mark31 Posted March 25, 2021 Share Posted March 25, 2021 Can i build the tamiya F-16 block 50 and make it a block 40? so far my research say yes but maybe im wrong Any advice will be welcome Thanks Mark Derek B and Mel 2 Link to comment Share on other sites More sharing options...
Derek B Posted March 25, 2021 Share Posted March 25, 2021 From what I can see Mark, yes (most of the changes will probably be confined to the cockpit and stores). https://www.f-16.net/ Derek mark31 1 Link to comment Share on other sites More sharing options...
ziggyfoos Posted March 25, 2021 Share Posted March 25, 2021 Yes, pretty easy. New HUD and stiffening plates (Cross Delta makes some nice ones) Here's a good lowdown on how to make other blocks with Tamiya kits: http://www.clubhyper.com/reference/f16blockssb_1.htm mark31, Derek B, Kagemusha and 2 others 4 1 Link to comment Share on other sites More sharing options...
mark31 Posted March 25, 2021 Author Share Posted March 25, 2021 Thanks then I build a block 40 Will take a look for the stifner plates Marl Derek B 1 Link to comment Share on other sites More sharing options...
ziggyfoos Posted March 25, 2021 Share Posted March 25, 2021 (edited) Here's the 1/32 plates: https://spruebrothers.com/cxdcd32001-1-32-crossdelta-f-16c-falcon-stiffener-plates-for-block-25-30-32-40-42/ Also for the WAR HUD, I believe the Academy kit comes with one and Wolfpack also has(had?) made them. Edited March 25, 2021 by ziggyfoos Derek B, Out2gtcha, mark31 and 1 other 3 1 Link to comment Share on other sites More sharing options...
mark31 Posted March 25, 2021 Author Share Posted March 25, 2021 7 hours ago, ziggyfoos said: Here's the 1/32 plates: https://spruebrothers.com/cxdcd32001-1-32-crossdelta-f-16c-falcon-stiffener-plates-for-block-25-30-32-40-42/ Also for the WAR HUD, I believe the Academy kit comes with one and Wolfpack also has(had?) made them. The plan wil be a bird from turkish air force so i dondt know iff the have the war hud i already have the tail so getting closer thanks for the info and link Mark Link to comment Share on other sites More sharing options...
Derek B Posted March 25, 2021 Share Posted March 25, 2021 (edited) I make Hellenic Air Force F-16s, so one thing to bear in mind for your Turkish version is that the aircraft of both air forces have the fin extension which houses the brake chute (maybe with antenna). Some TuAF F-16C Block 40 aircraft don't have the brake chute housing, so you may be OK Cheers Derek Edited March 25, 2021 by Derek B mark31 and mattcour 2 Link to comment Share on other sites More sharing options...
mark31 Posted March 25, 2021 Author Share Posted March 25, 2021 2 minutes ago, Derek B said: I make Hellenic Air Force F-16s, so one thing to bear in mind for your Turkish version is that the aircraft of both air forces have the fin extension which houses the brake chute. Cheers Derek i have one underway Mark Derek B and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Derek B Posted March 25, 2021 Share Posted March 25, 2021 6 minutes ago, Derek B said: I make Hellenic Air Force F-16s, so one thing to bear in mind for your Turkish version is that the aircraft of both air forces have the fin extension which houses the brake chute (maybe with antenna). Some TuAF F-16C Block 40 aircraft don't have the brake chute housing, so you may be OK Cheers Derek 4 minutes ago, mark31 said: i have one underway Mark Excellent! Derek mark31 1 Link to comment Share on other sites More sharing options...
mattcour Posted March 25, 2021 Share Posted March 25, 2021 You may have to take care of the ECM antennae on boths sides of the intake and the chute housing. mark31 and Derek B 2 Link to comment Share on other sites More sharing options...
mark31 Posted March 26, 2021 Author Share Posted March 26, 2021 7 hours ago, mattcour said: You may have to take care of the ECM antennae on boths sides of the intake and the chute housing. working on it tail is underway and the ecm antenna not to hard to make i think so that will be good Mark mattcour and Derek B 2 Link to comment Share on other sites More sharing options...
Hrvoje Posted March 27, 2021 Share Posted March 27, 2021 (edited) Did anyone use this on the Tamiya kit, does it fit ok? Edited March 27, 2021 by Hrvoje Edited the image link Link to comment Share on other sites More sharing options...
