Scotsman Posted October 17, 2021 Share Posted October 17, 2021 Great work Mark, how was the underwing / fuselage join for you , I had to spend a few sessions to fil and seal the joint - bit of a pain , but just about there now mark31 1 Link to comment Share on other sites More sharing options...
mattcour Posted October 17, 2021 Share Posted October 17, 2021 Looks soooo good! The nozzle is spectacular, so is the afterburner ring. Wonderful progress!! I'm not sure if this has been asked here but, will this be in gray or splinter scheme? mark31 1 Link to comment Share on other sites More sharing options...
frank83 Posted October 17, 2021 Share Posted October 17, 2021 Wow look at that!!! This is huge and becoming a supermodel mark31 1 Link to comment Share on other sites More sharing options...
mark31 Posted October 17, 2021 Author Share Posted October 17, 2021 20 hours ago, Stokey Pete said: Good heavens, you’ll have that finished over the weekend then….. Outstanding work there sir! not going that fast give me another month and then it will be almost finnishd i think 16 hours ago, Out2gtcha said: Just a WONDERFUL update Mark! I cant wait to get my copy, but it looks like you should have this one wrapped up by next weekend. Well done! Thanks but next week there will be no building time 2 long days at work and the wife needs surgery on wensday so changing plans over here 15 hours ago, Kagemusha said: Absolutely fantastic, such a pleasure to follow along, thanks Mark! thank you 8 hours ago, Scotsman said: Great work Mark, how was the underwing / fuselage join for you , I had to spend a few sessions to fil and seal the joint - bit of a pain , but just about there now will take a look but so far so good only problem i have seen is the gap between the wing and the after feuselage. will take a pic when i get there but i think with a bit off evergreen and putty it will be good 3 hours ago, mattcour said: Looks soooo good! The nozzle is spectacular, so is the afterburner ring. Wonderful progress!! I'm not sure if this has been asked here but, will this be in gray or splinter scheme? thanks and i will go for splinter i have the masks but i whas thinking about the nmf 3 hours ago, frank83 said: Wow look at that!!! This is huge and becoming a supermodel thank you and i do my best. Mark Out2gtcha 1 Link to comment Share on other sites More sharing options...
IvanVasili Posted October 17, 2021 Share Posted October 17, 2021 All has been said already but I just wanted to add myself how good it looks. The details look amazing and you are doing full justice to this kit. Looking forward to see it finished mark31 1 Link to comment Share on other sites More sharing options...
Paramedic Posted October 17, 2021 Share Posted October 17, 2021 The arse-end looks pretty darned good! As does the rest.. mark31 1 Link to comment Share on other sites More sharing options...
Violator1991 Posted October 17, 2021 Share Posted October 17, 2021 So well and fast progress. Looks fantastic! mark31 1 Link to comment Share on other sites More sharing options...
Phartycr0c Posted October 17, 2021 Share Posted October 17, 2021 (edited) Impressive, very very impressive. looks great now it will look superb when its finished. Keep up the great work! Edited October 17, 2021 by Phartycr0c mark31 1 Link to comment Share on other sites More sharing options...
Scotsman Posted October 18, 2021 Share Posted October 18, 2021 Quote will take a look but so far so good only problem i have seen is the gap between the wing and the after feuselage. will take a pic when i get there but i think with a bit off evergreen and putty it will be good That sounds about right , just finished doing that on my one , I just shot a coat of primer over most of the joins and it seems ready to head to the paint shedin a day or so mark31 1 Link to comment Share on other sites More sharing options...
mark31 Posted October 23, 2021 Author Share Posted October 23, 2021 so here we are with a small update i haddend much time this week to build. The wife in the hospital for surgery on the knee and just back home. So what happend on this one the wings are on and for size its a A3 cutting mat the fit off the wings need work so already put some putty on and start sanding. Still needs more work lik scribbing but first im going to put some primer on to see where it needs more work Only didt sanding an putty on the top side so far a vieuw on the underside Im planning to use some evergreen to fill the big gaps and some putty. I didt my best to get the fit so good i can get but this area whas a no go beter Thats it for now. Im hoping to have a bit more bench time but will see how things go here at home Mark Fanes, Piero, Out2gtcha and 20 others 23 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted October 23, 2021 Share Posted October 23, 2021 Great update. Mark. And that beast is big! I hope all is well with your wife. Cheers Rainer mark31 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted October 23, 2021 Share Posted October 23, 2021 That is a substantial piece of kit. Looks like it's going together quickly, and shouldn't need too much work to go together. Keep up the great work Mark! Matt mark31 1 Link to comment Share on other sites More sharing options...
Phartycr0c Posted October 23, 2021 Share Posted October 23, 2021 (edited) Hope your good lady is back on her feet soonest! Spot On with the Viggen! This work just makes me want my copy even more! Edited October 23, 2021 by Phartycr0c mark31 1 Link to comment Share on other sites More sharing options...
JMcD Posted October 24, 2021 Share Posted October 24, 2021 Details appear better after priming, good progress! mark31 1 Link to comment Share on other sites More sharing options...
crobinsonh Posted October 24, 2021 Share Posted October 24, 2021 Fantastic work - could I suggest that you use scrap resin cut to size to fill the gaps. I have done that previously and found it east to work with and to get good results when combined with super glue. mark31 1 Link to comment Share on other sites More sharing options...
