LSP_Ray 8,483 Posted February 3 Share Posted February 3 I am curious about this new system. I assume these are not the same as the peel away carrier film type. So is the decal just the ink? And it is tough enough to transfer to the model, with adhesive just under the ink? Neat trick if so. ill have to try some. Sure would be the thing for NMF aircraft. LSP_K2 and D.B. Andrus 2 Link to post Share on other sites
Archer Fine Transfers 970 Posted February 6 Share Posted February 6 On 2/3/2021 at 5:17 PM, LSP_Ray said: I am curious about this new system. I assume these are not the same as the peel away carrier film type. So is the decal just the ink? And it is tough enough to transfer to the model, with adhesive just under the ink? Neat trick if so. ill have to try some. Sure would be the thing for NMF aircraft. No, they are not Wet Transfers like HGW sells. Same basic concept, but without the peel away film which limits the process to single objects like national insignias and the like. My primary market for them at the moment is U.S. military vehicles, but I'm working on some aircraft ideas too. LSP_Ray and CShanne 2 Link to post Share on other sites
