Chris Wimmer Posted November 3, 2020 Share Posted November 3, 2020 Hello Everybody! Sorry for joining the party a bit late! This is my Revell conversion project that I started four years ago. I finally recovered it from the SOD and really hope to get it done this time… Pictures taken in 2016: Pictures taken yesterday. The sheet styrene both of cockpit and fuselage has obviously turned into yellow over the years... So this is the point where I'm starting from. AM will be a set of Eduard seatbelts as well as Airscale bezels & dials. February you said? Think I will have to roll my sleeves up...once again... Thanks for looking in Chris Anthony in NZ, Paul in Napier, mozart and 17 others 20 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 3, 2020 Share Posted November 3, 2020 Boy does this look familiar! This might just be the kick in the pants I need to drag mine out again. Good luck, Chris! Mine was started in 2009... Kev Rockie Yarwood, Chris Wimmer and D Bellis 3 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 4, 2020 Author Share Posted November 4, 2020 11 hours ago, LSP_Kevin said: Boy does this look familiar! This might just be the kick in the pants I need to drag mine out again. Good luck, Chris! Mine was started in 2009... Kev I remember, Kev! Would really love to take a look at your thread. Where can I find it? Link to comment Share on other sites More sharing options...
kkarlsen Posted November 4, 2020 Share Posted November 4, 2020 Very nice training conversion! Kent Chris Wimmer and Rockie Yarwood 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 4, 2020 Share Posted November 4, 2020 31 minutes ago, Chris Wimmer said: I remember, Kev! Would really love to take a look at your thread. Where can I find it? Here you go, Chris: Just don't take anything you see there as gospel. I'm also planning to make changes to some of the work I've already done, and hopefully your build will be just the motivation I need! Kev Landrotten Highlander, Chris Wimmer, Greg W and 1 other 4 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 7, 2020 Author Share Posted November 7, 2020 (edited) Thanks for sharing the link here , Kev! It's really amazing how much work you have already put into your build. Really hope that I can motivate you (although I'm still not entirely sure how to get mine done... ). Nice pic of the canopy. I always loved that morbid look and will try to represent it by using clear sheet and self-adhesive aluminium foil, hope it works... I made the hump by just bending a piece of 0,5mm sheet styrene. In advance I milled a small groove where it meets the fuselage. As shown in my first post this section was already done. However, it looked somewhat twisted and asymetrical, so I had to mill the support wall away and then carefully bent the hump into the correct position: Instructor's cockpit: The starboard side console looks quite simple and wasn't a big deal to do. The console on port side is a different thing. I vacuformed it over a carved piece of balsawood. Side console looks right to me, not so the forward part of the hump. I will try again later... So my Cockpit section is almost ready for paint. Just a little more detail to be added: Thanks for looking in... Chris Edited November 7, 2020 by Chris Wimmer Greg W, scvrobeson, LSP_Kevin and 9 others 12 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 10, 2020 Author Share Posted November 10, 2020 Thank you, Maru! I'm busy with detailing and painting the cockpit now. Will take a few more days to get it done. More to come soon... Thanks for lookin' in... Chris Alain Gadbois, Landrotten Highlander, Paul in Napier and 9 others 12 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 18, 2020 Author Share Posted November 18, 2020 Progress report for today! Have finally finished all the instrument panels. I used the kit decals for the kit parts and airscale bezels and dials for the scratchbuilt. The hole in the rear lower panel sits EXACTLY in the centre, gnnn... Main IP glued in place. Before I gave it that "glass" look by applying a drop of UV glue I replaced the horizon and the RPM by cannibalizing my second kit... Test fit... Let's take a look into Peter Rodeike's fantastic Fw190 book. On the right you can see two different styles of trainer cockpits. I'm going for the upper one, which looks pretty much like the Hendon example. The lower one is believed to be a converted Fw190A-5, if the white numbers written below the panel actually show its serial number. Kev is doing this version and he painted the cockpit in RLM66 grey, so I decided to try something different. Hey Kev, you really did a marvellous job on your Fw190 trainer and I like it very much! I think it's definately too beautiful for finally ending up on the the SOD. Searching the www I found nothing but one sole twin-seater build in our favourite scale out there! Hey, why not let there be three! More test fit... Working on the seatbelts today. I used the Eduard parts as seen here, but I prefer lead foil and wire for the shoulder straps. Note that there is no cushion attached to the rear seat. According to my sources a seat parachute was used here instead of a backpack, due to a lack of space. Thanks for looking in Chris Greg W, Landrotten Highlander, mgbooyv8 and 6 others 9 Link to comment Share on other sites More sharing options...
Jerry Crandall Posted November 18, 2020 Share Posted November 18, 2020 Great job so far. Keep in mind the seat backs are armored iron so there would be no silver chipping. Also the seat cushions are RLM 66. Cheers, Jerry Chris Wimmer, Rockie Yarwood and Greg W 2 1 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 18, 2020 Author Share Posted November 18, 2020 (edited) 53 minutes ago, Jerry Crandall said: Great job so far. Keep in mind the seat backs are armored iron so there would be no silver chipping. Also the seat cushions are RLM 66. Cheers, Jerry Thanks very much , Jerry! That's just in time... cheers, Chris Edited November 18, 2020 by Chris Wimmer Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 18, 2020 Author Share Posted November 18, 2020 Ok, and suddenly this pic really does make sense to me... Rockie Yarwood, Landrotten Highlander, Greg W and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 18, 2020 Share Posted November 18, 2020 Great work, Chris! 1 hour ago, Chris Wimmer said: Hey Kev, you really did a marvellous job on your Fw190 trainer and I like it very much! I think it's definately too beautiful for finally ending up on the the SOD. Searching the www I found nothing but one sole twin-seater build in our favourite scale out there! Hey, why not let there be three! Thanks, Chris. I definitely intend to get back to it - and hopefully soon! But I really need to clear the bench of other projects that are in the way first, rather than simply extending my SoD queue! Kev Rockie Yarwood and Chris Wimmer 2 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 20, 2020 Author Share Posted November 20, 2020 Well then... back to start with the seats! mozart, mgbooyv8, BradG and 6 others 9 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 21, 2020 Author Share Posted November 21, 2020 2 hours ago, MARU5137 said: Chris, Seats look great. seat belts too. look forward to seeing more. Good job. Sorry Maru, too late. But thank you very much for your kind and always encouraging words. Rockie Yarwood 1 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted November 30, 2020 Author Share Posted November 30, 2020 Update for today! I have no idea how to use a 3D printer, so I'm afraid it's rather old school stuff what I'm about to show you here: Gluing pieces of tinplate to both sides of a piece of balsawood. Then carefully cutting and sanding away all the excess material and - after several trials and errors the front part of the hump finally sits in place Reworked the seats and added a little dark grey chipping to the backs. The cushion is painted RLM66 now, thanks again, Jerry! You may have noticed that the flight sticks are missing. I found that the KG13 stick coming with the new Me262 kit looks very much more like the real thing, so I ordered a pair from Revell. Still waiting... Thanks for looking in Chris Rockie Yarwood, LSP_Kevin, Starfighter and 12 others 15 Link to comment Share on other sites More sharing options...
