brahman104 Posted January 12, 2022 Share Posted January 12, 2022 7 hours ago, JayW said: Peter, it would have taken me weeks upon weeks just to do the computer modelling required to design the PE parts! Not to mention the research to get the right config. How did you do it so fast? +1. I can't even imagine how you have such incredible forward thinking to conceive all the little parts and subassemblies that you'll need PE for and make them 100% accurate, so early in the build! But I guess you've done this a few times now! Craig KiwiZac, airscale and Martinnfb 3 Link to comment Share on other sites More sharing options...
Thomas Lund Posted January 13, 2022 Share Posted January 13, 2022 That is sooooo impressive ! I wish I had read this before starting my F-104... I can see a couple of things that could have been much easier airscale and Martinnfb 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted January 13, 2022 Share Posted January 13, 2022 Good show. Lots of drawing, there. You cut down on some of the challenging construction by using PE. Scratching can get tiring at times. Sincerely, Mark Martinnfb and airscale 2 Link to comment Share on other sites More sharing options...
Jim Barry Posted January 13, 2022 Share Posted January 13, 2022 Nice work with the foam. My Bearcat is built up with it. I sort of wish it was harder would be my only complaint. It's almost too easy to work with but once you sort of respect that, you can adjust. Rocat, Out2gtcha, Landrotten Highlander and 8 others 11 Link to comment Share on other sites More sharing options...
Starfighter Posted January 14, 2022 Share Posted January 14, 2022 There are (much) harder versions of this foam available. They are usuall brown or green. Ironwing, Martinnfb, airscale and 1 other 4 Link to comment Share on other sites More sharing options...
zaxos345 Posted January 14, 2022 Share Posted January 14, 2022 Amazing!!!! John Martinnfb and airscale 2 Link to comment Share on other sites More sharing options...
airscale Posted January 19, 2022 Author Share Posted January 19, 2022 evening folks thank you for stopping by with some encouragement On 1/12/2022 at 2:59 PM, RadBaron said: Fantastic progress, Peter! For future reference, here are some pics of the floor area (from a P40K), note the panel lines continuing across the span of the wing. Hope that helps! Denzil. Great to hear from you Denzil - I hope all is well - thanks for that, hopefully I have captured some of that detail in the floor coming up On 1/12/2022 at 4:03 PM, JayW said: Peter, it would have taken me weeks upon weeks just to do the computer modelling required to design the PE parts! Not to mention the research to get the right config. How did you do it so fast? Hi Jay - well I had a long break over the holidays and I did put in some 10 hour shifts doing drawing after drawing - I literally went through a 320 page parts manual and copied everything I thought either I needed or could physically be done in PE - even if they are template parts for working up plastic or metal 3D versions - I think there are about 500 parts.. On 1/13/2022 at 9:41 AM, dodgem37 said: Good show. Lots of drawing, there. You cut down on some of the challenging construction by using PE. Scratching can get tiring at times. Sincerely, Mark Exactly Mark - not only is it ultimately a time saver, but the results are geometrically accurate - things like rows of rivets or holes are vitually impossible to get micron perfect by hand. On top of that some shapes and parts are equally hard to capture, so having an eye for what can be done in PE is so helpful so, I was away for a bit so not too much bench time, but I did get the lower cowl fairing on after adding the PE radiator parts inside first.. rear... ..front.. ..I have a 3D printed part to sit in front of the lower intake - shaping it properly with all the fillets & fairings is well beyond me, but this will serve the purpose of having a hard basis part with which to work, shape & skin... ..should be here tomorrow.. and how the airframe looks.. ..started on some of the internals - this is the control column and rods - lots of fabricated bits from drawings - nearly got caught out with the lower mount which is two rods one above the other on early models, but as can be seen in Denzil's pic above is canted on later models - I built the canted one from drawings before realising.. the grip was made from square brass rod, worked with a dremel & files.. ..it all needs priming & finessing and proper construction before it's finished.. ..on to the floor - this is where PE can really help - I built a jig to hold the floor in the aerofoil shape, but did not include any dihedral as its too hard to do if I use PE.. The centre rib is a laminate of just the bit you can see, with stubs of fuse wire for bolts.. this is the main floor PE with laminate parts for the central rivet strips and the wing fuel gauges, the areas clear of rivets in the centre are left as location markers for the rubbing plates.. primed, painted and with the rubbing boards and a couple of pipe unions added.. ..I love doing cockpits so will be here a while TTFN Peter GMK, Antonio Argudo, RadBaron and 24 others 27 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 19, 2022 Share Posted January 19, 2022 Bloody amazing....... phasephantomphixer, airscale, JayW and 1 other 4 Link to comment Share on other sites More sharing options...
dodgem37 Posted January 19, 2022 Share Posted January 19, 2022 Good show. Exposed fastener heads are a nice detail. Nice grip sculpture. Fantastic finish, too. Sincerely, Mark Gerhard, Rockie Yarwood, scvrobeson and 4 others 7 Link to comment Share on other sites More sharing options...
JayW Posted January 20, 2022 Share Posted January 20, 2022 Just stunning Peter. Martinnfb and airscale 2 Link to comment Share on other sites More sharing options...
KUROK Posted January 20, 2022 Share Posted January 20, 2022 Aye - Yi -Yi !!! Super cool. Which color do you use for the interior green? Looks just right. airscale and Martinnfb 2 Link to comment Share on other sites More sharing options...
brahman104 Posted January 20, 2022 Share Posted January 20, 2022 Spectacular yet again Peter! I spent most of the day re-reading your race 80 ebook, so this was a most pleasant follow on! The radiator is nothing short of perfection Craig Martinnfb and airscale 2 Link to comment Share on other sites More sharing options...
Jaro Posted January 20, 2022 Share Posted January 20, 2022 Mark, spectacular build (as always)! If this is not a problem please consider taking photos, in particular small elements, with something else aside just for size reference. Of course not all of them, but from time to time. airscale and Martinnfb 2 Link to comment Share on other sites More sharing options...
zaxos345 Posted January 20, 2022 Share Posted January 20, 2022 Speechless!! John airscale and Martinnfb 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted January 20, 2022 Share Posted January 20, 2022 Jaro, the author is Peter Castle. Not Mark. Sincerely, Mark Martinnfb 1 Link to comment Share on other sites More sharing options...
