sandbagger 3,323 Posted February 4 Share Posted February 4 (edited) Hi all, I'm now starting on the 'Wingnut Wings' 1:32 scale model of the Roland D.VIa fighter. This aircraft was unusual in that its fuselage had a fuselage clad in overlapping plywood planks, known as ’lapstrake’, which was similar to that used on clinker built boats. This proved to be as strong, but lighter than existing constructions methods provided, which was an important factor for a fighter aircraft. Also the lower wings were located under, not into, the lower fuselage. It's the Roland D.VIa, Serial No: 3615/18 during 1918 (Jasta unknown). Mike Edited February 18 by sandbagger Different aircraft Daywalker, LSP_Kevin, Alex and 9 others 12 Link to post Share on other sites
Alex 2,740 Posted February 5 Share Posted February 5 Cool! Love to see unique/off the beaten path aircraft get built here. MARU5137 1 Link to post Share on other sites
Daywalker 782 Posted February 5 Share Posted February 5 One of my favorite WWI aircraft, and really looking forward to seeing your take on this! MARU5137 1 Link to post Share on other sites
overcast 11 Posted February 5 Share Posted February 5 Perfect Nick, thats the one I want to use for my final Roland DVa kit. I hope you will have a very good .pdf instruction in the end. Will you make masks? Have fun and stay save Best Wishes Kai MARU5137 1 Link to post Share on other sites
sandbagger 3,323 Posted February 6 Author Share Posted February 6 Thanks. Kai - I've replied to your email Mike Link to post Share on other sites
MARU5137 16,111 Posted February 6 Share Posted February 6 Mike, I am excited to see another of your superb build. Daywalker 1 Link to post Share on other sites
sandbagger 3,323 Posted February 11 Author Share Posted February 11 (edited) Hi all, A few updates. I'm working on the fuselage internals and the engine. The fuselage halves were two-tone, as were the cockpit side frames. The engine bearer frame was a single colour. As I normally do, the slight weathering effect was done using the 'Flory Models' dark dirt clay wash. The rudder, elevator and ailerons control lines were added using 0.08 mm diameter mono-filament and blackened 0.4 mm diameter tubes. Other detail, such as pipes, seat harness etc will be added after the cockpit assembly is built and before closing up the fuselage. The next stage, after completing the engine is to assemble the fuselage, Mike Here's the engine. As most of the engine won't be seen, it's just the basic engine with the addition of ignition leads and the pipe at the front cylinder. The replacement exhaust pipe is from 'ReXx', Mike Edited February 11 by sandbagger olgerd83, scvrobeson, Troy Molitor and 8 others 11 Link to post Share on other sites
sandbagger 3,323 Posted February 13 Author Share Posted February 13 Hi all, Just a quick update. The cockpit structure is now complete and ready to be fitted into the closed up fuselage. I had to sand the outer surface of the two cockpit side frames and cockpit frames quite a bit, as for some reason the fuselage wouldn't close up fully with the cockpit test fitted. I know tolerances are tight, especially on WNW kits so I made sure there was no paint etc on any mating faces. Even so the gap at the underside seam of the fuselage was large, indicating something wasn't fitted correctly. Everything look correct so I'm not sure where the obstruction was - probably around the fuel tank area. Anyway, it's sorted and ready to move onto closing up the fuselage, Mike MARU5137, geedubelyer, 109 and 9 others 12 Link to post Share on other sites
Uncarina 6,119 Posted February 13 Share Posted February 13 Looking good as always! Building those WNW kits is like assembling a Swiss watch. Cheers, Tom MARU5137 1 Link to post Share on other sites
sandbagger 3,323 Posted February 13 Author Share Posted February 13 Hi all, The fuselage is now closed up with the cockpit front decking panel fitted. I'm replacing the kit supplied machine guns with resin equivalent weapons from 'GasPatch'. These needed to be modified slightly so that would fit down and into the weapon slots in the front decking panel. This required the removal of the front mounting and synchronizing cable from the underside of the breech blocks. In addition the lower part of the cocking mechanism on the right side of the left weapon was removed. Now it's onto preparing the fuselage for the application of the 'ProperPlane' wood effect decal set for this aircraft, Mike Whitey, Landrotten Highlander, MARU5137 and 6 others 9 Link to post Share on other sites
Bobs Buckles 397 Posted February 13 Share Posted February 13 Lovely work, Mike. Keep going! vB MARU5137 1 Link to post Share on other sites
geedubelyer 1,430 Posted February 14 Share Posted February 14 Those ReXx exhausts are something else and fit right in with the work you're doing Mike. Lovely stuff as usual Link to post Share on other sites
rsanz 24 Posted February 14 Share Posted February 14 Great progress and its all looking good. Just a couple of things in case you're concerned with accuracy. Despite the profile art, Schape's Jasta 33 Roland D.VI was a D.VIb (not a D.VIa), the fuselage was not unpainted clear varnished wood and the marking was some sort of lightning bolt and not an elaborate arrow. Unfortunately this is the only known photo of Schape's Roland D.VIb and it just doesn't show enough of the fuselage to confirm the marking, other than to rule out the arrow that Dan-San Abbot designed for it. Hopefully a new image will show up one day and enlighten us all. http://www.wingnutwings.com/ww/productdetail?productid=3107&cat=1 MARU5137 1 Link to post Share on other sites
Rockie Yarwood 446 Posted February 14 Share Posted February 14 Beautiful work, Mike. MARU5137 1 Link to post Share on other sites
Troy Molitor 4,187 Posted February 15 Share Posted February 15 I certainly agree. Another beautiful build going on here. The Rexx exhaust stacks do look amazing. Link to post Share on other sites
