Some quick phone pics of progress:
The Tamiya/Trumpeter intakes are about finished. I used an off-white and dirtied the lower inside of the intakes a little.
F110s are courtesy of Chris (Zacto)... beautiful work from Chris as usual...
Aires exhausts... parts are dry-fitted and not correctly aligned, yet:
The forward fuselage is assembled... will require a lot of work to get to get it to look clean.
Red Fox on Avionix D pit.
Cheers,
Marcel
  • 4 months later...
Phew, it's been December since I last updated this thread. Things have been a little upside-down on my end but I have been progressing with the Cat.
The basic fit of this kit can really be a challenge:
Nothing too difficult to handle, it just soaks up a lot of time. The underside is in generally good shape now:
Wings are on.
Getting them to fit well is a challenge, I don't like seeing wing/fuselage gaps where there aren't any on the real thing, so I've spent a bunch of time shimming and sealing.
Fixing this gap is the toughest challenge (same on the Trumpeter F-14, btw):
I carefully ran UHU two-component glue into the gap (after masking the surrounding areas), this is about as tight as I can get that gap to be. The next F-14 I build (which will again be the Tamiya kit) I'll need to figure out a different approach.
I should be able to glue the nose on in the next few days, can't wait!
Cheers,
Marcel
  • 5 weeks later...
I'm not doing very well with keeping this WIP going... but I am making good progress on the Cat, it's a huge amount of work but I happen to have a lot of time on my hands right now.
Here's an overview of the underside:
I made good use of the various Archer raised details, in this case the latches:
Archer micro-welds used on the Tamiya external tanks:
Before masking them, I did the carbon fibre engine shrouds by mixing Vallejo metallic colors with Tamiya acrylics and working with a screen to get the textured look... then a thick coat of satin varnish to get a plastic-like look (ignore the white dust particles):
Here's what the top looks like now:
Getting ahead with the dark brown splinter. Note "washed off" leading edges.
Cheers,
Marcel
23 minutes ago, GMK said:
Lovely work, Marcel! A pleasure to watch.
Thanks!
I should have posted these images of the exhaust shroud. Hex bolts were drilled out and filled with tiny Aluminum tube sections... huge thanks to Kai W. for the tip.
1 hour ago, Marcel111 said:
Thanks!
:blink:
That's alot of work but the result speaks for itself.
Very convincing :clap2:
Coming along real nice. As I said few months back, I could not find any reference on this jet showing it top side. I google until it said enough! :D So, would you be willing to share what, where, and how you found this temporary scheme reference? TiA.
Mike
Thanks guys!
Mike, there is quite a bit of speculation involved with the camo in the top/center section, but it's a temporary scheme so I'm fine with that.
Cheers,
Marcel
Got the dark brown splinter shade on, for the most part:
Vertical stabs are just dry-fitted:
Note tight wing/glove seal on pic below... that took a lot of work. I think it's possible to build an excellent Tomcat with the Tamiya kit, but you'll have to invest a huge amount of time in basic model building to get you there.
Cheers,
Marcel
