mozart Posted May 3, 2021 Author Share Posted May 3, 2021 17 minutes ago, monthebiff said: Looking good Max, very clean build, such a pretty airframe indeed. Regards.Andy The fuselage halves took some work Andy, quite a bit of filling and sanding to get a reasonable finish. 2 minutes ago, mgbooyv8 said: Hi Max, That's looking very good! As always time well spent. Reassuring to know that lower wings with fuselage and the cabane struts with the top wing makes for a sturdy assembly. This makes life so much easier with biplanes. Keep up the good work! Cheers, Peter Yes Peter, such a contrast to my fragile handle-with-extreme-care SW Tiger Moth! mgbooyv8 and Martinnfb 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 4, 2021 Share Posted May 4, 2021 Looking good, Max! Kev mozart and Martinnfb 2 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted May 7, 2021 Share Posted May 7, 2021 On 5/4/2021 at 5:06 AM, mozart said: It's been a while, for which my apologies. The build has been progressing slowly and I know will not be finished before the GB end time (again!), but I'm pleased with the over all look of this beautiful fighter. The fuselage and lower wings are firmly glued, the top wing just resting on the cabane struts for now. The construction is very sturdy which, for a biplane model, is reassuring! The two Hawkers, with the T7 Hunter in the background are separated by what, 20 - 30 years but light years in design and complexity. That's absolutely gorgeous Max! Always love following your work...that is such a beautiful looking aeroplane Cheers Anthony Martinnfb and mozart 1 1 Link to comment Share on other sites More sharing options...
mozart Posted May 7, 2021 Author Share Posted May 7, 2021 Thanks Anthony. Seems like we’re both also interested in a thread on BM too.....different planes though! Martinnfb 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted May 10, 2021 Share Posted May 10, 2021 Excellent progress Max! The very fine surface detail is very apparent in the photos. Alain Martinnfb 1 Link to comment Share on other sites More sharing options...
mozart Posted May 16, 2021 Author Share Posted May 16, 2021 I've been trying to understand how the cryptic instructions and drawings would have you assemble the back end of the Fury.....not easy!! Fortunately when I paid a visit to Brooklands a couple of years ago I took some detailed shots of their beautiful Fury....these have saved my bacon! I had already glued the horizontal tailplane in place but that has come off so that I can now start to reconstruct how it actually should look. Pictures later hopefully if progress goes smoothly. BradG, Greg W, Trak-Tor and 2 others 5 Link to comment Share on other sites More sharing options...
mozart Posted May 16, 2021 Author Share Posted May 16, 2021 Well I'm rather pleased with the way things are going with the Fury's aft end! This shows a substitute piece which sets the height of the tailplane, the original was as straight as the dog's back leg: I had pondered for ages what these little semi-circular bits were for, they have been in my "yet to be identified" bag of parts for ages, but this morning the penny dropped! Firstly though I drilled and added "pegs" for the fin: then trial fitted the rudder, that was the "Eureka!!" moment - hinges for the lower two positions!! Alleluia...... All looking promising so far, but with the horizontal tailplane? Looks good enough to me, just a matter of carefully putting it all permanently in place now. BradG, Landrotten Highlander, Greg W and 3 others 6 Link to comment Share on other sites More sharing options...
mozart Posted May 16, 2021 Author Share Posted May 16, 2021 Good outcome, very happy with the final result Starting to look like a Fury now. The next task is to drill rigging points, then make up my mind what finish to give her. I was hoping to do a spatted version, I know that early kits were supplied with spats as an option so I wrote to Alley Cat on the off chance some might still be available to buy, but not heard a dicky bird back, which I think is a pity having spent £100+ on the kit in the first place. Civility and good manners on the other hand are free. Landrotten Highlander, Trak-Tor, BradG and 3 others 6 Link to comment Share on other sites More sharing options...
mozart Posted May 16, 2021 Author Share Posted May 16, 2021 Some of the pics of Brooklands Fury that I'm using to determine rigging points for the main wires: I'm planning to use Gaspatch turnbuckles, it's the first time I've used this type so it could prove interesting! LSP_Kevin, MDuv, Landrotten Highlander and 5 others 8 Link to comment Share on other sites More sharing options...
RLWP Posted May 16, 2021 Share Posted May 16, 2021 Too wet for gardening/golf today? That tail does indeed look very Fury Richard mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted May 16, 2021 Author Share Posted May 16, 2021 You’re absolutely right Richard, chucked it down all day! Really enjoyed my day modelling, looks like there’s more to come this week! RLWP 1 Link to comment Share on other sites More sharing options...
mozart Posted May 20, 2021 Author Share Posted May 20, 2021 (edited) An update on the Fury. The perceived wisdom with this kit is to fix the interplane struts in position, paint and then add the upper wing - who am I to question? The struts are white metal and therefore bend quite easily but getting everything to fit was quite a challenge. I'm just about there now I think, the upper wing "locks" into position in a very positive way so I hope there will be no further surprises. I've also drilled out all the location holes for the rigging turnbuckles ready for the next stage which is painting, and I STILL haven't decided on my favourite scheme, though I'm rather tempted by this one, it has a bit of everything: I love this photograph not only for the detail that it shows of the Fury, but also the characters. They are, left to right, "Prosser" Hanks, "Johnnie" Walker, "Tops" Boxer and "Teddy" Donaldson, all members of the 1937 RAF formation team. Three years later they would find themselves in action in the Battle of France flying Hurricane Mk 1s. Brilliant flyers they all were for sure, but the rigid straitjacket of aerial tactics employed by the Air Staff/RAF at the beginning of the war against the experienced Luftwaffe meant that they were very, very lucky to survive the first few days of aerial battle let alone the 6 years of war regardless of their skills. Edited May 20, 2021 by mozart BradG, KiwiZac, LSP_Kevin and 7 others 10 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 20, 2021 Share Posted May 20, 2021 Just catching back up on this one my friend.............. Lovely work! I too am really drawn to that mix of green/brown camo over yellow and NMF. Nice! Uhmmm I mean Brilliant! mozart and KiwiZac 1 1 Link to comment Share on other sites More sharing options...
mozart Posted May 20, 2021 Author Share Posted May 20, 2021 2 minutes ago, Out2gtcha said: Just catching back up on this one my friend.............. Lovely work! I too am really drawn to that mix of green/brown camo over yellow and NMF. Nice! Uhmmm I mean Brilliant! You remember then Brian! Out2gtcha 1 Link to comment Share on other sites More sharing options...
mozart Posted May 21, 2021 Author Share Posted May 21, 2021 Up on the chocks ready to receive the undercarriage: but on closer inspection whilst trying to understand how it all goes together, I see one of the wheels is imperfectly formed or damaged: I think it's not too much of a job to make and fix but, although I'm really enjoying the kit and looking forward to seeing it as part of my "stable", it's the latest in quite a long line of deficiencies that have needed to be corrected or scratch-built. Ah well, it's character forming I guess! Landrotten Highlander, scvrobeson, Alain Gadbois and 6 others 9 Link to comment Share on other sites More sharing options...
