Nigels modelling bench Posted November 30, 2021 Share Posted November 30, 2021 (edited) As can be seen in the attached pic i am wrapping up my ZM Ta 152 project and have a question regarding the ali panels on the under wing and belly surfaces. You can see where I've masked the NMF and will paint around it RLM76. Is this correct or would it have been a soft edge where they spray painted in the field? Thanks for any advice. Nige Edited November 30, 2021 by Nigels modelling bench Paul in Napier and Martinnfb 2 Link to comment Share on other sites More sharing options...
John1 Posted November 30, 2021 Share Posted November 30, 2021 Can't see /open your picture but from what I recall, late war German aircraft were assembled from components made all over the country. Typically, some of the underwing panels would be left in NMF, while others were finished with whatever color was called out / they had laying around the shop. As such, I would wager that it's a hard finish going from one panel to another. Uncarina, Paul in Napier and Nigels modelling bench 3 Link to comment Share on other sites More sharing options...
Nigels modelling bench Posted November 30, 2021 Author Share Posted November 30, 2021 Thanks John, I cannot make the Imgur link work for some reason?? Nige Link to comment Share on other sites More sharing options...
LSP_K2 Posted November 30, 2021 Share Posted November 30, 2021 The link brings me right back to this thread. Link to comment Share on other sites More sharing options...
Nigels modelling bench Posted November 30, 2021 Author Share Posted November 30, 2021 25 minutes ago, LSP_K2 said: The link brings me right back to this thread. I have forgotten how to upload from Imgur??? Doh LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted November 30, 2021 Share Posted November 30, 2021 2 minutes ago, Nigels modelling bench said: I have forgotten how to upload from Imgur??? Doh Can't help you, brother, I've never used it. Link to comment Share on other sites More sharing options...
modelmkr Posted November 30, 2021 Share Posted November 30, 2021 Nigels modelling bench, LSP_K2, Martinnfb and 1 other 4 Link to comment Share on other sites More sharing options...
Nigels modelling bench Posted November 30, 2021 Author Share Posted November 30, 2021 Just now, LSP_K2 said: Can't help you, brother, I've never used it. I am copying the BB code link and putting it in "Insert image from URL". I'm sure this is what I've done in the past? Link to comment Share on other sites More sharing options...
Nigels modelling bench Posted November 30, 2021 Author Share Posted November 30, 2021 Just now, modelmkr said: Any idea what I'm doing wrong @modelmkr?? Link to comment Share on other sites More sharing options...
LSP_K2 Posted November 30, 2021 Share Posted November 30, 2021 1 minute ago, Nigels modelling bench said: I am copying the BB code link and putting it in "Insert image from URL". I'm sure this is what I've done in the past? I have no idea. Hopefully someone will come along and help out. On ImageShack, I just use the "direct link" and paste it using the insert from URL function. Link to comment Share on other sites More sharing options...
modelmkr Posted November 30, 2021 Share Posted November 30, 2021 Just now, Nigels modelling bench said: Any idea what I'm doing wrong @modelmkr?? All I did was copy the URL, no [img] tag in front or end of the URL when I put it in the “insert image from URL” button. ¯\_(ツ)_/¯ Nigels modelling bench 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted November 30, 2021 Share Posted November 30, 2021 few well known pictures of the Ta-152H underside, I would move the blue on the lower leading edge further down the wing, no sharp line. Uncarina, Alain Gadbois, scvrobeson and 2 others 5 Link to comment Share on other sites More sharing options...
Nigels modelling bench Posted November 30, 2021 Author Share Posted November 30, 2021 13 minutes ago, modelmkr said: All I did was copy the URL, no [img] tag in front or end of the URL when I put it in the “insert image from URL” button. ¯\_(ツ)_/¯ THANK YOU!!!!!!!!!!!!!!!!!!!!! That works!! Out2gtcha 1 Link to comment Share on other sites More sharing options...
Nigels modelling bench Posted November 30, 2021 Author Share Posted November 30, 2021 2 minutes ago, Martinnfb said: few well known pictures of the Ta-152H underside, I would move the blue on the lower leading edge further down the wing, no sharp line. That's where my mind was taking me Martin. If they painted them in the field there would be a soft edge. Thank you. I shall remove the tape and add a white tac sausage or two. I have left the flaps bare metal and the ailerons will be blue so I'm sorted. Nige Uncarina, Out2gtcha and Martinnfb 3 Link to comment Share on other sites More sharing options...
Nigels modelling bench Posted November 30, 2021 Author Share Posted November 30, 2021 5 minutes ago, Martinnfb said: few well known pictures of the Ta-152H underside, I would move the blue on the lower leading edge further down the wing, no sharp line. What on earth happened to this old girl.. She looks a right ol mess!! Out2gtcha 1 Link to comment Share on other sites More sharing options...
