Daywalker Posted April 26 Share Posted April 26 MUCH better! Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted April 27 Share Posted April 27 Glad it was an EZ fix Tolga . Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted May 5 Author Share Posted May 5 Hello everyone, Before sharing WIP pictures I would like to clarify some points. As you can see in the first picture there is an ventral antenna mast . If I m not wrong this was added during restoration of this bird. And it seems that GWB copied this entirely. So I have decided not to use this piece, albeit late. That means some minor work is needed to remove traces of this plugin And secondly the color of both fuselage lights (left and right side) is blue. Is that correct?? Thanks in advance. BiggTim, MARU5137 and Rocat 3 Link to comment Share on other sites More sharing options...
quang Posted May 6 Share Posted May 6 (edited) I don’t know about the first photo but on the second one, it’s indeed a blue formation light on both sides of the fuselage. Same light on a P-40E Cheers, Quang Edited May 6 by quang Tolga ULGUR, Rocat, scvrobeson and 3 others 6 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted May 6 Author Share Posted May 6 Thanks @quang I found some pictures on the internet. It seems that this part was not found on the original aircraft. I think it's an antenna mounted on restored aircraft in flying condition So I deleted it. themongoose, scvrobeson, MikeMaben and 2 others 5 Link to comment Share on other sites More sharing options...
quang Posted May 6 Share Posted May 6 It looks indeed like a ‘modern’ antenna MARU5137 and Tolga ULGUR 1 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted May 12 Author Share Posted May 12 Some progress. Rockie Yarwood, ivanmoe, themongoose and 13 others 16 Link to comment Share on other sites More sharing options...
BiggTim Posted May 12 Share Posted May 12 On 5/5/2022 at 4:48 AM, Tolga ULGUR said: On 5/5/2022 at 8:53 PM, quang said: Correct me if I'm wrong, but doesn't that light appear to be in a different location in these two pics? It seems much farther forward on the P-40E. Maybe that is just a difference between the B and E variants? Out2gtcha 1 Link to comment Share on other sites More sharing options...
quang Posted May 12 Share Posted May 12 29 minutes ago, BiggTim said: Correct me if I'm wrong, but doesn't that light appear to be in a different location in these two pics? It seems much farther forward on the P-40E. Maybe that is just a difference between the B and E variants? Indeed the lights were in a different location depending on the version but they served the same purpose. I posted the pic just to show how it looks like. You’d agree it’s a very special kind of blue BiggTim and Paul in Napier 2 Link to comment Share on other sites More sharing options...
quang Posted May 12 Share Posted May 12 Taking good shape, Tolga Just two minor details you’d want to correct: The two filler caps under the side window should be RED (fuel) in front and YELLOW or SILVER (oil) at the rear. GWH got it wrong with their instructions A noticeable difference between the P-40B/C and the later versions is the central seam visible under the chin. They’re very easy to correct and would add much to the finished model. Cheers, Quang rafju, Rocat, Paul in Napier and 3 others 6 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted May 12 Author Share Posted May 12 1 hour ago, quang said: Taking good shape, Tolga Just two minor details you’d want to correct: The two filler caps under the side window should be RED (fuel) in front and YELLOW or SILVER (oil) at the rear. GWH got it wrong with their instructions A noticeable difference between the P-40B/C and the later versions is the central seam visible under the chin. They’re very easy to correct and would add much to the finished model. Cheers, Quang Ahha.. Murpy's finger in charge. Thanks for the warning @quang I will fix them. By the way I have a question about the propeller. Are the propeller tips of these AVG P-40s painted yellow? Link to comment Share on other sites More sharing options...
quang Posted May 12 Share Posted May 12 (edited) I’m not sure about the AVG but on the RAF Tomahawks, yellow tips only on the side opposite the pilot. Edited May 12 by quang scvrobeson, Paul in Napier, Rocat and 6 others 8 1 Link to comment Share on other sites More sharing options...
dennismcc Posted May 13 Share Posted May 13 Lots of great modelling going on here and lots of useful information for my future build. Cheers Dennis Daywalker and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted May 13 Author Share Posted May 13 And here it is: I have used Barracudacast main whells which are designed for Trumpeter kit. But no chance for the tailwheel . It is from the box. And the seat. I have used Eduard seatbelts. Fanes, MikeMaben, patricksparks and 6 others 9 Link to comment Share on other sites More sharing options...
quang Posted May 13 Share Posted May 13 Good corrections The resin tyres are great. Which paint did you use for the rubber tailwheel? How did it behave? Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
