1 hour ago, Hawkwrench said:
So just run the needle around the inside of the circle on the template???
Tim
Yep! Just tape the template down firmly so that it's less likely to move. You'll also have to press it down with your fingers, as the needle will really want to push it out of place as it goes around. The thicker the styrene, the less successful this method tends to be, and you need to focus on keeping the tool as vertical as possible. Start lightly and try not to dig the needle in with too much pressure. Tricky, but it works pretty well given the right conditions.
Kev
Another technique for creating circles of this size is to bevel appropriately sized brass tubing to a sharp edge, creating a metal punch that can be struck into the sheet of plastic with a hammer.
That's a good idea.
I'll try Kevin's and your idea each.
Tim
another way , however a little bit expensive ( you can find it to different price ), but very useful to cut even very small circle , that works on thin plastic sheet too ...... find it
Alain
Alain
For the price of this a Cricut or Silhouette cutter is not that much more expensive and they are much more versatile.
hi
you are right , the " Silhouette cutter is way more " versatile " . If I  dare to say , the limit , is your imagination , but its prise is from 150 Euros to 250 Euros more or less :hmmm:
" my" tool  , is .......25 to 66 Euros .....more or less , but............. we are limited to cutting only ...... circles :whistle:
