THE SHARK HAS LANDED! Curtiss Tomahawk 112sqn RAF
quang
2 hours ago, Jaro said:
I love all these small corrections (like the fairing you did) -- all them 'make' the final look of the model!
Indeed. I like implementing and sharing what I found in my ‘research’ on the internet.
And in the case of an excellent kit like this one, it’s 100% sheer modelling fun :wub:
Thank you all for your comments.
Cheers,
Quang
On 4/12/2022 at 11:30 AM, quang said:
Frank, Mike, John, thank you for your kind words :)
Before resuming the build, we’d take the opportunity to refine and to add some details to the already accurate and precise mouldings.
This rather simple extra task would add much to the realism of the model.
The underside fairing - the infamous ‘nun’s hat’-  is correctly shaped but would need some extra detailing.
1-The two parts of the fairing should be separated and the upper lip refined and thinned (red arrow)
2-I suspect the small gap (yellow arrow) is added in provision for the belly tank of the P-40C. It's not present on the earlier variants and should be filled.
3-The crude moulded fuel and oil dump lines are removed and replaced with appropriate tubings.
FA0-B3151-9-BD7-4-D24-957-E-975-D405-B11
The 2 parts of the fairing are separated
A8050-CCC-D4-B4-4-DFA-891-B-10-F02-C4824
C20-BEE32-63-F3-4-FE3-8-BD2-B621-F8746-F
Upper lip thinned, gap filled, drain tubes
D8-A18-F5-F-2-F17-4497-BE96-7-DBA2-F374-
Primed
245652-FA-BCE9-42-D9-951-E-DF97-BF299882
The electrical tab on the left wing only applies to the USAAC planes.
On the export H81, it should be removed …
2-B18-F38-C-BE8-E-44-DA-85-D8-4-D122-F3-
…and replaced by an external tab on both wings.
FCBB1859-ECF7-4-C51-92-CD-590-B8-E0-B79-
The windscreen on the H81 is a delicate affair. The armoured glass is installed first.
7-D5-ECDA4-85-ED-4161-B84-B-002-FC72-DE8
Like on the actual export H81, no gunsight is provided in the kit ;) as it was up to the recipient air forces to provide the appropriate sight.
Our RAF Tomahawk will get a Barr&Shroud MK2 salvaged from a defunct Fly Hurricane mounted on a sprue cross-bar.
96485-AF2-0-FA9-45-AC-BA6-C-DF94-AB40-B0
3121-D661-4-A85-4298-AAF3-2771656392-EA.
4-F44-BF0-D-0160-4-B40-A89-A-3733-C5-E55
C831098-A-9742-492-B-B1-FF-A4-B70-A40-C2
D328-E9-BB-3-ED0-48-FC-B53-B-F82-BFE4-F7
When the mods are completed, the main components of the airframe are assembled, the joints checked and ready for a final coat of primer before rolling to the paint shop.
Until then keep well.
Cheers,
Quang
 Very nice progress abd detail addition.
And I have a question
Did it need to be filled ventral hole (yellow arrow) for AVG Tomahawks?
If so, I have to fix it in my WIP.
Yes indeed. Incidentally this ventral hole is the exact location of the bomb rack/ fuel tank attachment on the P-40C which I suspect GWH has projected for another boxing.B)
Looking back, I found out I forgot to fill the small indent in the lip (which of course, must also be filled).
On the other hand I re-made bigger drain lines and add a 3rd flexible line for the pilot’s relief :wacko:
BB9-CC728-E360-4-BC6-8-DD6-65762-A54485-a
Today’s motto: NEVER LOOK BACK at what you’ve already done. You’ll inevitably find something wrong that will need correcting :BANGHEAD2:
Cheers,
Quang
Gone hunting for Easter eggs
Cheers,
Quang
Exactly
Agreed with today s motto.
I will make some minor corrections and will go on
Edited by Tolga ULGUR
No merit here, Matt. I’m only implementing what I learned on the internet.:)
Now back to the build. A few more details have to be dealt with before committing to the paint shop.
Filling the indent on the fairing lip. A piece of sprue is stuck in the indent.
24-A7-EE5-B-D236-44-E6-A9-D6-23-F9648098
Excess removed and sanded…
E95901-AF-39-A1-4084-B664-9-B6969-FDA1-A
… after a coat of primer
8-C418-FFB-D0-CC-4-B00-9-CAF-790-D85-B88
Many RAF Tomahawks of the desert air force wore a mast antenna. I fashioned mine from a bamboo cocktail stick.
3-C44456-B-E8-A6-49-E0-892-D-B6-FEA87-AA
I also took the opportunity to add two ceramic insulators. These were also on the AVG machines.
AADC8-DBE-DBBB-4-E67-8-EDD-46-F270-E9151
Walkways were often found on RAF and AVG Hawks. They were made from a strip of linoleum (a popular floor covering that old timers remember from their childhood days) glued to the wing and secured by a riveted strip of aluminium to keep the lino from fraying.
Mine are made from the tin sheet covering the neck of a (carefully emptied) wine bottle.
DC4320-AA-56-C6-4-CDE-B0-B3-1-A206996792
109-BEA39-828-B-40-E5-8-A76-5-EB1-E2-E4-
Rivets added and under a coat of primer
474235-BE-84-A4-42-F7-A749-9-E75445-AAEC
A final detail before we go… this small round hatch on the right side of the fuselage. I don’t know its purpose but it’s frequently shown open on many period on-the-field photographs. I decide to add it as a conversation piece. B)
62684-E4-F-338-E-428-D-B85-F-307-D6997-F
That’s it folks.
Next time hopefully we’ll be stirring the pots … of colours :lol:
Until then, keep well
Cheers,
Quang
Edited by quang
That’s it folks.
Cheers,
Quang
Looks great indeed.
This will be a good reference for my second Tomahawk with TuAF markings. TuAF Tomahawks were sent from RAF Med stocks.
So it’s the hole for the starting hand crank. Does make sense. Thanks Mike!
GWH should have included a full set of service stencils. It would help appreciate the kit even more! ;)
Edited by quang
I don’t know how I’ve missed your build Quang, a prolonged senior moment perhaps or obsession with solving a Bf110 nacelle build :shrug: but I’ve just enjoyed reading about your adventure. Loving every step of the way….I do like a thorough and well researched build, and the shark mouth is sublime!
i’ve given myself a good talking to, and subscribed to “Following”! :coolio:
  • quang changed the title to THE SHARK HAS LANDED! Curtiss Tomahawk 112sqn RAF
