2 New Bomber L/G Sets From S.O.W.
Bombs Away!!
Introducing 1/32 Bomber sets from Synthetic Ordnance Works.
We have two new landing gear sets made for the Junkers Ju 88A-1/4 and the
Consolidated B-24D/J Liberator ready to go:
NEW!     MLGS 1018 Junkers Ju 88A-1/4 Set
(for Revell Kit)
Price:  $26.95  $23.95
Made withe the same engineering process as our other gear sets - stanless steel tube(5 mm),
music wire(.025", .062" & .078") and captured in polyurethane resin. The only difference is no
SS oleo reveal. The complexity of the original gear design transfers to the 1/32 gear and as a
result increases labor costs. Guaranteed to hold up to the toughest treatment, however, trying
to land your plane on the driveway from the roof voids all warranties, expressed or implied!).
NEW!     MLGS 1019 Consolidated B-24D/J Liberator
(for HobbyBoss Kit)
Price:  $27.95
These are some beefy legs, pile on as much weight in the nose as you like, they'll
take it at their ease. Engineered with 5.5 mm stainless steel tube, .094" music wire
and P/U resin.
ORDERING PROCESS:
To place an order please contact me at this email address:
DBAndrus(at)protonmail(dot)com
Please include the following information:
  1. The item number and the quantity of each item you would like to order.
  2. The country to which the items will be sent.
  3. The email address you use for Paypal.  An invoice form Paypal will then be sent to you via email.
Upon receipt of payment your order will be shipped to you via USPS First Class Mail.
USPS Priority Mail is available at additional cost - prior approval from customer is required to avoid "sticker shock".
(If postage is deemed excessive by out of U.S. customers and you wish to cancel the order, please notify us at your earliest convenience.)
Shipping to U.S. Addresses:
1 to 5 sets               $5.00
6 or more sets       Free
Shipping to non-U.S. address:
See No. 2 above  We use a flat rate of $15.00 for shipments outside of the U.S.
Please Note:
Synthetic Ordnance Works is a one-man operation dealing with labor intensive products. Please have patience when an item is out of stock. It will be refilled as quickly as possible, considering the only fabricator is past his sell-by date.)
COMING SOON!
MLGS 1016   A-4 "Skyhawk"  (for Hasegawa kit)
MLGS 1017   A-4 "Skyhawk"  (for Trumpeter kit)
MLGS 1020   Me 262 "Schwalbe"  (for Revell kit)
COMING LATER!
MLGS 1021   P-40 "Warhawk"  (for Hasegawa kit)
MLGS 1022   F-86F "Sabre"  (for Kinetic/Italieri kits)
MLGS 1023   Bf 110 (for Dragon/Revell kits)
MLGS 1024   He 219A (for Revell kit)
MLGS  1025  MiG -23 (for Trumpeter kit)
IMPORTANT NOTICE:
At the point where all sets listed as "Coming .........." are in production Synthetic Ordnance Works will evaluate where we stand with our business model. Whether we continue solely with landing gear, diversify into other modeling products, or move on to other things remains to be seen. We'll keep you posted as to what the future holds for S.O.W.!
Thanks for stopping by and taking a gander at our products.
Damian Andrus
HERE IS A LIST OF THE BALANCE OF OUR PRODUCTS:
MLGS 1001   Messerschmitt Bf 109G/K Set
(for Hasegawa Bf 109 G/K kits)
Price:  $17.95 per set
This set is for the Hasegawa 109 in the G-4 through G-14 and K-4 range. It also features added towing loops and pre-shortened axles. This axle process makes the gear suitable for kit wheels and aftermarket, ie. MDC and Barracuda products. The music wire makes shortening the axle problematic for the user, so we've done that in advance.
MLGS 1002   Messerschmitt Bf 109F-2/4 Set
(for Hasegawa Bf 109F-2/4 kits)
This set also features the towing loops as well as the kit's hydraulic line overlapping the oleo. Be aware these lines are delicate and need care when handling. You can also remove the resin lines and use your own setup. We wanted to give the buyer a choice on which route to take. The pre-shortened axle modification applies to this set, as well.
MLGS 1003   Messerschmitt Bf 109G-6/G-10 Set
(for Revell Bf 109G-6/G-10 Kits)
Price:  $18.95 per set
This set addresses the inherent weaknesses in the kit's design. Our parts will eliminate the overly-complex assembly stage while adding strength with stainless steel tubing and intricate bends in the music wire. This makes for a very rigid landing gear assembly.
This is the complex wire bend embedded the mounting lug:
MLGS 1004   Focke-Wulf  Fw 190A-8/F-8
(for Revell Fw 190A-8/F-8 kits)
As with the Revell 109, set we address the thin axle in the original design by adding music wire to give a rigid gluing surface for the wheel assembly.
MLGS 1005   Focke-Wulf  Fw 190A/D
(for Hasegawa Fw 190A/D kits)
This set is for the Hasegawa Fw 190A-5, A-8 and D-9 kits.
MLGS 1006Tank Ta 152H-0/H-1
(for Zoukei-Mura Ta 152H-0/H-1 kits)
Designed specifically for the Zoukei-Mura Ta 152 kit.
MLGS 1007   Grumman TBF-1C/TBM-3  "Avenger"
(for Trumpeter kit)
MLGS 1008   Douglas SBD -1/2/3/5  "Dauntless"
(for Trumpeter kit)
Price:  $18.95
MLGS 1009   North American Aviation P-51D  "Mustang"
 (for Revell kit)
MLGS 1010   Nakajima Ki-84  "Hayate"
(for Hasegawa kit)
Price:  $17.95
MLGS 1011   Kyushu J7W1  "Shinden"
 (for Zoukei-Mura kit)
Price: $22.95 per set
Above is the complex interior stainless steel tubing and music wire structure needed to add necessary support for the very thin nose gear leg.
MLGS 1012   Supermarine "Spitfire" Mk. IIa
(for Revell Kit No. 03986)
Price:  $16.95 per set.
Detailing of the towing loops enhances to the stainless steel oleo reveal.
As with all of our sets the struts and axles are constructed with stainless steel capillary tubing, music wire and high quality Smooth-On
polyurethane resin.
MLGS 1013  Lockheed P-38 "Lightning"
(for Trumpeter kit)
Price:  $25.95 per set
This is a complex set of gear to engineer....the main gear legs each have 2 pieces of SS tubing and 4 pieces of various diameters of
music wire all encapsulated in a strong resin shell. The nose gear is strong enough to take any amount to weight needed to keep this
baby from being a tail sitter!
Some external modifications have been made from the kit parts:
The diameter of the main and nose oleos were determined to be a bit underfed, so they've been beefed up. The nose gear was missing
its towing loop and the torque links were basically blobs - out they went and new parts were fabricated and added to give a better
presentation.  That took a while, but I'm hoping you'll think it was worth it.
MLGS 1014   Republic P-47 "Thunderbolt"
(for Hasegawa kit)
Price:  $17.95 per set.
This set is as tough as they get - large diameter SS and music wire innards will take a licking and keep on.....well, you know the rest!
MLGS 1015   Republic P-47 "Thunderbolt"
(for Trumpeter kit)
Engineered in the same manner as the set above, but tailored for all Trumpeter P-47 kits.
Main Landing Gear Strut Replacement Sets
Each set consists of 2 pieces of stainless steel tubing, music wire of various diameters, styrene plastic or stainless steel centering ring(s) all encased in a polyurethane resin shell.
The advantages of  this combination are strength, easy clean-up and the stainless steel reveal of the oleo piston. This process eliminates the need for simulating the finish of the oleo using paint, etc., which can be tricky and frustrating. Just add the kit parts to the leg, mask the oleo and paint. Et Voila! An authentic looking landing gear strut at hand.
  • 2 weeks later...
