easixpedro Posted January 22, 2023 Author Share Posted January 22, 2023 Progress on the ball turret. I think the key to any kit this size is to approach it like you’re building a bunch of mini kits. The ball turret is a case in point. Before I started working on it, I wanted to know if this plane even had a ball turret. At some point in the middle of the B-24L production run they stopped installing ‘em. They were completely gone by the time the B-24M came along. I’ve searched high and low, and found nothing conclusive for this plane. From what I’ve seen of others in the BW at the same time, they all had ‘em, so I’ll keep it. I also had to dig to ensure that they had the ammo cans on the outside, which they did. B-17s and early model B-24s didn’t - the ammo was all kept internal to the turret. The kit gives you ammo cans above, so I’m good there. Here’s a great link to a period manual: https://www.ibiblio.org/hyperwar/USN/ref/AirGunnery/TURRETS5.html You can also follow this link for Hangar Thirteen’s manual. https://hangarthirteen.org/library/ and the manual itself: http://hangarthirteen.org/wp-content/uploads/2020/08/11-45G-1-Handbook-for-Sperry-Lower-Ball-Turrets-A-2-A-2A-A-13.pdf They’re a tremendous resource for sure. So onto the turret. Not a bad OOB. A little plain, but won’t be seen as it’s raised in the fuselage if you build it with the gear down. I’m not doing that, so of course I put a figure in there. Not much else, as it won’t be seen. I had to make some shell ejector chutes as the kit’s were wonky. They didn’t even line up with the ports, which I also had to open up… It all clicks together and is a really nice fit! You can see I dirtied up the gunner’s boots like he’d been tramping around a muddy Italian airfield… Masking it was a bit of a pain and took the better part of an hour. Here it is after a quick shot of Tamiya AS-12. And here’s the turret mechanism before painting (it’s painted now, but no pics). I’ll swap out the suspension arm so that it hangs down outside the fuselage (and why I’m doing this now, before I button the fuselage up). Here’s the Right Waist Gunner. Needs the O2 line to his mask and add the ammo chute to his gun and he’s done. And a view from outside. Once the fuselage is closed you definitely can’t see this much…! That’s it for now. Thanks for following along, and I appreciate everyone’s comments. -Peter MikeC, Rockie Yarwood, Citadelgrad and 20 others 23 Link to comment Share on other sites More sharing options...
JayW Posted January 22, 2023 Share Posted January 22, 2023 To steal an aviator's term - this is Sierra Hotel!!! Those manuals are amazing. I am about 5' 5" - I would have fit in there beautifully. What an educational build Peter. Nice work. Can't believe you got a person in that ball.... easixpedro 1 Link to comment Share on other sites More sharing options...
themongoose Posted January 22, 2023 Share Posted January 22, 2023 Your work on the ball turret is stellar. And huge props for fitting the figure in there AND muddying up his boots - brilliant, buy yourself a Guinness! easixpedro 1 Link to comment Share on other sites More sharing options...
easixpedro Posted January 23, 2023 Author Share Posted January 23, 2023 14 hours ago, JayW said: To steal an aviator's term - this is Sierra Hotel!!! Those manuals are amazing. I am about 5' 5" - I would have fit in there beautifully. What an educational build Peter. Nice work. Can't believe you got a person in that ball.... 14 hours ago, themongoose said: Your work on the ball turret is stellar. And huge props for fitting the figure in there AND muddying up his boots - brilliant, buy yourself a Guinness! Thanks guys. I was rather shocked that I managed to pull it off. The figure is a mashup from the spares bin, mostly a Tamiya figure from their early M113 offering. He was the smallest though--and I checked him compared to all the other figures. So makes sense seeing as how the shortest guys in the crew became ball gunners. I'm gathering folks like the background detail I'm providing, so will hopefully have a few more updates in that regard. Frankly the build has been a bit of a struggle in that, I want to go to town on things, but have to constantly pull myself back from the edge. Case in point--I just put little black dots for the eyes of the gunner. Am I capable of more? Yes. Is it visible? No. The dots actually look better once everything is closed up as it gives the impression, and your mind fills in the details. But it's driving me a bit batty as I look at the pics and see sloppy painting etc. Looks like it was painted by the teenage version of myself. But once closed up it looks good, so I'll keep forging ahead. And a fella did wrap this up with a cold snack! -Peter chrish, John1, JayW and 2 others 5 Link to comment Share on other sites More sharing options...
Oldbaldguy Posted January 23, 2023 Share Posted January 23, 2023 You know what? Yer ball turret looks just like a pod out of any number of sci-if movies - 2001, Star Wars, Oblivion and probably several others I don’t recall. Hmmmm. I wonder if maybe a prop department somewhere happened to have a ball turret laying around and the rest is history. JayW and easixpedro 2 Link to comment Share on other sites More sharing options...
John1 Posted January 24, 2023 Share Posted January 24, 2023 18 hours ago, Oldbaldguy said: You know what? Yer ball turret looks just like a pod out of any number of sci-if movies - 2001, Star Wars, Oblivion and probably several others I don’t recall. Hmmmm. I wonder if maybe a prop department somewhere happened to have a ball turret laying around and the rest is history. You are 100% correct. Look at the Star Wars' "Tie Fighter". Lucas admitted that it's cockpit was based on a WW2 ball turret. Oldbaldguy and easixpedro 2 Link to comment Share on other sites More sharing options...
easixpedro Posted January 25, 2023 Author Share Posted January 25, 2023 Just found this pic in ye' old personal archives. It's a doozy. SOOOO many details to study and soak up. It's a B-24L. No ball turret that I can tell (though the shadows don't help). It's got the stinger guns instead of the tail turret. She's coming in for a landing with #1 feathered and I'm guessing #2 isn't providing much power based off the amount of oil thrown on the vertical stab. And look at the rudder. It's a replacement from the 484th BG. It's OD with the bowtie that mismatches the rectangle of the 461st. Might have a go at replicating that when the time comes Have no clue about time or date, but a fascinating photo nonetheless! -Peter Victor K2, JayW, MikeC and 5 others 8 Link to comment Share on other sites More sharing options...
John1 Posted January 26, 2023 Share Posted January 26, 2023 When I was a kid, I met a friend of my dad's. Somehow the subject of WW2 bombers came up and he casually mentioned that he flew B-24's out of England during the war. I jumped in with "Wow, you flew Liberators?". He seems genuinely shocked that a 1980's teen would know this. I asked him what it was like (as a kid, the thought that I was possibly prying never occurred). He just said "It was pretty damned cold up there" and changed the subject. Keep up the good work, this build is something special Pete. JayW and easixpedro 1 1 Link to comment Share on other sites More sharing options...
easixpedro Posted January 26, 2023 Author Share Posted January 26, 2023 Right there with you John. My uncle never really talked about it, other than I remember him telling me about not having a waist window. That, and a story about the first time he'd ever had too much to drink and had a hangover. Background that I've uncovered is this. In August 1944, the Allies landed in southern France (Operation Dragoon). In September 1944, the 15th began ferrying supplies to forward fighter strips to help supply the fight. The 49th Bomb Wing flew roughly 7 missions from 10-22 September. On their very first one, one of the APUs (otherwise known as a put-put) caught fire, as they tended to do. The resulting fire destroyed one of the B-24s, and crews scrambled to get the rest out of the way. There's some pretty famous pictures of the event that are in a lot of WW2 books. 100 Octane AVGAS and fire, plus oil, bombs and bullets isn't a good combo... Here they are, courtesy of the 461st website: My Uncle flew three of these supply missions, and during one, they essentially found some good french wine and got plastered. He said the flight the next day was rough and only felt better after sucking on the pure O2 from the plane. My guess is that mission was on 17 September, as the entire wing had to divert due to weather and deliver supplies the next day. (and not that I EVER used O2 to cure a hangover before going flying... something about aviators and live fast, die young mentalities!) -Peter Paul in Napier, JayW, themongoose and 4 others 7 Link to comment Share on other sites More sharing options...
mc65 Posted January 26, 2023 Share Posted January 26, 2023 well, maybe a hangover cure not, but a couple of puffs on the first flight in the morning helps to wake up! this, combined with my habit of test the mask's mike by imitating Dart Vader or The Central Scrutinizer helped the rest of the crew to wake up! themongoose and easixpedro 2 Link to comment Share on other sites More sharing options...
Oldbaldguy Posted January 26, 2023 Share Posted January 26, 2023 Anybody besides me note in one of the photos above that the nosewheel is turned but the rudders are not, meaning the nosewheel is not steered by the rudder pedals, something I did not know. easixpedro 1 Link to comment Share on other sites More sharing options...
easixpedro Posted January 26, 2023 Author Share Posted January 26, 2023 3 hours ago, Oldbaldguy said: Anybody besides me note in one of the photos above that the nosewheel is turned but the rudders are not, meaning the nosewheel is not steered by the rudder pedals, something I did not know. Yes, that I recall they were free-castering, meaning it swiveled like the front wheel of a shopping cart. Pilots would steer with differential braking and perhaps a bit of thrust in extremis. Still easier than taxiing a tail dragger though. I can’t imagine having to taxi the Corsair or the Thunderbolt (and why you see pics of ground crew sitting on wings to help them clear). There’s certainly an art to taxiing a plane from this generation. HB252 1 Link to comment Share on other sites More sharing options...
easixpedro Posted January 28, 2023 Author Share Posted January 28, 2023 Back on page 7 @JayW asked about "friendly fire." Ran across this picture yesterday and thought it summed up the issue up nicely. It did happen (still happens). As OBG stated, the turrets had cam locks to prevent gunners from shooting their own ships, but a clear field of fire is mighty important. This is the first pictorial evidence I've seen though. Everything else has just been in histories on the topic. Found it on page 245 of this book, and posted under fair use. -Peter HB252, themongoose, JayW and 1 other 4 Link to comment Share on other sites More sharing options...
easixpedro Posted January 29, 2023 Author Share Posted January 29, 2023 Waiting on ammo feed chutes to arrive. Apparently the Pony Express is slowed a bit due to the weather. Have the other waist gunner done. They're tuff to photograph due to the reflection from the waist windows. That and not a lot is visible. Managed this photo though. Looks like a period pic from the war, so thought I'd share. Once I get the feed chutes. I can add those and do the O2 lines before I start the process of closing up the fuselage. Kind of excited for that as its a big moment on the build. -Peter MikeMaben, Dany Boy, LSP_Kevin and 8 others 11 Link to comment Share on other sites More sharing options...
aircommando130 Posted January 29, 2023 Share Posted January 29, 2023 Add some 1/32 empty brass shell cases to the floor and it would really look real! Great job so far! I have the "D" model to build. Haven't figured the setting yet but it will be the "Lady Be Good" prior to the fateful mission. Cheers...Ron easixpedro 1 Link to comment Share on other sites More sharing options...
