wpierson 53 Posted December 25, 2020 Share Posted December 25, 2020 You should consider skinning only one side of the fuselage so folks can see that amazing work. MARU5137 and airscale 2 Link to post Share on other sites
Oldbaldguy 645 Posted December 25, 2020 Share Posted December 25, 2020 On 12/6/2020 at 5:28 PM, dodgem37 said: Lovely work, Peter. I'm surprised the throttle quadrant is mounted outside of the framing. Sincerely, Mark Ditto on the throttle quadrant. Just don’t see how that’s going to work considering the general shape of the fuselage. MARU5137 and airscale 2 Link to post Share on other sites
Oldbaldguy 645 Posted December 25, 2020 Share Posted December 25, 2020 Nope, he’s right. The quadrant fits in between the longeron and the skin. airscale 1 Link to post Share on other sites
wunwinglow 5,675 Posted December 25, 2020 Share Posted December 25, 2020 Phwoooaaar! Yes, I think that sums up my reaction! Happy Christmas Peter! Tim MARU5137, airscale and Rockie Yarwood 2 1 Link to post Share on other sites
Model_Monkey 622 Posted December 26, 2020 Share Posted December 26, 2020 Brilliant! Wishing you lots of mojo this year. airscale and MARU5137 2 Link to post Share on other sites
airscale 11,946 Posted December 27, 2020 Author Share Posted December 27, 2020 Seasons Greetings all I hope you all had a great Christmas, even if it was a bit different this year. I had about the best ever with just my immediate family and zero stress or hassle On 12/6/2020 at 7:04 PM, brahman104 said: Sooooo good!!!!!!! The ammo cans and chutes are amazing. The little stiffeners on the side of the boxes though... are they folded litho or P.E.? They look thicker than folded sheet..... Now I'm off to watch your next Patreon video Craig Hi Craig - if you mean the little stringer 'T' sections, yes, they are folded litho - I think I folded once, then splayed out the 'T' bar of the Tee to make them, then rivetted from behind On 12/6/2020 at 10:28 PM, dodgem37 said: Lovely work, Peter. I'm surprised the throttle quadrant is mounted outside of the framing. Sincerely, Mark Hi Mark - yes me too - this is a Nimrod rather than a Fury, but you can see it packed in there on the outside of the main tubular fuselage assembly.. ..likely to be a bit of a nightmare to get these sorts of tolerances and fits when the time comes.. On 12/25/2020 at 1:49 AM, wpierson said: You should consider skinning only one side of the fuselage so folks can see that amazing work. I have considered leaving one of the big side access panels off so it can all be seen, maybe I will, I just need to work out how much work that means as much more than just the cockpit can be seen.. unlikely, but possible... so, been busy with a couple of things, first I have skinned the 'easy' constant chord parts of the wings - I ended up using very thin card, lined from the back with a ballpoint pen to define ribs and contact adhesive to stick it down (plastic cements seemed to distort the skin too easily... ..holes were made where the struts & rigging goes.. ..the wing tips are proving difficult and frustrating, simple scoring a skin doesn't work as the skin has compound curves as the skin gets both smaller at the tip, but also shrinks in chord - I am trying to vacform a base part and score that (not going so well), but I might just end up filling with P38 and shaping from a solid - though that means a bit of weight at the tips I don't want... ..with that not going smoothly, I decided to change tack and start the fuselage.. this will be vacformed over a basswood master - the first time I have tried this and I really want it to go well as it means I can scratchbuild any subject in 1/18 in the future ..the first thing to do was to create all the relevent sections and outlines as scale plans - the outlines to define the outer borders of the shape, and the sections to be used when shaping the wooded master to the shapes needed.. ..each section was created as a side profile and as a top and bottom profile and numbered to the station position.. ..the basswood core is four machined 4cm square bits that get painted black on the mating faces which defines the four datum lines that run through the fuselage.. ..you can see one half has been painted, then stuck together, then the side profile applied.. ..I bought a small bandsaw just for this job to get nice perpendicular cuts - here I am starting to cut out the side profile.. ..I had also drilled holes where the mainspar was, and the front and rearmost exhaust stack while I had theri positions to hand.. ..I didn't run the cut all the way to the end, so it kept the cut-off bit in place so I still had a square block to then cut the top profile.. ..once the cuts were finished, the front and rear cuts were made and a disc stuck to the front to denote the spinner size.. ..you can also see the datum lines showing through.. ..then it was lots of rasping, sanding , filing and generally making a terrible mess to get the Fury within to match the contour profiles... ..the two halves were only lightly stuck together, so these were broken apart after fully finishing - I had been too aggressive in places so used P38 to build it back up and/or primer which I also needed to get a better eye on the shapes (though this needed to be removed for vacforming..) ..then the halves needed a 1.5mm plinth and some fillers at the nose and tail so the plastic doesn't have such a drop off and to space the mould up from the vacforming plinth by the thickness of the material.. ..now for the vacforming itself... I couldn't hope to do this at home, I don't have the kit and as it's quite a big part even if I did I doubt I could do it. So I asked my good friend John Wilkes (Tigger) who offers large scale vacform kits like B29's Do217 etc to do them for me (and had advised me on making the mould). i sent John the mopuld and he very quickly turned around a few copies - they are nothing less than perfect! ..I have just started to cut them out and get the mating faces right - here you can see the fuselage sat with the wings (ignore the incidence..) ..so now I have the basic form, and am forever in debt to John.. ..next is planning how to proceed - I think to get all the skinning on the nose right, and to be able to integrate the delicate internal fuselage framework & cockpit, i will need to assemble the vac halves and then cut in two at the cockpit so I have one form for the nose for skinning, the tubular cockpit slides forward into that, and the rear fuselage & tail (with stringer detail added), will slide forward onto those.. ..thats the working theory, but as I am making all this up as I go it may change TTFN Peter Rainer Hoffmann, MARU5137, GMK and 24 others 27 Link to post Share on other sites
jumpjack 47 Posted December 27, 2020 Share Posted December 27, 2020 Hi Peter- Limonene (as sold by Mr Cement but widely available as a commercial product) is a much less aggressive solvent useful for bonding very thin styrene to styrene and other material with a surface key. Smells of citrous fruit. Seasonal Best Wishes to All. Out2gtcha, airscale and MARU5137 3 Link to post Share on other sites
Derek B 4,534 Posted December 27, 2020 Share Posted December 27, 2020 (edited) Peter, I am so pleased that you have had a really restful Christmas (I hope that you will have a great new year as well). Fantastic progress with your Fury and I am so pleased that Tigger has been able to assist you with your project - he is a top guy! As for the wing tips, as you already have the ribs in place, perhaps filling the voids with dense blue foam type material and the then (after shaping) cover each individual rib position with strips of thin plastic sheet; hopefully, that will get you around the double curvature issue without adding additional weight to the wing tips? Alternatively, to keep it simple, you could fill the tip rib gaps with foam, shape it, then heat a thin sheet of plastic card and simply pull it over the wing tip - it can then be trimmed and glued to the tip (i use latex based contact adhesive for this purpose, as it does not affect the plastic - I use this to attach plastic sheet to balsa cores for wings or fuselage). For foam filler. I use 'Oasis' type flower arranging foam, which seems pretty impervious to any solvents. Good luck. Cheers Derek Edited December 27, 2020 by Derek B airscale, MARU5137 and Alain Gadbois 3 Link to post Share on other sites
tigger 342 Posted December 28, 2020 Share Posted December 28, 2020 Glad that I could be of service to you Peter. Derek B, Out2gtcha, Scotsman and 2 others 4 1 Link to post Share on other sites
alaninaustria 5,810 Posted December 28, 2020 Share Posted December 28, 2020 Wow! What a build! And nice to see the cooperation amongst members! Cheers Alan airscale and MARU5137 2 Link to post Share on other sites
crobinsonh 865 Posted December 28, 2020 Share Posted December 28, 2020 Superb work and illustration of your methods airscale and MARU5137 1 1 Link to post Share on other sites
Marcin_Matejko 788 Posted December 28, 2020 Share Posted December 28, 2020 Very good Peter That's how I make hulls, it's the best method airscale 1 Link to post Share on other sites
tomprobert 3,384 Posted December 28, 2020 Share Posted December 28, 2020 This project just continues to amaze - it’s good to see your woodworking skills are on a par with your metal work... is there anything you cannot do..? Tom MARU5137, Derek B and airscale 2 1 Link to post Share on other sites
Out2gtcha 36,358 Posted December 28, 2020 Share Posted December 28, 2020 Simply astounding work! airscale 1 Link to post Share on other sites
Cati888 2 Posted December 28, 2020 Share Posted December 28, 2020 Long time lurker.. wondered If you had considered some of the very light hearshrink used for free flight scale models. You can use small slithers for wing tape etc lifespan was most commonly used but getting in short supply https://solarfilm.co.uk/products/litespan MARU5137 and airscale 2 Link to post Share on other sites
