John Stambaugh Posted February 14, 2021 Share Posted February 14, 2021 On 2/8/2021 at 10:08 PM, LSP_Kevin said: I second the toothbrush method, but a secondary technique I use after that is to run a tiny amount of liquid cement (Tamiya Extra Thin is ideal) along the newly-scribed lines. This not only helps with dissolving any sanding detritus, but also assists in tidying up the lines a little, and helps make them look like an integrated part of the moulding, rather than scribed-in trenches. Kev I will give you extra thin tip a try. My re-scibbing is often trench like. Softening the edges would help. Thanks Link to comment Share on other sites More sharing options...
