dodgem37 Posted November 6, 2021 Share Posted November 6, 2021 Fantastic presentation. Sincerely, Mark Seversky 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted November 7, 2021 Share Posted November 7, 2021 This is masterclass! Thanks for sharing! Awesome Cheers Alan Seversky 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted November 7, 2021 Share Posted November 7, 2021 On 11/5/2021 at 10:38 AM, Seversky said: Painted the fuel tank and pylon with primer. Hi. Continued Master Class work! One thing you might check, although it's variable, is whether or not your subject has the vertical fin on the fuel tank. Many don't, just like the American Air Force and Navy F-5E/F's, like this pic below. Easy fix to delete if want to. Taiwan F-5F Cheers, Chuck Seversky 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted November 7, 2021 Share Posted November 7, 2021 Looking at the rivets, do you trim off the internal ends of the rivet once they're installed? Just thinking about the rear end where the exhaust cans will have to fit in. Matt Seversky 1 Link to comment Share on other sites More sharing options...
Seversky Posted November 7, 2021 Author Share Posted November 7, 2021 40 minutes ago, chuck540z3 said: Hi. Continued Master Class work! One thing you might check, although it's variable, is whether or not your subject has the vertical fin on the fuel tank. Many don't, just like the American Air Force and Navy F-5E/F's, like this pic below. Easy fix to delete if want to. Taiwan F-5F Cheers, Chuck Thanks for the suggestion, but my prototype carried a large tank with a vertical fin. In your photo there is a small fuel tank. Paul in Napier, chuck540z3, Iain and 2 others 5 Link to comment Share on other sites More sharing options...
Seversky Posted November 7, 2021 Author Share Posted November 7, 2021 35 minutes ago, scvrobeson said: Looking at the rivets, do you trim off the internal ends of the rivet once they're installed? Just thinking about the rear end where the exhaust cans will have to fit in. Matt Yes, I trim off the internal ends of the rivet once they're installed. After processing the seamy side the engine pipes fit in. scvrobeson 1 Link to comment Share on other sites More sharing options...
Seversky Posted November 7, 2021 Author Share Posted November 7, 2021 Wheel bays. Very good, but some work needs to be upgrade. Greg W, Landrotten Highlander, dodgem37 and 2 others 5 Link to comment Share on other sites More sharing options...
Seversky Posted November 7, 2021 Author Share Posted November 7, 2021 Details of wheel bays, landing gear struts and air brakes. MaxIt, LSP_Kevin, Paul in Napier and 6 others 9 Link to comment Share on other sites More sharing options...
Seversky Posted November 7, 2021 Author Share Posted November 7, 2021 Assembled it all without glue. scvrobeson, Iain, chuck540z3 and 16 others 19 Link to comment Share on other sites More sharing options...
dodgem37 Posted November 7, 2021 Share Posted November 7, 2021 Great show! Love what you're doing. What is the dark grey connector? How did you make those? Thank you. Sincerely, Mark Starfighter, LSP_Kevin, Rainer Hoffmann and 5 others 7 1 Link to comment Share on other sites More sharing options...
Seversky Posted November 7, 2021 Author Share Posted November 7, 2021 (edited) 30 minutes ago, dodgem37 said: Great show! Love what you're doing. What is the dark grey connector? How did you make those? Thank you. Sincerely, Mark These are the products of the ResKit company. https://reskit.com.ua/index.php?route=product/search&search=RSU32-0035&description=&category_id=0&sub_category= The connectors are glued with super glue. I drilled the connectors from the end with a 0.3mm drill and inserted the wire. Edited November 7, 2021 by Seversky Isar 30/07, Paul in Napier, Landrotten Highlander and 7 others 9 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted November 7, 2021 Share Posted November 7, 2021 Fantastic detailing in the wheel bays. Extremely crisp and clean work. Keep it up Matt Seversky 1 Link to comment Share on other sites More sharing options...
Iain Posted November 7, 2021 Share Posted November 7, 2021 Lovely work - going to be a stunner! Iain Seversky 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 8, 2021 Share Posted November 8, 2021 Great work! Seversky 1 Link to comment Share on other sites More sharing options...
alain11 Posted November 8, 2021 Share Posted November 8, 2021 Oh !!! I like this kind of details !!!!!!! very well done !!!!!!!! thank you for the link , I didn't know these "Reskit " items , it's very useful Alain Seversky 1 Link to comment Share on other sites More sharing options...
