SeaVenom Posted April 17, 2022 Share Posted April 17, 2022 I'm building the Italeri/Kinetic 1/32 F86F Sabre and I'm just checking the interior/cockpit colours etc are correct. The instructions say an overall dark gull grey for most of the cockpit and black for the instrument panels plus a red headrest for the seat with field green and red cushions. It also says the interior of the rear fuselage should be a green zinc chromate. The interior of the cockpit looks more of a lighter grey/gray to me on references I've seen like this ....... https://www.youtube.com/watch?v=RFw0AVWmgdg Also the way the fuselage is split in this kit with the rear on a trolley to show off the engine. Is that realistic or just a gimmick? I can't find any photo's like that. Link to comment Share on other sites More sharing options...
thierry laurent Posted April 17, 2022 Share Posted April 17, 2022 Which air force and which timeframe should first be clarified. Wartime US Sabres had black cockpits. Link to comment Share on other sites More sharing options...
SeaVenom Posted April 17, 2022 Author Share Posted April 17, 2022 Either 2 of the schemes on the instruction sheet. Firstly FLT James L. Thompson 39th FS Suvon AFB South Korea 1953 or NA.F 8th FBW col W.B. Wilmot Suwon AFB South Korea 1953. Link to comment Share on other sites More sharing options...
iaf-man Posted April 17, 2022 Share Posted April 17, 2022 (edited) 3 hours ago, SeaVenom said: Also the way the fuselage is split in this kit with the rear on a trolley to show off the engine. Is that realistic or just a gimmick? I can't find any photo's like that. It was common to all jet fighters up to the end of the 50ties,mainly because of the centrifugal compressors of the first engines,although some axial flow ones also had this feature,like the Skyhawk,F-100 https://secure.boeingimages.com/archive/F-86-Sabre-Jet-Engine-Removal-2F3XC5N138V.html Edited April 17, 2022 by iaf-man . LSP_K2 and MikeMaben 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted April 17, 2022 Share Posted April 17, 2022 23 minutes ago, SeaVenom said: Either 2 of the schemes on the instruction sheet. Firstly FLT James L. Thompson 39th FS Suvon AFB South Korea 1953 or NA.F 8th FBW col W.B. Wilmot Suwon AFB South Korea 1953. So cockpit should be fully black. Link to comment Share on other sites More sharing options...
Ayovan Posted April 17, 2022 Share Posted April 17, 2022 11 minutes ago, thierry laurent said: So cockpit should be fully black. I found this pic while doing a little research on this exact topic. It looks to me like the ejection seat, canopy support crossmember and rear wall of the canopy are gray. Just my 2 cents... John Glenn's mount Suwon 1953 Link to comment Share on other sites More sharing options...
thierry laurent Posted April 17, 2022 Share Posted April 17, 2022 I wrote the cockpit (tub, side consoles and front IP), not the seat or the canopy. Actually all marks of F-86 were delivered with black cockpits (including the seat) up to the F-86F BuAe 52-4500 for Inglewood production and BuAe 51-13400 for Columbus production. As the change to grey cockpits in North American Aircraft production seems to have been made in production around the end of 1952/beginning of 1953, this explains why Sabres used in Korea normally had black pits even if you can possibly find some of them with some grey components and this was the exception rather than the rule. "Mig Mad Marine" (52-4584) was precisely an exception as it was built in Inglewood right after that production change and was used in Korea. "Miss Tena" was similar as it belonged to the same batch (some grey components). However, wartime pictures of "the Huff" (that belonged to an earlier batch) clearly showed a black seat. Mark_C and Ayovan 2 Link to comment Share on other sites More sharing options...
Ayovan Posted April 17, 2022 Share Posted April 17, 2022 2 minutes ago, thierry laurent said: I wrote the cockpit (tub, side consoles and front IP), not the seat or the canopy. Actually all marks of F-86 were delivered with black cockpits (including the seat) up to the F-86F BuAe 52-4500 for Inglewood production and BuAe 51-13400 for Columbus production. As the change to grey cockpits in North American Aircraft production seems to have been made in production around the end of 1952/beginning of 1953, this explains why Sabres used in Korea normally had black pits even if you can possibly find some of them with some grey components and this was the exception rather than the rule. "Mig Mad Marine" (52-4584) was precisely an exception as it was built in Inglewood right after that production change and was used in Korea. "Miss Tena" was similar as it belonged to the same batch (some grey components). However, wartime pictures of "the Huff" (that belonged to an earlier batch) clearly showed a black seat. So, as with much in modeling, it will highly depend upon which particular aircraft you want to represent. Thanks for the explanation, Thierry. Link to comment Share on other sites More sharing options...
SeaVenom Posted April 18, 2022 Author Share Posted April 18, 2022 12 hours ago, iaf-man said: It was common to all jet fighters up to the end of the 50ties,mainly because of the centrifugal compressors of the first engines,although some axial flow ones also had this feature,like the Skyhawk,F-100 https://secure.boeingimages.com/archive/F-86-Sabre-Jet-Engine-Removal-2F3XC5N138V.html Thanks for those and great pics. I found pictures of other jets but for some reason I couldn't find ones of the Sabre. Link to comment Share on other sites More sharing options...
SeaVenom Posted April 18, 2022 Author Share Posted April 18, 2022 11 hours ago, thierry laurent said: I wrote the cockpit (tub, side consoles and front IP), not the seat or the canopy. Actually all marks of F-86 were delivered with black cockpits (including the seat) up to the F-86F BuAe 52-4500 for Inglewood production and BuAe 51-13400 for Columbus production. As the change to grey cockpits in North American Aircraft production seems to have been made in production around the end of 1952/beginning of 1953, this explains why Sabres used in Korea normally had black pits even if you can possibly find some of them with some grey components and this was the exception rather than the rule. "Mig Mad Marine" (52-4584) was precisely an exception as it was built in Inglewood right after that production change and was used in Korea. "Miss Tena" was similar as it belonged to the same batch (some grey components). However, wartime pictures of "the Huff" (that belonged to an earlier batch) clearly showed a black seat. Cheers for that. So what would you say were the grey components in Miss Tena? I take it the cockpit floor on the Huff would be black also? Link to comment Share on other sites More sharing options...
