Coolie Posted February 10, 2006 Share Posted February 10, 2006 I have a little bit of a warp in my Zero Fuse and it could be a bit of work to me to fix as its in the fuse top ahead of the canopy...Ordinarily I would just get in there and fill/sand the hell out of it (Good old Aussie bl@#dy make it fit)... Anyone have any nice easy methods they would like to share with me to cure the warp? I might try and take some detail shots with the new camera...see if I can show what I mean Link to comment Share on other sites More sharing options...
titan Posted February 10, 2006 Share Posted February 10, 2006 Hair Dryer. Set it on really hot and hold fairly close to the warped part (8-10cm) for about 30 seconds. Try bending. Repeat as necessary. Try to hold the plastic far enough away from the heated area that you don't cause additional deformations with your fingers. If you must touch the heated area (rather than simply twist surrounding plastic) try to only touch the area on the side that won't be visible. Or just be gentle and you should have no problem. Link to comment Share on other sites More sharing options...
LSP_Ray Posted February 11, 2006 Share Posted February 11, 2006 Best to dunk it in cold water once you get it in the shape you want it also. If you let it cool gradually it may warp back. Link to comment Share on other sites More sharing options...
Coolie Posted February 11, 2006 Author Share Posted February 11, 2006 alright, ill have to borrow a hair dryer heehee Link to comment Share on other sites More sharing options...
