Ayovan Posted March 28, 2021 Share Posted March 28, 2021 Thinking about picking up one of these. I always liked the Meteor. Since I have never built anything from HK, I looked at a couple reviews that were favorable. Has anyone here built one? Any advice, and or cautions about the kit? I saw that Eduard has a lot of am for this kit. Thanks, Andy Link to comment Share on other sites More sharing options...
thierry laurent Posted March 28, 2021 Share Posted March 28, 2021 Good kit but the air intakes look weird and the front of the engines is very basic. To be honest this looks like a kit that was designed by one guy and ended by another one who rushed the job for the details. Ayovan and Grunticus 2 Link to comment Share on other sites More sharing options...
Ali62 Posted March 28, 2021 Share Posted March 28, 2021 It looks like a Meteor, and the ones I have seen built do look quite good, but it is not accurate, there is a lot wrong with it, BUT if you want a Meteor then build and enjoy it by adding some additional bits, I am sure it will look great. Ayovan 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 28, 2021 Share Posted March 28, 2021 I built one of the test shots just before it was released: Kev Phartycr0c, dutik, Dany Boy and 4 others 6 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted March 28, 2021 Share Posted March 28, 2021 It's a bummer that Fisher is gone now, and no one else picked up the plan for corrected intakes for the Meteor. The HK ones are a bit blunt. Matt Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 28, 2021 Share Posted March 28, 2021 7 minutes ago, scvrobeson said: It's a bummer that Fisher is gone now, and no one else picked up the plan for corrected intakes for the Meteor. The HK ones are a bit blunt. I've got a couple more kits in the stash, and will use the Fisher nacelle set with one of them. Some day! Kev scvrobeson 1 Link to comment Share on other sites More sharing options...
Ayovan Posted March 28, 2021 Author Share Posted March 28, 2021 1 hour ago, Ali62 said: It looks like a Meteor, and the ones I have seen built do look quite good, but it is not accurate, there is a lot wrong with it, BUT if you want a Meteor then build and enjoy it by adding some additional bits, I am sure it will look great. There doesn't appear to be any other 1/32 offerings of a Meteor available. So if I want a Meteor this looks to be my only choice. Link to comment Share on other sites More sharing options...
Ayovan Posted March 28, 2021 Author Share Posted March 28, 2021 1 hour ago, LSP_Kevin said: I built one of the test shots just before it was released: Kev I really like that Argentinian AF paint. Much more colorful than the RAF camo I was thinking about. Dany Boy 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted March 29, 2021 Share Posted March 29, 2021 55 minutes ago, Ayovan said: I really like that Argentinian AF paint. Much more colorful than the RAF camo I was thinking about. It is always kind of funny to me to see a British jet in Argentine colors given the, let's say, fractious relationship between the two. Matt Shoggz and nmayhew 1 1 Link to comment Share on other sites More sharing options...
Ayovan Posted March 29, 2021 Author Share Posted March 29, 2021 (edited) 5 hours ago, thierry laurent said: Good kit but the air intakes look weird and the front of the engines is very basic. To be honest this looks like a kit that was designed by one guy and ended by another one who rushed the job for the details. Looking at some photos, the intakes are really blunt. Look like they ran head first into a concrete wall. According to the reviews that I read there are no engines in the kit. Just a bulkhead type block off that represents the front of a Whittle engine. No mention of the tail pipe. Even still, I think I can live with that. Maybe I can come up with a plan for the intakes, or try and hunt down some Fisher ones. I heard of someone that might have a set. Edited March 29, 2021 by Ayovan Link to comment Share on other sites More sharing options...
Dpgsbody55 Posted March 29, 2021 Share Posted March 29, 2021 (edited) I've built two of these, though the last one was built as a T.7 using the Fisher conversion kit. It's a nice kit if a little simple, but it does come with a nose weight supplied to keep it from being a tail sitter. However, I shove a little more lead under the cockpit floor, just to be sure. The cockpit is good, but could use some enhancement, and as has been pointed out, engine detail is poor. This is the worst aspect of the kit in my opinion, but can be improved thanks to an upgrade kit from Profimodeller. http://www.profimodeller.com/detail/p32191-engine-bay-engine-gm/ Here's what it looks like when built up. And in place: The T.7 had two of these installed, but one will do the trick if you're OK with that. I'm very pleased with both builds, and you can find a WIP on both on this site. Recommended. Hope this helps, Michael Edited March 29, 2021 by Dpgsbody55 Dany Boy, crobinsonh, jgrease and 4 others 6 1 Link to comment Share on other sites More sharing options...
Ayovan Posted March 29, 2021 Author Share Posted March 29, 2021 24 minutes ago, Dpgsbody55 said: I've built two of these, though the last one was built as a T.7 using the Fisher conversion kit. It's a nice kit if a little simple, but it does come with a nose weight supplied to keep it from being a tail sitter. However, I shove a little more lead under the cockpit floor, just to be sure. The cockpit is good, but could use some enhancement, and as has been pointed out, engine detail is poor. This is the worst aspect of the kit in my opinion, but can be improved thanks to an upgrade kit from Profimodeller. http://www.profimodeller.com/detail/p32191-engine-bay-engine-gm/ Here's what it looks like when built up. And in place: The T.7 had two of these installed, but one will do the trick if you're OK with that. I'm very pleased with both builds, and you can find a WIP on both on this site. Recommended. Hope this helps, Michael Thank you Michael. Those engines look great. Looks like a must have add-on for this kit. I'll go hit up you're wip threads for sure. Andy Dpgsbody55 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted March 29, 2021 Share Posted March 29, 2021 Profi engines are nice but lack a lot of very visible components. Globally all hoses connected to the engine are missing. Two huge ones covered by tape were normally located on each side of the top, from mid to rear sections. It is not that easy to find good pictures of them. So have a look at the 1/48 Airfix kit on Scalemates. Ayovan 1 Link to comment Share on other sites More sharing options...
iaf-man Posted March 29, 2021 Share Posted March 29, 2021 Not the best but...I promise to get better next time :-) Dany Boy, jgrease, Uncarina and 3 others 5 1 Link to comment Share on other sites More sharing options...
RLWP Posted March 29, 2021 Share Posted March 29, 2021 A Rolls Royce Derwent kit - how cool! With a bit of artistic license you could make a runway snowblower My Artistic License has points on it...* Richard *UK joke Ayovan, MikeC, mozart and 2 others 3 2 Link to comment Share on other sites More sharing options...
