAG Posted June 12 Share Posted June 12 MARU5137 and Hoss FL 2 Link to comment Share on other sites More sharing options...
Troy Molitor Posted June 12 Share Posted June 12 Love it. Hoss FL and MARU5137 1 1 Link to comment Share on other sites More sharing options...
Rockie Yarwood Posted June 12 Share Posted June 12 Wonderful build and finish, Hoss! MARU5137 and Hoss FL 1 1 Link to comment Share on other sites More sharing options...
MARU5137 Posted June 12 Share Posted June 12 Hoss FL... WOWZER !! What a SPLENDID set of photographs. The first 4 photos look as if you are showing the real Major Edward Giller's "The Millie G". your photography is second to none. And your model is STUNNING and EXCEPTIONALLY EXQUISITE. Hoss FL 1 Link to comment Share on other sites More sharing options...
MARU5137 Posted June 12 Share Posted June 12 On 6/11/2022 at 4:00 PM, Hoss FL said: Thanks again. May I have your permission to use this photograph for MY screen saver please. Thank you. MARU 5137. Hoss FL 1 Link to comment Share on other sites More sharing options...
