Panzerwomble Posted December 1, 2020 Share Posted December 1, 2020 (edited) Excellent , not done a group build ever , but this gives me a great excuse to have a crack at this over the Xmas break having sat on the shelf for three months . I assume it fits within the rules ? Edited January 22, 2021 by Panzerwomble Change title mpk, Lothar, Gazzas and 10 others 13 Link to comment Share on other sites More sharing options...
BradG Posted December 1, 2020 Share Posted December 1, 2020 Yep that fits in quite well. Panzerwomble, mpk and Rockie Yarwood 3 Link to comment Share on other sites More sharing options...
Panzerwomble Posted December 9, 2020 Author Share Posted December 9, 2020 Okey dokey ...making a start . Haven't done a Luftywaffy build for ........8 years .....maybe longer, and that was a really old 1/48 kit someone bought me . I'm a bit out of touch with all of the RLM codes. Personally I always struggle with Revells way of doing paint call outs (and their paints which I don't use) , the last two LSP builds I used Tamiyas colour schemes downloaded from their instructions instead. Anyway, got the pretty much OOB pit done , and zipped into the fuselage which is a start . Not feeling the OOB decals , I really fancy (cliched though it may be ) doing Priller's Black 13 scheme from June 44 . There are plenty of references for this a/c and some Peddinghaus decals in 1/32, plus for some reason his ace of hearts 190 always had a soft spot for me as a child . On with the show ! Rockie Yarwood, mpk, BradG and 10 others 13 Link to comment Share on other sites More sharing options...
Rockie Yarwood Posted December 10, 2020 Share Posted December 10, 2020 Great start! Panzerwomble 1 Link to comment Share on other sites More sharing options...
Panzerwomble Posted December 23, 2020 Author Share Posted December 23, 2020 So , huge progress .....or maybe not . Just posting this too remind me to keep on with this one as much as anything else ! Not a lot to say , ordered some decals for Prillers 190 / Black 13, removed the moulded trim tabs to replace with thinner material later on . Got the engine build next , technically speaking to match the photos I've got I don't need it , as the panels are all in place as the plane is pushed back into a hanger , although as a model it might be nice to be able to remove them to show the engine . Decisions decisions. Also it looks like the drop tank attaches to the centreline in a different manner to the kit ... more research needed Side note - Priller sadly died of a heart attack at age 45 whilst running the family brewery in Bavaria ; his son Sebastian ( on the right below ) stills runs it . MikeC, Gazzas, BradG and 1 other 4 Link to comment Share on other sites More sharing options...
Panzerwomble Posted December 24, 2020 Author Share Posted December 24, 2020 Bit more progress , walloped the engine together . it's er Ok ..ish . I've decided to stick to the original idea so chances are this will never get seen again . KiwiZac, MikeMaben, Alain Gadbois and 9 others 12 Link to comment Share on other sites More sharing options...
Gazzas Posted December 24, 2020 Share Posted December 24, 2020 Nice work! Great pics, too! Panzerwomble 1 Link to comment Share on other sites More sharing options...
Panzerwomble Posted January 10, 2021 Author Share Posted January 10, 2021 (edited) .......& back after a little while a brief update Some progress, as predicted the engine I spent some time building , caused no end of problems when it came to attaching the cowlings and frankly will never be seen again . Slight misalignment of the mounting was the main culprit . With hindsight , I could have just built the front cylinders , would have been an easier fit and since I was 99% certain it would be covers closed........, meh . So engine in , covers on , some filling around and about but a reasonable fit. Decals from Peddinghaus arrived as well . Made a start on the basic paint , used Lifecolour.....mixed emotions on that , perhaps not as bad as some would have it , but not as good for me, as my "go to" Tamiya. I quite fancy giving MRP a go sometime but getting hold of them in the UK seems problematic. Mottling on the sides is way too pronounced as of now so going to have a rethink on that / re paint , and then I'll be using my more common techiques for blending weathering and chipping . Sorry for the low res pics , my Iphone doesn't want to perform today . Edited January 10, 2021 by Panzerwomble LSP_Kevin, themongoose, MikeC and 9 others 12 Link to comment Share on other sites More sharing options...
Juggernut Posted January 10, 2021 Share Posted January 10, 2021 (edited) Well, if it matters, Priller’s 190 wasn’t an R-2 variant and wouldn’t have the outboard 30mm cannon. It would’ve had the 20mm cannon instead (unless they were removed). The underwing details for the 30mm cannon vs. the 20mm cannon are quite different. There’s also no armor plate on the sides of the fuselage. This Revell kit is the R-2 Sturmbock aircraft which was a dedicated bomber attack aircraft equipped with additional armor plating on either side of the cockpit, additional armored glass on both the windscreen and on some R-2 aircraft, armored glass on the sides of the canopy. Additionally, the 13mm machine guns in the cowl were removed and faired over. If it doesn’t matter then carry on with the above information as a footnote for informational purposes only. Edited January 10, 2021 by Juggernut mpk and One-Oh-Four 2 Link to comment Share on other sites More sharing options...
themongoose Posted January 10, 2021 Share Posted January 10, 2021 I like the mottling so far. Looking forward to seeing you bring this home! Panzerwomble 1 Link to comment Share on other sites More sharing options...
Panzerwomble Posted January 11, 2021 Author Share Posted January 11, 2021 9 hours ago, Juggernut said: Well, if it matters, Priller’s 190 wasn’t an R-2 variant and wouldn’t have the outboard 30mm cannon. It would’ve had the 20mm cannon instead (unless they were removed). The underwing details for the 30mm cannon vs. the 20mm cannon are quite different. There’s also no armor plate on the sides of the fuselage. This Revell kit is the R-2 Sturmbock aircraft which was a dedicated bomber attack aircraft equipped with additional armor plating on either side of the cockpit, additional armored glass on both the windscreen and on some R-2 aircraft, armored glass on the sides of the canopy. Additionally, the 13mm machine guns in the cowl were removed and faired over. If it doesn’t matter then carry on with the above information as a footnote for informational purposes only. Cheers yes , I'm aware of some of the differences , I'm modelling by eye from photos rather than any huge in depth knowledge of the aircraft . The 30mm I was aware off and are not on there , & the kit comes with an unarmoured canopy , but the armour plate I can do less about . TBH the swap to a "Priller" aircraft was a little capricious & mainly because I wasn't feeling the kit offering and they were both A8's . I suppose in future it might be worth me asking all this up front on the forum before setting off with glue MikeC, Gazzas, mpk and 1 other 3 1 Link to comment Share on other sites More sharing options...
RadBaron Posted January 18, 2021 Share Posted January 18, 2021 Really nice progress! Panzerwomble 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted January 20, 2021 Share Posted January 20, 2021 On 1/11/2021 at 1:01 AM, Panzerwomble said: I suppose in future it might be worth me asking all this up front on the forum before setting off with glue Nah , build it the way 'you' want it to be . Looks fine so far Panzerwomble and mpk 1 1 Link to comment Share on other sites More sharing options...
Panzerwomble Posted January 20, 2021 Author Share Posted January 20, 2021 (edited) Greetings,... done the FW 190 . Marked up as Priller's A8 around D-Day . Lifecolour paints were ok , but very fragile , Peddinghaus decals again ok but frankly could have made my own of similar quality . Some slight discrepancies as to variant as mentioned above, but hey looks ok to me . As per the wartime pics she's quite dirty and beaten up , I reckon they were knocking out a lot of sorties a day by June 44. Also as I have recently received a Trumpeter 109, with earlier Priller markings , I'm going to keep on with the Lufty LSP theme and do this one in the same GB as well if thats ok , a "double Priller thriller" . ] Edited January 20, 2021 by Panzerwomble MikeC, Fanes, D.B. Andrus and 12 others 15 Link to comment Share on other sites More sharing options...
BradG Posted January 20, 2021 Share Posted January 20, 2021 Great work mate I will add you to the gallery. Panzerwomble 1 Link to comment Share on other sites More sharing options...
