jeroen_R90S Posted November 11, 2020 Share Posted November 11, 2020 (edited) First of all I'd like to point out that I've been a long-time lurker that has gotten a lot of information on large scale aircraft here and figured it might be time to send something back. I'm actually a mostly 1/72 modeller, but after finishing a beautiful WnW Fokker D.VII as my first 1/32 kit in ages, I kind of picked up the bug again. My last 1/32 somewhat modern aircraft was a Revell F-14A in VF-1 markings that I put on the television back then -until my mom dusted it off and it fell off, despite the rubber grippy tires! As it would fit nowhere near on a modern TV I guess that tells something about how long ago that was... (I'm 42 now and live in the Netherlands). Some may know me from the Dutch Modelbrouwers or WW1 Aircraft forum there I go by the same name. The Intruder has always been a favourite with 1/72 builds of Italeri, Hasegawa and Fujimi kits, but I'd never gotten one as it was too big and expensive... however, when I discovered AoA decals I got a set for VA-65, and somehow managed a nice deal on an A-6A, mostly still factory sealed. It's this set: My kids want me to do the camouflaged version, but bought it for NL-413 or AA-511, though as you can see later I finished the MERs already and it'll have to be NL-401 or NL-413 now. I can decide later on, but it does feel like a bit of a waste of decals to only use so few on top... I started our with ordnance, as one of the things I dislike about modern aircraft is just that. The kit only comes with 12 simplefied Mk82 Snakeeyes and 2 MERs, but a fellow modeller who would replace them with aftermarket gave me another MER and 6 Mk82s. I'll be loading the A-6 up with 2 MERs outboard, and 1 on the centerline, leaving the inner pylons empty as I saw on a photo of this cruise. As I can't justify the additional costs of 18 Mk82s and 3 MERs in aftermarket I set about to improve what came with the kit. These Snakeeyes fit poorly and required a lot of work to get them to look acceptable. I poked the hinges (which should extend much more to the rear and be much taller as well) with a drill bit and needle, and used a JLC saw and a scriber to open up the fins. The rear part was modified with some punched card disks. Accurate? Not quite, but IMHO a lot better as what came with the kit. I'll be using pins to attach all of it to the model once done so if my lottery ticket proves a winning one I can always replace them. I used black basing and mottled purple red, yellow and some green, deliberately painting some parts more than others. This was then overcoated with olive drab and the noses painted yellow. All of this was Revell Aqua Acrylics, except the glosscoat, which is my trusty Tamiya X-22. The decals are from the kit and worked well, but don't have any letterin on them, they're just yellow squares and rectangles... better than nothing I guess. The fuses are Revell Aqua "Eisen" (#91) with an oil wash and satin varnish. The MERs needed a lot of filling and sanding, and had the extra wires for the top positions added, for some reason Trumpeter supplies only the lower ones. These were also painted black, mottled with medium grey and pure white, then painted with my Insignia White mix (95% Revell Aqua 04 gloss pure white with 5% Revell Aqua 43 medium grey mixed in) I wish I replaced the lower wires as well, they do look a bit different now. The VA-65 decals are from the AoA sheet and worked well, final finish was another glosscoat, some washes with oil paints and a satin coat finished them. In case you're wondering why one of the decals is angled, I saw that on a photo and figured it would be a nice little detail. I'm now working on a few more mods to the wings and fuselage, so more to follow! Jeroen Edited January 15, 2021 by jeroen_R90S forgot the MER picture Squizzy, Greif8, GMK and 10 others 13 Link to comment Share on other sites More sharing options...
jeroen_R90S Posted November 11, 2020 Author Share Posted November 11, 2020 The next part were the modifications to the fuselage as indicated in the AoA instructions -these are really superb, by the way: ALR-18 chaff dispenser, it is really helpful if I had done this before I glued the bulkhead inside de fuselage, as it makes creating the slot much more difficult! This still needs some cleanup I'm not sure if this is prototypical for the kit, but mine had loads of sinkmarks on the flaps, slats, slat tracks (including pinmarks) and speedbrakes. This was filled with Mr White Putty as somehow I can't get CA to work on these shallow areas. Marcel111, Starfighter, F`s are my favs and 14 others 17 Link to comment Share on other sites More sharing options...
jeroen_R90S Posted November 11, 2020 Author Share Posted November 11, 2020 The last installment are the wingtips, these had the original navigations lights added as well as the ALR-15 RWR recievers. I could not find a lot of good pictures, but I found some images in a book and made a best-guess. I marked out the navigation lights and cut them off with a JLC saw. However, I mis-measured somehow and had to add some back with Evergreen. I also kind of mis-jugded how big these lights actually are, and after cutting them off I found out I did not have single bit of clear sprue that was big enough! Eventually I found some acrylic rod I used for in-flight 1/72 models, and a bit of testing showed this is much tougher than normal clear styrene, but can be used. It can even be glued with Tamiya Extra Thin. After the lights were done I had a bit of a reference for the ALR-15 antenna's, these were made from card, sprue and Milliput, aftwards needed more blending with CA and Mr Surfacer. Eventually I think they look OK, if not a bit too large. I also filled the panel lines indicated for the newer formation lights. Finally done, after a lot of work. Obviously nobody but A-6 experts will notice, but I found it a lot of fun to do and learned a lot! Brett M, Marcel111, LSP_Kevin and 11 others 14 Link to comment Share on other sites More sharing options...
jeroen_R90S Posted November 11, 2020 Author Share Posted November 11, 2020 One last installement (oops) for te lower avionics bay cover. This had the ALR-29 dispensers filled with Evergreen, as the dispensers from the kit sit deeper and are flat, making filling the holes more difficult. I then marked out the shape of the bulge and set up some Evergreen scraps to make it a bit firmer. The shape was then slathered with Milliput and roughly sculpted, and, like the wingtips, several rounds of filling, sanding and priming followed. The flange was recreated by marking the shape with doubled-up tape and brushing Mr Surfacer on it. With hindsight I should have airbrushed it, as it's a bit uneven. Not perfect but I'm not ready to start over again, and again, I leared quite a lot from this little adventure! The final result, the bulge itself looks pretty good IMHO, the flange, especially at the rear, could have been better But I find it acceptable for now Now to read up on all those great inspirational builds here...! Best regards, Jeroen easixpedro, MikeMaben, LSP_Kevin and 17 others 20 Link to comment Share on other sites More sharing options...
easixpedro Posted November 11, 2020 Share Posted November 11, 2020 Brilliant work! Looks like you’re well on your way to a solid A model. Looking forward to more! Thanks for sharing! -Peter jeroen_R90S 1 Link to comment Share on other sites More sharing options...
Brett M Posted November 11, 2020 Share Posted November 11, 2020 Welcome to the forum! You’ve done some great work to start, I’m looking forward to seeing more. jeroen_R90S 1 Link to comment Share on other sites More sharing options...
Neo Posted November 11, 2020 Share Posted November 11, 2020 (edited) Wow thats some solid work there. Great job Edited November 11, 2020 by Neo jeroen_R90S 1 Link to comment Share on other sites More sharing options...
Rockie Yarwood Posted November 11, 2020 Share Posted November 11, 2020 Great work, Jeroen! I really like the finish on your Mk82's. Cheers, Rockie jeroen_R90S 1 Link to comment Share on other sites More sharing options...
jeroen_R90S Posted November 11, 2020 Author Share Posted November 11, 2020 (edited) Thank you all for the warm welcome! I'm currently working on the sink marks of the slats and some last wing bits, and my Verlinden PE seatbelts/buckles finally arrived today so hopefully I can finally get along on the interiour. Feels like I've been filling and sanding for ages now... time to glue some stuff together I also really to find some time to read and comment on all the other great builds going on here Jeroen Edited November 11, 2020 by jeroen_R90S Greg W 1 Link to comment Share on other sites More sharing options...
Barry Posted November 11, 2020 Share Posted November 11, 2020 Great looking Intruder underway! FYI, all the MERs and TERs I've seen have the Firing Cables encased in a woven wire mesh covering like this. Keep up the great work! Barry Greg W, Paul in Napier, Rockie Yarwood and 5 others 8 Link to comment Share on other sites More sharing options...
Squizzy Posted November 11, 2020 Share Posted November 11, 2020 I’ll be watching this with interest! I’ve got one in the stash, and for some reason this kit has we worried about starting it! Must be the cost and the Trumpeter factor, but from what I’ve read, they had Trumpeter’s A team on this one. Good luck! jeroen_R90S 1 Link to comment Share on other sites More sharing options...
Padubon Posted November 12, 2020 Share Posted November 12, 2020 Quite impressive! It is interesting that there is not a simple A-6A, F-16C of Fw190, there is always something that needs modification, correction of upgrade. Excellent work! jeroen_R90S 1 Link to comment Share on other sites More sharing options...
Starfighter Posted November 12, 2020 Share Posted November 12, 2020 Very nice, I'll be following with huge interest! jeroen_R90S 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted November 12, 2020 Share Posted November 12, 2020 Good stuff. Sincerely, Mark jeroen_R90S 1 Link to comment Share on other sites More sharing options...
Crew Dog Posted November 12, 2020 Share Posted November 12, 2020 Outstanding work on the Intruder so far! Really like the effect you've done on the Mk.82's! Welcome aboard, and I'm pulling up a bench for sure. jeroen_R90S 1 Link to comment Share on other sites More sharing options...
