Stevepd Posted May 6, 2022 Share Posted May 6, 2022 I’m converting some fuel tanks into a spray tank. On the real thing on outer surface you can see the welds. Not very aerodynamic but functional none the less. How do I make these seam lines?. Steve. Link to comment Share on other sites More sharing options...
denders Posted May 6, 2022 Share Posted May 6, 2022 Hmmm, some sort of filler applied through a hypodermic needle? Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 6, 2022 Share Posted May 6, 2022 I've had some success using some very thin stretched sprue, glued into place with copious amounts of liquid cement, and then mashed and gouged into shape with a hobby knife while still soft. Experiment on a spare if you can, before going live! Kev Stevepd, D.B. Andrus and Alain Gadbois 3 Link to comment Share on other sites More sharing options...
chrish Posted May 6, 2022 Share Posted May 6, 2022 A lot of armor modellers discuss this kind of thing, they, from my readings use a method described by LSP Kevin...practice is key though. until someone makes a 1/32 TIG welder... Stevepd 1 Link to comment Share on other sites More sharing options...
Tec182 Posted May 6, 2022 Share Posted May 6, 2022 Or depending on size required: http://www.archertransfers.com/SurfaceDetailsArmor.html Stevepd and Woody V 1 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted May 6, 2022 Share Posted May 6, 2022 Tamiya resin putty rolled up into a tiny snake, then progressive toothpick action. D.B. Andrus and Stevepd 2 Link to comment Share on other sites More sharing options...
Martinnfb Posted May 6, 2022 Share Posted May 6, 2022 Nice tutorial from Martin Kovac. dodgem37, Ebf2K, D.B. Andrus and 3 others 6 Link to comment Share on other sites More sharing options...
thierry laurent Posted May 7, 2022 Share Posted May 7, 2022 There is another method to replicate the very thin weld seams you can find on modern tanks: use masking tape and dissolved putty or surfacer. Put the tape on each side of the future weld. Then spray surfacer or brush dissolved putty. Remove the tapes and clean the edges with a fine sanding sponge. Done! Stevepd, Ryan, Martinnfb and 1 other 4 Link to comment Share on other sites More sharing options...
TankBuster Posted May 7, 2022 Share Posted May 7, 2022 I have used lead wire, glue it down and then use small chisel to make the weld. Cheers. Martinnfb, Ryan, D.B. Andrus and 1 other 3 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted May 7, 2022 Share Posted May 7, 2022 Good show, Martinn. Many thanks. Sincerely, Mark Martinnfb 1 Link to comment Share on other sites More sharing options...
Woody V Posted May 7, 2022 Share Posted May 7, 2022 Probably not kosher to blow my own horn but I made THESE specifically for aircraft weld seams. Martinnfb, D.B. Andrus, Pete Fleischmann and 2 others 4 1 Link to comment Share on other sites More sharing options...
NigTT Posted May 7, 2022 Share Posted May 7, 2022 Much like LSP Kevin, I use thin stretched sprue or rod glued on with Tamiya extra thin and then soaked with more extra thin. Before it dries, to get the weld seam effect I use a wooden cocktail stick with just the very tip cut off, pushed into the sprue all along the seam. I have used this quite effectively on 1/35 Churchill tanks. Martinnfb and Stevepd 2 Link to comment Share on other sites More sharing options...
