F-104 1/32 "Catamaran" belly Aim-9 launcher?
Hi All,
Does anyone know if they have ever been produced in 1/32? I searched everywhere without sucess.
Italeri is only providing the Italian specific ones.
Tristan
DACO made both NATO and JASDF style Catamaran 'winder launchers in 1/48.
It might be worthwhile scratching one based on that item plus drawings if anyone has any to post here.
The Starfighter looked good with four AIM-9s (catamaran pair + one under each wing) plus wing tip tanks.
Tony
The parts are actually in the kits.  You use kit parts 42C and 43C, which are marked not for use in the G/S and RF kits.  These are the small “arms” that go across the belly and attach to the pylons.  Combine them with parts 44C and 45C, the pylons, and 8B and 9B, the Red Dog rails.  Note that there are only two Red Dog rails in the kits, so you can either use them on the belly, or on the wingtips, but not both.
You can see the parts use in the A/C kit in steps 24 and 25.
https://www.super-hobby.com/products/F-104-A-C-Starfighter-34377588.html
Hi Dave,
Actually the parts are not appropriate for a Nato 104. Neither the pylons nor the launchers (which should be  Aero 3Bs) are the good ones. And the arms looks suspicious to say the least.
Edited by Warbird
mistake
1 hour ago, Warbird said:
Hi Dave,
Ah, you didn’t mention you wanted the NATO catamaran launcher.  I assumed you wanted the US/Japanese Red Dog catamaran launcher.
I'm builing a KLU 104 - Sorry I didn't know US had a different one than NATO. It's a pity Italeri omited that in their G/S box.
When i did a Luftwaffe Zip with 'winders on the belly, i scratch built the pylons and used two rails from a Tamiya F-4C/D kit, modified. It is really odd there are no NATO launchers included.
They turned out good enough for me, someone more skilled should be able to do these simply enough.
Edited by dmthamade
Flying Leatherneck have 6 LAU-7 launchers for different aircraft/periods.for the life of me-I can't tell the difference,they all look alike :unsure:
https://www.flyingleathernecksdecals.com/c/132-resin
same case here?
I understand this type of launcher was mainly confined to display aircraft and almost never used operationally.
It's not difficult to envisage the amount of dirt and spray that would be thrown up all over the Sidewinder seeker heads.
Maybe not so much an issue in California, but way more so in rainy Europe.
Edited by Chek
It's not difficult to envisage the amount of dirt and spray that would be thrown up all over the Sodewinder seeker heads.
The catamaran configuration gave less drag for supersonic intercepts, so it was certainly used operationally.  When fitting the same launch rails on the wing pylons (not wingtips), that configuration gave less drag for subsonic intercepts.
 Share
