chrish Posted February 25, 2022 Author Share Posted February 25, 2022 A strange time to be building a Ukrainian themed Russian built aircraft but...I'm back on task. Having started a 1/6 resin female (scantily clad of course) whilst awaiting Zacto resin parts and then a Revell 1/32 Me 262 while waiting for the oils to dry on the figure I was a bit off topic (probably why this model ended up on the shelf of doom the first 2-3 times) Anyway, the 262 is done and off the bench an on the shelf. The figure is standing near the back of the bench awaiting her head and arms and the resin Zacto parts (shown here) are destined for the Su-27. I initially thought they were fairly pricy but the quality of the parts is amazing. Thanks for looking Zola25, Daniel Leduc, Martinnfb and 9 others 12 Link to comment Share on other sites More sharing options...
Stokey Pete Posted February 26, 2022 Share Posted February 26, 2022 (edited) I can’t praise the zacto’ stuff more highly that I have in the past. I have the full monty thrown at mine. I would say, have patience and make small adjustments when you dry fit the intakes and their parts. It’s all too easy to keep sanding a little here. Trimming a little there, and end up with gaps to fill. Edited February 26, 2022 by Stokey Pete geedubelyer and Martinnfb 2 Link to comment Share on other sites More sharing options...
chrish Posted February 27, 2022 Author Share Posted February 27, 2022 True fact stated above. I trimmed here and sanded there I still had to add a bit of filler but not as bad as it could've been (being the mediocre modeller I am) Some images of the work so far; The resin bits cleaning up building and painting the intakes; they even have probes in the ducting fitting out required the removal of some surplus plastic. and glued in place; and that's it for now Thanks for looking Kagemusha, geedubelyer, LSP_Kevin and 8 others 10 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted March 2, 2022 Share Posted March 2, 2022 Really nice stuff are going on here Link to comment Share on other sites More sharing options...
chrish Posted March 3, 2022 Author Share Posted March 3, 2022 Thanks for the encouragement! This build has stalled more often than an old car but seems to be on a bit of a roll (for now) I've managed to fix a few errant seams and splash some paint on here and there Doesn't show real great in the pictures but there's at least 5 shades of Alclad lacquers on the cans (Reskit- great stuff) and engine sections. and just purchased today; Thanks for looking geedubelyer, MikeMaben, LSP_Kevin and 9 others 12 Link to comment Share on other sites More sharing options...
geedubelyer Posted March 3, 2022 Share Posted March 3, 2022 Superb metal work Chris. Looks like the Reskit cans are super thin and fragile? They look great in your pictures though. Good job Martinnfb 1 Link to comment Share on other sites More sharing options...
blackbetty Posted March 4, 2022 Share Posted March 4, 2022 very cool build, dont know how i overlooked it. pulled out mine yesterday, i have the single seater and the foxbot decals. Martinnfb 1 Link to comment Share on other sites More sharing options...
chrish Posted March 7, 2022 Author Share Posted March 7, 2022 Thanks for checking in on me. A difficult subject to continue with knowing what's going on in Ukraine...As well, the masks were quite difficult (for me) to make use of. I had to use super glue debonder brushed under a raised edge to get the masks to lift off without leaving adhesive behind or ripping off the paint. I did have to re-mask a lot of areas with small squares of Tamiya tape to re-paint places...more than I would've liked. I hesitate to put any blame on the Foxbot masks thinking it may (possibly?) be a reaction between the paint and the masks or my application. In any case, here's where the model sits tonight. bleed under and paint lift visible here; repairs in progress; Thanks for looking Isar 30/07, Martinnfb, LSP_Kevin and 11 others 14 Link to comment Share on other sites More sharing options...
Stokey Pete Posted March 7, 2022 Share Posted March 7, 2022 Coming together nicely now Chris. I too, had similar experiences with the masking set. I think it’s a combination of them having a fairly high tack, and the hard edges of each colour, makes it very easy to lift paint from under any masking. I spent hours staring at it and making tiny repairs over every bit of the surface. chrish and Martinnfb 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted March 7, 2022 Share Posted March 7, 2022 Martinnfb 1 Link to comment Share on other sites More sharing options...
Zola25 Posted March 7, 2022 Share Posted March 7, 2022 Looking really good Chris What brand of paints are you using? /Niels Martinnfb 1 Link to comment Share on other sites More sharing options...
chrish Posted March 9, 2022 Author Share Posted March 9, 2022 On 3/7/2022 at 2:45 AM, Zola25 said: Looking really good Chris What brand of paints are you using? /Niels Thanks Niels Tamiya acrylic for the gray Vallejo acrylics (model air) for the blues primed white with Tamiya fine surface primer (white) Martinnfb, Zola25 and blackbetty 3 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 9, 2022 Share Posted March 9, 2022 Great work so far! Martinnfb 1 Link to comment Share on other sites More sharing options...
chrish Posted March 10, 2022 Author Share Posted March 10, 2022 (edited) All....all I could find so far paint problems have been fixed and the Zacto pylons and engines added. Without weapons added the Zacto pylons are almost mandatory for the details they add when the business side of the pylon is exposed. Again, keep in mind, I strive for mediocrity That's all for now Thanks for looking Edited March 10, 2022 by chrish Zola25, Dragon, panzerrob and 13 others 16 Link to comment Share on other sites More sharing options...
themongoose Posted March 10, 2022 Share Posted March 10, 2022 38 minutes ago, chrish said: All....all I could find so far paint problems have been fixed and the Zacto pylons and engines added. Without weapons added the Zacto pylons are almost mandatory for the details they add when the business side of the pylon is exposed. Again, keep in mind, I strive for mediocrity That's all for now Thanks for looking Thanks for looking OVERACHIEVER! Dpgsbody55, Martinnfb and chrish 1 2 Link to comment Share on other sites More sharing options...
