justplanecrazy Posted May 5, 2021 Share Posted May 5, 2021 Would the spark plugs really be visible on P & W R-2800? I have been tempted to get the ANYZ spark plugs but it seems to me they would have been covered by some kind of boot or tube for anti-static purposes. After all, I can't see the spark plugs on my car and these plugs have to perform in MUCH harsher conditions. Any input would be greatly appreciated. Thanks, Mark Link to comment Share on other sites More sharing options...
Derek B Posted May 5, 2021 Share Posted May 5, 2021 The front cylinder plugs are... Derek LSP_K2 and rafju 1 1 Link to comment Share on other sites More sharing options...
justplanecrazy Posted May 5, 2021 Author Share Posted May 5, 2021 Thanks Derek Derek B 1 Link to comment Share on other sites More sharing options...
JeepsGunsTanks Posted May 5, 2021 Share Posted May 5, 2021 52 minutes ago, Jennings Heilig said: What flavor of R2800 is that in the photo!?!? I've never seen a single one with the P&W logo on top of the reduction gear case like that. And where are the magnetos? Is it even an R2800? I dont think it is... Derek B 1 Link to comment Share on other sites More sharing options...
rjones726 Posted May 6, 2021 Share Posted May 6, 2021 I think the photo Derek posted is an R-1830 Derek B 1 Link to comment Share on other sites More sharing options...
Theo Posted May 6, 2021 Share Posted May 6, 2021 It is an R-1830, used in the B-24, the C-47 and Wildcat. Derek B 1 Link to comment Share on other sites More sharing options...
Finn Posted May 6, 2021 Share Posted May 6, 2021 Here is one with labels for the parts: Jari Derek B and MikeMaben 1 1 Link to comment Share on other sites More sharing options...
Dpgsbody55 Posted May 6, 2021 Share Posted May 6, 2021 It depends on how much of the engine you want to display. All 36 plug leads, plus the leads from the magnetos, are visible from the front, but the plugs on the back of each cylinder disappear as they pass through the cooling tins. If you're doing a model with no removable cowlings, then it's only the front view you have to contend with. If, like me, you like to have the cowlings off, then it gets more complicated. I recently finished the engine on the Tamiya Corsair, and that was a bit of a juggle of parts to thread the plug leads through the cooling tins and into the back of the cylinders. For those, I glued the plug leads into the cylinders first, then through the tins as I fitted those, then into the plug lead ring on the front of the engine. It's just time and patience, and if you get tangled up, put it down and come back to it later. Cheers, Michael Derek B 1 Link to comment Share on other sites More sharing options...
Derek B Posted May 6, 2021 Share Posted May 6, 2021 7 hours ago, Jennings Heilig said: What flavor of R2800 is that in the photo!?!? I've never seen a single one with the P&W logo on top of the reduction gear case like that. And where are the magnetos? 6 hours ago, rjones726 said: I think the photo Derek posted is an R-1830 Yes, you are correct - I just 'Wikki'ed R-2800 and selected an image without really looking at it too closely, which is normally not like me at all! (however, it still serves to illustrate the principle that spark the plugs can at least still be seen on the front row of cylinders, even if the engine is a different one! ). Derek rjones726 and LSP_K2 2 Link to comment Share on other sites More sharing options...
