Patchwork paint on Navy/Marine Phantom
When I look at the patchwork looking paint on these planes am I seeing darker paint that may have been repair work? Maybe replaced panels? Also, the panel lines on the fuselage aft of the national insignia always seem to stand out more than other parts of the plane. Is that due to heat?
Grime/wear/tear, Vietnam environment, corrosion control paint touchups, etc. Can find many random patchwork appearance for the "old" airframes as they continued to serve in SEA. The fuselage area especially could also have a lot of boot scuffs along the top, side, and around the wing root area as maintenance climbed up/down that area relatively frequently and would scrape their boots (heel/toe) along the whole area. Several panels on the center fuselage area were removable for maintenance component access with screw head fasteners, and woudn't be unusual to see darker/fresh paint sprayed along the edge over the fasteners. Here's a pretty scruffy looking example (post from Facebook):
Thank you Ziggy. I want to try to replicate some of that on my Red Devils Phantom build.
4 hours ago, Jennings Heilig said:
It's more likely just corrosion control touchups, rather than "repairs" per se.
Sometimes it looks like an old Chevy that someone took a rattle can of primer to. I want to do some of this but just need to be careful not to over do it. I'm learning that less is best.
1 hour ago, Finn said:
It's not hard to tell this Phantom had a replacement panel installed, or maybe it was put on the other way around on top of the spine:
Panels can’t be put on the wrong way around.  They only fit one way.  That’s a replacement panel from a different aircraft.
Yes panels are supposed to fit one way only, that's why they have one or two different size screws or bolts so the panel does get put on the right way however some can go on anyway that fits. Check the 0 on the tail of this F-8:
ac13db43ed39a32d_large
Jari
