navyjet Posted August 28, 2021 Share Posted August 28, 2021 It's model I've started a few years ago. It's 1:14 scale made of aluminium and I'm going to try to make it as close as possible as the real plane. Out2gtcha, Coneheadff, JMcD and 15 others 18 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 28, 2021 Share Posted August 28, 2021 Wow what a project! Link to comment Share on other sites More sharing options...
KiwiZac Posted August 29, 2021 Share Posted August 29, 2021 Oh my!! navyjet 1 Link to comment Share on other sites More sharing options...
navyjet Posted August 30, 2021 Author Share Posted August 30, 2021 On 8/28/2021 at 4:46 AM, Out2gtcha said: Wow what a project! Well why not Out2gtcha 1 Link to comment Share on other sites More sharing options...
navyjet Posted August 30, 2021 Author Share Posted August 30, 2021 13 hours ago, MARU5137 said: OMG... a project I look forward to. I love Skyhawk {so how big with this turn out to be in 1:14 scale please. Thank you}. It's one of my favorite planes. I don't remember exactly but it will be around 1 meter long. Link to comment Share on other sites More sharing options...
navyjet Posted August 30, 2021 Author Share Posted August 30, 2021 I did a bit more work at the intake area. I'm going to spend a lot of time at this area. It's the most complicated area of the fuselage. Derek B, Anthony in NZ, Landrotten Highlander and 10 others 13 Link to comment Share on other sites More sharing options...
navyjet Posted September 9, 2021 Author Share Posted September 9, 2021 Slow and steady, a little paint, a little bit of metal work. KiwiZac, JMcD, daveculp and 7 others 10 Link to comment Share on other sites More sharing options...
Patrick HMD Posted September 10, 2021 Share Posted September 10, 2021 On 8/29/2021 at 5:40 AM, MARU5137 said: OMG... a project I look forward to. I love Skyhawk {so how big with this turn out to be in 1:14 scale please. Thank you}. The length of the Skyhawk is a little bit over 40 feet. So you divide that by 14 and you come up with 34.285 inches long. (BIG) Simple math. Sorry, I don't do metrics, my least favorite option. My brain doesn't like to function in that mode. Be following this one. Link to comment Share on other sites More sharing options...
navyjet Posted September 10, 2021 Author Share Posted September 10, 2021 (edited) 18 hours ago, Patrick HMD said: The length of the Skyhawk is a little bit over 40 feet. So you divide that by 14 and you come up with 34.285 inches long. (BIG) Simple math. Sorry, I don't do metrics, my least favorite option. My brain doesn't like to function in that mode. Be following this one. I know how you feel I don't do feet and inches and after I popped a neuron trying to figure out if your numbers are right I got out the plans and the measuring tape and got on an online converter. So from the tip of the radome to the tip of the exhaust nozzle the model is 89cm(35,03937in) When I print out plans I don't care about what scale it is going to be. I want the bulkheads to be just the right size. Too big and they won't be stiff enough, too small and I can't put in the details. Along the line I've found out that for jets(for me) the optimum is from 100cm(39,37in) to 150cm(59,05in) total length; the Tomcat is 110cm(43,30in) from the tip of the radome to the tip of the fuel dump nozzle, from the tip of the alpha probe to the tip of the vertical fin is probably 120cm(47,24in). Edited September 10, 2021 by navyjet grammar Link to comment Share on other sites More sharing options...
Patrick HMD Posted September 11, 2021 Share Posted September 11, 2021 1 hour ago, navyjet said: I know how you feel I don't do feet and inches and after I popped a neuron trying to figure out if your numbers are right I got out the plans and the measuring tape and got on an online converter. So from the tip of the radome to the tip of the exhaust nozzle the model is 89cm(35,03937in) When I print out plans I don't care about what scale it is going to be. I want the bulkheads to be just the right size. Too big and they won't be stiff enough, too small and I can't put in the details. Along the line I've found out that for jets(for me) the optimum is from 100cm(39,37in) to 150cm(59,05in) total length; the Tomcat is 110cm(43,30in) from the tip of the radome to the tip of the fuel dump nozzle, from the tip of the alpha probe to the tip of the vertical fin is probably 120cm(47,24in). I was using wikipedia as reference. They say 40 ft. 1 1/2 in. long. Now just how accurate that is, I don't know. I've heard they are error prone at times. Thank your for your service. Link to comment Share on other sites More sharing options...
navyjet Posted September 11, 2021 Author Share Posted September 11, 2021 21 hours ago, Patrick HMD said: I was using wikipedia as reference. They say 40 ft. 1 1/2 in. long. Now just how accurate that is, I don't know. I've heard they are error prone at times. Thank your for your service. They are as accurate as I am. I've said that the scale is 1:14, but if I'm doing the math to the millimeter it won't be exactly that.Things like that are not important. KiwiZac 1 Link to comment Share on other sites More sharing options...
GreyGhost Posted September 13, 2021 Share Posted September 13, 2021 Awesome Scooter build! A-4's 4-Ever! -Gregg navyjet 1 Link to comment Share on other sites More sharing options...
navyjet Posted September 19, 2021 Author Share Posted September 19, 2021 More progress on this section of the fuselage. D.B. Andrus, JMcD, KiwiZac and 6 others 9 Link to comment Share on other sites More sharing options...
navyjet Posted September 28, 2021 Author Share Posted September 28, 2021 Almost ready for some paint. Rainer Hoffmann, Anthony in NZ, Greg W and 5 others 8 Link to comment Share on other sites More sharing options...
Flight Line Media Posted September 29, 2021 Share Posted September 29, 2021 Nice progress! I look forward to seeing this build completed. Link to comment Share on other sites More sharing options...
