artoor_k Posted October 16, 2020 Share Posted October 16, 2020 (edited) Hello, It's time for another oldie I've searched for Lysander for few months because it's not available in shops, only from second hand. I bought it from friend two weeks ago and it landed on the bench ASAP. There is something cool in this dragonfly-like airplane I bought it in original box I had to modify seat and rudder pedals Map box wasn't there so it was needed to scratchbuild it Observer's electric panel was a fantasy so this is new one, based on 4+ Lysander book Rear side of instrument paner was plain so some profiles and wires were used to make this area busy There was no rear ballast and no starting handle so they were build from profiles and clip wire. Instrument panel was quite detailed. AMMO paints were used to finish it. Then Kristal Klear for all glasses. On this photo K.K. is milky white - it was not dry. After drying it's super clear. Cockpit is almost ready. I'm waiting for Eduard seatbelts. Gunsight still needs to be built. Here is observer seat, one from kit was unusable. When I'll get seatbelts I'll be ready for final works inside fuselage. Next week I hope I'll get masks from Montex and guns from Master. Edited October 16, 2020 by artoor_k Fixed image links BiggTim, wunwinglow, Kagemusha and 11 others 14 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 16, 2020 Share Posted October 16, 2020 Hi Artoor, You have to remove the bbCode (stuff in square brackets) for your images to show now. More details in the following thread: Kev artoor_k 1 Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted October 16, 2020 Share Posted October 16, 2020 Unfortunately I cannot see your pictures, and copying it in the search bar does not help either. I use Imgur as well, and I always copy the 'direct' option (click on a picture, its the second option on the right of the screen. Link to comment Share on other sites More sharing options...
artoor_k Posted October 16, 2020 Author Share Posted October 16, 2020 (edited) 12 minutes ago, LSP_Kevin said: Hi Artoor, You have to remove the bbCode (stuff in square brackets) for your images to show now. More details in the following thread: Kev Thanks, I've missed that topic. Unfortunately now I have only links, not pictures. Edited October 16, 2020 by artoor_k Link to comment Share on other sites More sharing options...
artoor_k Posted October 16, 2020 Author Share Posted October 16, 2020 7 minutes ago, Landrotten Highlander said: Unfortunately I cannot see your pictures, and copying it in the search bar does not help either. I use Imgur as well, and I always copy the 'direct' option (click on a picture, its the second option on the right of the screen. Thanks for tip Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 16, 2020 Share Posted October 16, 2020 Just now, artoor_k said: Thanks, I've missed that topic. Unfortunately now I have only links, not pictures. I can see that you tried to fix the images, Artoor, and that it didn't work, so I've sorted them out for you. If you remove the bbCode tags and leave the URL intact, the forum software just sees it as a link, and doesn't embed the image. In that case, you can either remove it and paste it in fresh, or use the 'Insert image from URL' function, available from the Other Media drop-down menu, bottom right of the post edit window. Kev Link to comment Share on other sites More sharing options...
artoor_k Posted October 16, 2020 Author Share Posted October 16, 2020 Just now, LSP_Kevin said: I can see that you tried to fix the images, Artoor, and that it didn't work, so I've sorted them out for you. If you remove the bbCode tags and leave the URL intact, the forum software just sees it as a link, and doesn't embed the image. In that case, you can either remove it and paste it in fresh, or use the 'Insert image from URL' function, available from the Other Media drop-down menu, bottom right of the post edit window. Kev Many thanks and sorry for making mess LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted October 16, 2020 Share Posted October 16, 2020 7 minutes ago, artoor_k said: Thanks for tip ur welcome. Nice work btw. artoor_k 1 Link to comment Share on other sites More sharing options...
artoor_k Posted October 24, 2020 Author Share Posted October 24, 2020 Hello, Yesterday I got PE seatbelts and metal barrels. I found two ammo boxes with Tamiya ammo belts in scrapbox so I'll use them for Lysander. Machinegun pivot arm is made from styrene profiles, same as gunsight mount. I hate working with PE parts - when everything is glued together and it's time to put f.ex seatbelts in place, these PE's starting to disasseble like they're never glued. I think I'll never learn to use them properly chukw, patricksparks, Iain and 12 others 15 Link to comment Share on other sites More sharing options...
Iain Posted October 24, 2020 Share Posted October 24, 2020 Beautiful work, on a great subject! Iain Kagemusha 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted October 24, 2020 Share Posted October 24, 2020 1 hour ago, Iain said: Beautiful work, on a great subject! Iain Absolutely! Link to comment Share on other sites More sharing options...
MikeMaben Posted October 25, 2020 Share Posted October 25, 2020 Link to comment Share on other sites More sharing options...
artoor_k Posted October 25, 2020 Author Share Posted October 25, 2020 Thanks y'all With use of masks from Montex I painted wheels but when I was going to mount them in fairings I realised that I have to make new backplates of lights. There was no chance to glue them OOB (or I'd made a mistake when reading manual). So I've cut new backplates from piece of styrene, painted them silver and glued bulbs from transparent sprue. Towend ring and exhaust were glued together. Exhaust was drilled and both parts were painted with dark cooper and titanium gold. MikeMaben, patricksparks, Landrotten Highlander and 3 others 6 Link to comment Share on other sites More sharing options...
mgbooyv8 Posted October 25, 2020 Share Posted October 25, 2020 Nice to see a Lysander being build. Very good work! Cheers, Peter Link to comment Share on other sites More sharing options...
artoor_k Posted November 2, 2020 Author Share Posted November 2, 2020 (edited) Hello! Well, it's time for some paint... Wing was first. Tamiya Green and AK Brown were used. ...then fuselage. Bottom color is Mr.Hobby Sky. Bomb dispensers OOB looked nowhere near real ones so I build them from scratch. Engine was glued together with cowling and Towend ring. Then two brass pipes were glued too. Edited November 2, 2020 by artoor_k Whitey, chukw, Gazzas and 8 others 11 Link to comment Share on other sites More sharing options...
