thierry laurent Posted October 27, 2020 Share Posted October 27, 2020 The Tamiya F-14 is really needing such a treatment. Marcel111 and Darren Howie 2 Link to comment Share on other sites More sharing options...
RFS Hungary Posted October 28, 2020 Share Posted October 28, 2020 16 hours ago, Dave Williams said: Thanks for doing this, although a little too late for me since I just got the F-117 sets. If you are redoing the F-117, is they any chance that you can also change the grey background color? It’s much too light for the real Dark Gull Gray color that it should be. The color in the F-5E set looks closer. Dear Dave, Yes we will look into the problem and definitely repair it! We could advise you to gently wash the surface. At the edges .. maybe a solution .. And thanks for the comment! Regards Attila Link to comment Share on other sites More sharing options...
RFS Hungary Posted October 28, 2020 Share Posted October 28, 2020 13 hours ago, Troy Molitor said: An earlier mark Stuka set would also be nice. Dear Troy, We are already working on versions A and B! We hope to be available soon! Isar 30/07, MikeMaben and coogrfan 2 1 Link to comment Share on other sites More sharing options...
RFS Hungary Posted October 28, 2020 Share Posted October 28, 2020 11 hours ago, thierry laurent said: The Tamiya F-14 is really needing such a treatment. Thierry, did you mean the display is off? Because we will introduce it for almost all types. Where it is needed... Regards Attila coogrfan 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted October 28, 2020 Share Posted October 28, 2020 Hi Attila, No, this was not my point. For sure you understood I do not like when the systems are up. However, for the Tamiya Tomcat the problem is more elemental: there is simply no instrument on the panels! Tamiya just put some flat decals. Accordingly your 3d decals would noticeably improve the cockpit. BR Thierry Link to comment Share on other sites More sharing options...
RFS Hungary Posted October 28, 2020 Share Posted October 28, 2020 1 hour ago, thierry laurent said: Hi Attila, No, this was not my point. For sure you understood I do not like when the systems are up. However, for the Tamiya Tomcat the problem is more elemental: there is simply no instrument on the panels! Tamiya just put some flat decals. Accordingly your 3d decals would noticeably improve the cockpit. BR Thierry Ohh okay Link to comment Share on other sites More sharing options...
RFS Hungary Posted October 28, 2020 Share Posted October 28, 2020 18 hours ago, Dave Williams said: Thanks for doing this, although a little too late for me since I just got the F-117 sets. If you are redoing the F-117, is they any chance that you can also change the grey background color? It’s much too light for the real Dark Gull Gray color that it should be. The color in the F-5E set looks closer. We looked at the problem ... The color of the F-117A is given by both Hasegawa and Trumpeter (given as FS36375) which corresponds to the H57 Aircraft Gray in the Gunze palette. The F-5 and F-18E Yet as you wrote Dark gull gray (FS 36231) which is H317 in the Gunze palette. This can lead to the difference. But of course we will try to bring out the color as close as possible and if we can do even better we will! Thanks Attila thierry laurent, coogrfan, Jeff T and 1 other 4 Link to comment Share on other sites More sharing options...
Dave Williams Posted October 28, 2020 Share Posted October 28, 2020 1 hour ago, RFS Hungary said: We looked at the problem ... The color of the F-117A is given by both Hasegawa and Trumpeter (given as FS36375) which corresponds to the H57 Aircraft Gray in the Gunze palette. The F-5 and F-18E Yet as you wrote Dark gull gray (FS 36231) which is H317 in the Gunze palette. This can lead to the difference. But of course we will try to bring out the color as close as possible and if we can do even better we will! Thanks Attila Thanks for taking a look, Attila. The color given by Hasegawa and Trumpeter is wrong. Standard modern US cockpit color is Dark Gull Gray, and that includes the F-117. Also, the background of the main instrument panel is black, not the gray cockpit color. A Google search for “F-117 cockpit” can confirm this. As a note, the photos of the F-117 in the USAF museum are from an early machine that was used testing and it has a non standard instrument layout. HTH. RFS Hungary 1 Link to comment Share on other sites More sharing options...
RFS Hungary Posted October 28, 2020 Share Posted October 28, 2020 25 minutes ago, Dave Williams said: Thanks for taking a look, Attila. The color given by Hasegawa and Trumpeter is wrong. Standard modern US cockpit color is Dark Gull Gray, and that includes the F-117. Also, the background of the main instrument panel is black, not the gray cockpit color. A Google search for “F-117 cockpit” can confirm this. As a note, the photos of the F-117 in the USAF museum are from an early machine that was used testing and it has a non standard instrument layout. HTH. The layout of the instruments was based on the book by HAYNES. We could not obtain a more credible source. And when it came to colors, we tried to rely on manufacturers. Which is also a bit annoying because if someone orders from this kits (Hasegawa or Trumpeter), and after follows the instructions it won’t be like the original. Or, if we're going to make it with Dark Gull Gray now (by the way well), another part of the modellers will throw us a stone to so what we are do :)) By the way we will do Thanks! Kagemusha and coogrfan 2 Link to comment Share on other sites More sharing options...
NewtonK Posted October 29, 2020 Share Posted October 29, 2020 Late to the game, but will get the A 10 in 1/32, thank you very much Link to comment Share on other sites More sharing options...
otis252 Posted October 29, 2020 Share Posted October 29, 2020 Will the F/A-18E set fit the Trumpeter Kit? Thanks. Chuck RFS Hungary 1 Link to comment Share on other sites More sharing options...
seiran01 Posted October 29, 2020 Share Posted October 29, 2020 The Red Fox Fw190 set for the Revell kit just arrived an hour ago (ebay buy - thanks Attila!). My god it's nice. coogrfan and RFS Hungary 2 Link to comment Share on other sites More sharing options...
RFS Hungary Posted October 29, 2020 Share Posted October 29, 2020 8 hours ago, otis252 said: Will the F/A-18E set fit the Trumpeter Kit? Thanks. Chuck I don't know ... but most likely not :( we experience several times that when we make a jet, the instrument panel in the kits of the manufacturers is usually, if "minimal" (or total other separated), different ... but the good news is that our panels for trumpeter 1/32 sets will be available by the end of November! E, F and G series Nice day! Attila Marcel111 and Kagemusha 2 Link to comment Share on other sites More sharing options...
RFS Hungary Posted October 29, 2020 Share Posted October 29, 2020 54 minutes ago, seiran01 said: The Red Fox Fw190 set for the Revell kit just arrived an hour ago (ebay buy - thanks Attila!). My god it's nice. We thanx too! Good build! Link to comment Share on other sites More sharing options...
Rubblebeam Posted October 30, 2020 Share Posted October 30, 2020 16 hours ago, RFS Hungary said: I don't know ... but most likely not :( we experience several times that when we make a jet, the instrument panel in the kits of the manufacturers is usually, if "minimal" (or total other separated), different ... but the good news is that our panels for trumpeter 1/32 sets will be available by the end of November! E, F and G series Nice day! Attila Nice. RFS Hungary 1 Link to comment Share on other sites More sharing options...
