LSP_Kevin 32,002 Posted November 28, 2020 Share Posted November 28, 2020 Clever work with the scalloping on the rudder, Eric! Kev mozart and MARU5137 2 Link to post Share on other sites
mozart 12,660 Posted November 28, 2020 Share Posted November 28, 2020 3 hours ago, LSP_Kevin said: Clever work with the scalloping on the rudder, Eric! Kev Yes, neat bit of lateral thinking there! Link to post Share on other sites
ericg 9,694 Posted December 5, 2020 Author Share Posted December 5, 2020 Some more work. There are a couple of areas of this model that need attention. The leather crash padding on the front of each cockpit is not very well moulded, with them having undercuts as part of the way the kit has been designed. There is an opportunity to make them a lot better, as they will stand out when the model is finished. I filled underneath each pad with superglue/talc mix. I also built up each one to make them a bit more prominent and then sanded them to shape. The wings have the rear seam line well forward of the trailing edge and needs lots of work to smooth down. The trailing edge of each flap is not present even before sanding, except for the fairly shallow engraving of the fuselage mounted flap (visible here). This area benefits from some careful work to bring out that detail, so once the seam was smoothed, i scribed new trailing edges for each flap, as well as running a razor saw through the edge of each aileron to better define that control surface. I have ran a pin wash into the new flap panel lines for better visibility. MikeMaben, rafju, Paul in Napier and 12 others 15 Link to post Share on other sites
Alain Gadbois 2,176 Posted December 5, 2020 Share Posted December 5, 2020 Great work on the modified rudder and the new tail wheel assembly is just brilliant! Alain Link to post Share on other sites
ericg 9,694 Posted December 10, 2020 Author Share Posted December 10, 2020 Some more work. After just finishing my heavily modified S.E.5a, I am now full steam ahead on the Magister. I didn’t like the photo etch pitot tube as it is too flat for this scale. I bent some .5mm brass rod to shape and soldered them together and then used some aluminium strip for the bottom section. I have made the pitot removable for transport. It is now far stronger and more realistic than the photo etch item. The engine is fairly nice, but as not much of it is visible, I didn’t spend too much time on it. It would certainly be a good candidate for superdetailing if the cowl was left opened. I filled the panel lines in both sides of the cowl, as the aircraft I am making had a 4 piece one instead of five. Test fitting it shows the correct way in which the cowl sits proud of the fuselage but it could do with a bit of tweaking . I thinned the rear edge of the cowl, so that the engine compartment can be seen from the rear. GDW, Victor K2, LSP_Kevin and 11 others 14 Link to post Share on other sites
ericg 9,694 Posted December 11, 2020 Author Share Posted December 11, 2020 Some more work. The cockpit access doors are softly moulded and could do with some definition. I was tempted to cut these out and position them open but resisted. i scribed down each side of the doors to define them a little better. The cowl needed a bit of work to smooth it out and get the panel lines consistent. I sanded off the original fasteners to assist with this and then replaced them with some raised surface detail decals from Archer. Once the model was primed, I painted it with Tamiya AS-12 straight from the rattle can to represent the high speed silver finish. I then painted the cowl and wheel pant extension areas with SMS Jet Black which gave a smooth gloss black surface. I then used a thinned mix of Alclad High Shine Aluminium and applied it in multiple layers to give a fairly shiny metallic surface. I will give these areas multiple coats of gloss clear and polish between coats. A sleek little aeroplane. Pretty happy with progress so far. Anthony in NZ, Rockie Yarwood, Out2gtcha and 16 others 19 Link to post Share on other sites
Anthony in NZ 5,915 Posted December 11, 2020 Share Posted December 11, 2020 Absolutely love this Eric, I have this kit and am taking lots of notes! And that S.E.5a is beyond terrific! Great work buddy MARU5137 1 Link to post Share on other sites
scvrobeson 3,473 Posted December 11, 2020 Share Posted December 11, 2020 Just burning through this build. The little tweaks really do make it look great, and bring it up to a new level. Matt Anthony in NZ 1 Link to post Share on other sites
Whitey 1,080 Posted December 11, 2020 Share Posted December 11, 2020 Looking the goods alright Eric. Link to post Share on other sites
Alain Gadbois 2,176 Posted December 12, 2020 Share Posted December 12, 2020 Looks fantastic! Excellent metallic finish! Alain Link to post Share on other sites
ericg 9,694 Posted December 13, 2020 Author Share Posted December 13, 2020 Getting closer to the finish line. I set out to use my mask cutter to fully paint all of the markings on this model but am having trouble with getting the smaller circle in the roundels correct. For some reason they are cutting out of round, so I went with the kit decals. The first of the smaller roundels broke up when I went to remove it from the backing sheet, but luckily the rest applied nicely although a fair bit of caution was used. They are very brittle but settle down great using Microsol/set. I made up a mask for the serial number and sprayed it with MRP tire rubber. I set the outer top edge of the mask so that it corresponded with the panel line running the length of the fuselage to make alignment easier on both sides. MARU5137, Rockie Yarwood, mozart and 17 others 20 Link to post Share on other sites
Simmo.b 1,159 Posted December 14, 2020 Share Posted December 14, 2020 Just found the time to see this, really nice as always mate MARU5137 1 Link to post Share on other sites
Whitey 1,080 Posted December 14, 2020 Share Posted December 14, 2020 Coming along nicely Eric. MARU5137 1 Link to post Share on other sites
ericg 9,694 Posted December 17, 2020 Author Share Posted December 17, 2020 (edited) Thanks guys. The big job of doing the windshields was always waiting for me at the end of the build and was something I was going to have to face to get this one finished. The kit comes with a farily nice front windshield but the framing is a little off, as the real aircraft does not have a framed windscreen, just a piece of perspex draped over the roll bar. The rear windshield that is contained in the kit is wrong for the earlier version of the aircraft that I am depicting, so I needed to find a solution. The great thing about modelling is that you can make it as complicated or as simple as you like, you are your own boss. By doing conversion work and scratchbuilding parts, you build up skills that can serve you well in future projects and I used a skill on this project that I had learnt on a previous one, being vac forming. I first did this when I built a new extended window for my O-2 build and was able to put the stuff I learnt to good use on this one. I started with a small section of Ureol board. I carved the shape of the windscreen, close to that of the kit part. Vac forming is a three man job, so I called 2/3rds of my compliment of kids to come and give me a hand (actually it was a way to keep them quiet and occupied for 30 minutes!!) One to hold the vac nozzle into the vac form machine, one to hit the on/off switch of the vaccum and of course that freed me up to manipulte the work piece. Its kinda cool to see this process in action. Here is a section of PETG .3mm sheet freshly formed over the winshield part. All of the parts of the vac form and frame are low-tech home made stuff. The two nice windshields. Slightly out of focus compared to the master. The pile of rejects..... I couldnt remember the succesful temperature that I used on my O-2 build, so it too a few goes of progressivley less bubbling to lower the temp to a crystal clear level. The next part of the mod was to bulid the roll bar/windshield frame. I reckon this is a pretty cool design feature that was well worth the effort. The roll bar extends right down inside the cockpit. I formed this out of 1mm brass rod and soldered the forward supports into place. I preset the angle of the supports to make it easier to hold in place whislt I soldered them together and cut them to length later. This was then inserted into some holes that I drilled into the fuselage and then the windscreen attached. This was pretty difficult to get right. As can be seen, the roll bar is quite visible insode the cockpit. I used some thin aluminum strip (the membrane inside Milo tins) to form the fairing joining the windshield to the fuselage. This was superglued into place and then burnished into place. I then painted them the AS-12 as per the fuselage. Interestingly, the rear windshield on the real aircraft is just a formed piece of plexiglass without any framing. The pic has come up a bit grainy but they both look nice and clear in person. Edited December 17, 2020 by ericg Kagemusha, rafju, Whitey and 20 others 23 Link to post Share on other sites
LSP_Kevin 32,002 Posted December 18, 2020 Share Posted December 18, 2020 Excellent work, mate! Kev Link to post Share on other sites
