1/32 BAe Harrier GR.5 ZD318 "first flight"
Hello,
this is the first Harrier GR.5 to be completed and flown, the ZD318 alias DB1, as took the air for the first time on 30 April 1985 at BAe Dusnfold flown by the company’s Chief Test Pilot Mike Snelling.
This was a Development Batch machine that was never handled to the RAF and remains to BAe for his entire life. Now he is preserved as a GR.7A in the Harrier Heritage Centre inside Royal Air Force Wittering.
The colours denote the work-share between the main manufactures, Bae in the UK and McDonnell Douglas in USA.
The following photos are posted for modelling discussion only. All the rights are by the authors.
zzd318_2
zzd318_1
The model is the 1/32nd Trumpeter GR.7 kit converted/backdated to a GR.5.
All the conversion parts are made from scratch by me: MIRLS bulged nose, instrument panel with the Moving Map Display, MB Mk.12 ejection seat, rear ventral chaff&flare dispenser box, wing pylons and ventral pylon. I’ve made the FOD air intakes too.
I’ve also correct: all the undercarriage legs, the wings profile, the ventral strakes, all the ECM/RWR lumps and bulges, the four engine nozzles.
Aires resin sets were used for the front undercarriage bay and the main cockpit tub, the IP cover and the canopy frame.
Some PE parts came from the Eduard set, as for the hot-nozzles shield plates and minor details.
All the fuselage, wings, tail planes panel lines were completely rescribed correct.
All paints are from the acrylic range of Tamiya for airbrushing and Vallejo for bush use.
As I said before, the colours denote the materials used in the construction of all the Harrier II: front fuselage and main wings are made with Carbon Fiber Composite, the rear fuselage section is made with metal alloys, other in aluminium, fiberglass, titanium, acrylic, steel and others.
The few decals for the necessary safety/resque markings, the cold-nozzles angle calibration and the serial number/identification number are from various spare decal sheets.
318_1
318_2
318_3
318_4
318_5
318_6
318_7
318_8
318_9
318_10
318_11
318_12
318_13
318_14
318_15
CIAO!
Piero
Edited by Piero
  • Piero changed the title to 1/32 BAe Harrier GR.5 ZD318 "first flight"
What a great rendition of the aircraft. I was at Boscombe Down when ZD319 “the grey one” when it came for testing. It definitely felt like a new era was upon the RAF, super modern shape and thinking. This is why I’m keen for a copy of the resin parts before I get too old…. Nope there we are.
Edited by Stevepd
 Share
