ivanmoe Posted January 16, 2021 Share Posted January 16, 2021 So, I'm noticing that the label on MRP clearcoats is the same as the maker's other, pre-mixed lacquers. Question... Is it safe to apply MRP's clear-coat varnishes over microscale decals? Don't want to destroy the markings trying to protect them. -Moe Link to comment Share on other sites More sharing options...
AlbertD Posted January 18, 2021 Share Posted January 18, 2021 On 1/15/2021 at 6:33 PM, ivanmoe said: So, I'm noticing that the label on MRP clearcoats is the same as the maker's other, pre-mixed lacquers. Question... Is it safe to apply MRP's clear-coat varnishes over microscale decals? Don't want to destroy the markings trying to protect them. -Moe I was wondering the same thing and will be fining out in the next day or two. I'll let you know how I do. I will be using Tamiya decals though. ivanmoe 1 Link to comment Share on other sites More sharing options...
ivanmoe Posted January 18, 2021 Author Share Posted January 18, 2021 12 hours ago, AlbertD said: I was wondering the same thing and will be fining out in the next day or two. I'll let you know how I do. I will be using Tamiya decals though. Ah, a brave man indeed. Thanks, Albert, and good luck! AlbertD 1 Link to comment Share on other sites More sharing options...
nmayhew Posted January 18, 2021 Share Posted January 18, 2021 i have applied them over various decals with no ill-effects but I have been careful to not flood the surface, and have built up coverage. i have not applied a 'wet coat' over them. suggest trying on a mule?? ivanmoe and AlbertD 2 Link to comment Share on other sites More sharing options...
AlbertD Posted January 18, 2021 Share Posted January 18, 2021 On 1/15/2021 at 6:33 PM, ivanmoe said: So, I'm noticing that the label on MRP clearcoats is the same as the maker's other, pre-mixed lacquers. Question... Is it safe to apply MRP's clear-coat varnishes over microscale decals? Don't want to destroy the markings trying to protect them. -Moe I had a bit of a setback with the MRP gloss clear. I sprayed it over Zero Paints lacquer and the clear coat went hazy. It may have been my fault for not letting the color coat dry enough. I gave it 24 hours. If that was not the issue I don't know what to say about it. It may have been my technique too. I sprayed a couple of light coats to give it something to hold on to then went with a heavier coat to give it its gloss. I've ended up stripping the paint on the parts and will give it another go but maybe with a different clear coat. BTW this is on a 1/12 motorcycle kit. Link to comment Share on other sites More sharing options...
nmayhew Posted January 19, 2021 Share Posted January 19, 2021 Just use MRP paints ? Link to comment Share on other sites More sharing options...
Woody V Posted January 19, 2021 Share Posted January 19, 2021 Decals are lacquer. MRP paints are lacquer. A match made in heaven. Link to comment Share on other sites More sharing options...
