Marcel111 Posted March 4, 2021 Author Share Posted March 4, 2021 (edited) Jari, scroll down a little to see a nice pic of a VA-65 jet loaded with 12x Mk.20's: http://rickmorganbooks.com/intruders.html Here are some quick and dirty iPhone pics of progress. Intakes are fully on with engine installed also. This time around I used two-component epoxy to glue the weights to the nose, every time I use super glue the weight seems to come unstuck after a while which would be bad in the large A-6 nose-cone. A look down the intake... note the BIG J-52 :-). The step before the engine is actually there, just hard to see in this nasty pic. Everything packed into the fuselage. Note the additional supports for the exhausts, don't want those to break off as I push the rearmost sections on at the end of the build. And here she is, right side up. Very little work to do here other than that seam on the nose... but that is also very sraight-forward. Here's what the IP looks like, under a lot of magnification. I also modified the instrument coaming pretty substantially. There's still a lot of work to do here but I won't be spending more time on the cockpit until right at the end of the build... as it is it will be a miracle if the cockpit remains intact throughout the rest of the build, it's incredible how high up and hence exposed the A-6 cockpit was... thereby giving the pilot an outstanding view. Also note that I scratchbuilt the B/N lightbox... pics such as the one below show that this was installed on "500" during Desert Storm. (Pic is marked as free to use): Cheers, Marcel Edited March 4, 2021 by Marcel111 chuck540z3, Hartmann352, Isar 30/07 and 17 others 20 Link to comment Share on other sites More sharing options...
allthumbs Posted March 4, 2021 Share Posted March 4, 2021 Coming along great Marcel...cockpit looks amazing! Are you planning folded wings on this one? Marcel111 and phasephantomphixer 2 Link to comment Share on other sites More sharing options...
chuck540z3 Posted March 4, 2021 Share Posted March 4, 2021 Sweet cockpit Marcel! Very, very nice. Cheers, Chuck Marcel111 1 Link to comment Share on other sites More sharing options...
Finn Posted March 4, 2021 Share Posted March 4, 2021 Marcel some more images of Mk-20 Rockeyes are here: https://catalog.archives.gov/search?q=Mark 20 Rockeye&rows=20&f.materialsType=photographsandgraphics you can zoom in on them to get details, of note the body has thermal coating on it, the nose section and tail don't: Jari Marcel111, Starfighter, chuck540z3 and 1 other 4 Link to comment Share on other sites More sharing options...
Marcel111 Posted March 5, 2021 Author Share Posted March 5, 2021 18 hours ago, allthumbs said: Coming along great Marcel...cockpit looks amazing! Are you planning folded wings on this one? Thanks! I'll be folding the wings since it's more appropriate with the cockpit open on a carrier deck... will also save a bunch of display space and I also think Intruders just look cooler that way. Jari, I had downloaded all of those pics but had never noted the thermal body, you have quite the eagle eye! Not sure how I will model that since it is very fine but for sure there won't be a glossy shine on the main sections of the Mk.20's. Cheers, Marcel Greg W, phasephantomphixer and A-10LOADER 3 Link to comment Share on other sites More sharing options...
mattcour Posted March 5, 2021 Share Posted March 5, 2021 Gret work, the cockpit look spectacular. And yes, it will have definitely look better with folded wings for sure! Marcel111 1 Link to comment Share on other sites More sharing options...
Finn Posted March 5, 2021 Share Posted March 5, 2021 Marcel, in case you have access to a 3D printer, here is one in 1/10th scale (just rescale it to 1/32 when printing): https://cults3d.com/en/3d-model/game/1-10th-scale-mk-20-rockeye-ii-cbu-100 the body can be printed separately and the printing process may give you the rough texture needed. Jari Marcel111 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted March 5, 2021 Author Share Posted March 5, 2021 31 minutes ago, Finn said: Marcel, in case you have access to a 3D printer, here is one in 1/10th scale (just rescale it to 1/32 when printing): https://cults3d.com/en/3d-model/game/1-10th-scale-mk-20-rockeye-ii-cbu-100 the body can be printed separately and the printing process may give you the rough texture needed. Jari I'm committed to using the Eduard Brassin Mk20's, they are beautifully done and I have already spent a bunch of time cleaning them up. If you look at a pic at 1/32 scale on the screen I think the effect is so subtle that I think a clear flat coat will suffice. Cheers, Marcel phasephantomphixer and Greg W 2 Link to comment Share on other sites More sharing options...
themongoose Posted March 5, 2021 Share Posted March 5, 2021 6 minutes ago, Marcel111 said: I'm committed to using the Eduard Brassin Mk20's, they are beautifully done and I have already spent a bunch of time cleaning them up. If you look at a pic at 1/32 scale on the screen I think the effect is so subtle that I think a clear flat coat will suffice. Cheers, Marcel you know it could be worth experimenting by spraying the flat at a distance so it dries in the air some before hitting the Mk20? I’ve made extra work for myself doing this on the finish coat because of the rough surface it creates lol Would be cool if it resulted in a very mild effect for you like the fire retardant coating. Marcel111 and phasephantomphixer 2 Link to comment Share on other sites More sharing options...
Finn Posted March 9, 2021 Share Posted March 9, 2021 (edited) Hi Marcel, here is another Rockeye pic showing the thermal coating a bit better: edit: from the USS Ranger Cruise Book: https://www.navysite.de/cruisebooks/cv61-91/index_002.htm several more Mk-20 pics are there. Jari Edited March 9, 2021 by Finn A-10LOADER and Marcel111 2 Link to comment Share on other sites More sharing options...
Marcel111 Posted March 18, 2021 Author Share Posted March 18, 2021 On 3/9/2021 at 5:46 AM, Finn said: Hi Marcel, here is another Rockeye pic showing the thermal coating a bit better: https://www.navysite.de/cruisebooks/cv61-91/index_002.htm several more Mk-20 pics are there. Jari Thanks Jari! Only just noticed this post. I really thought I knew everything there is to know about Mk7 dispensers but this coating thing caught me by surprise. So huge thanks for posting these pics, it will definitely influence how I finish the dispensers. I managed to salvage my Mig-29 build so right now I'm mainly focused on getting that through the finish line, but there is some progress to show on the A-6 nonetheless. Here is where I am with the True Details seats. I think they are generally excellent, although the front of the headrest needs to be rounded a little. Only major gripe is that that no consideration was given to how the modeller will detach the seats from the molding block, you can see I damaged one of the seats in that process. I did almost all of the painting with my Olympos Micron airbrush, love how I can almost spray a hard line with that airbrush. Much more work to do on those but am happy where it's headed. I don't know how everybody else feels about it but I hate using superglue on clear parts. This time around I used UHU quick-setting two component glue, the bond is far stronger and I find it much easier to work with. Cheers, Marcel Scotsman, allthumbs, A-10LOADER and 10 others 13 Link to comment Share on other sites More sharing options...
A-10LOADER Posted March 18, 2021 Share Posted March 18, 2021 I'm late to the party, WOW, great work so far !! Love the cockpit. Steve Marcel111 1 Link to comment Share on other sites More sharing options...
Starfighter Posted March 19, 2021 Share Posted March 19, 2021 Great progress, Marcel! Marcel111 1 Link to comment Share on other sites More sharing options...
allthumbs Posted March 19, 2021 Share Posted March 19, 2021 Seats look great...and the airbrush application of paints seems to have made a difference in preserving/accenting all of the fine details. phasephantomphixer and Marcel111 2 Link to comment Share on other sites More sharing options...
chuck540z3 Posted March 19, 2021 Share Posted March 19, 2021 Great looking seats Marcel! I hear you with not wanting to use CA glue on canopy parts, which is why I now use Gator Glue whenever I need to glue brass to clear plastic. It cleans up with water and the bond is quite good. Cheers, Chuck Greg W and Marcel111 2 Link to comment Share on other sites More sharing options...
