Marcel111 Posted September 12, 2020 Share Posted September 12, 2020 I received these in the mail yesterday, to my eye they look great. The battery in my vernier is empty so I didn't get any measurements but they align closely with the Sierra Hotel exhausts. I will be using these on my Revell F-4G but if I was building the Tamiya F-4 I'd also be using these. Molding is perfect and entirely free of any errors. I'm assuming this brand was started by someone that worked at one of the major resin aftermarket outfits before, the set looks perfectly produced and packaged. Cheers, Marcel johncrow, Tony T, Daniel Leduc and 5 others 6 2 Link to comment Share on other sites More sharing options...
firefly7 Posted September 12, 2020 Share Posted September 12, 2020 Thank you Marcel for showing this to us. Looks great. Marcel111 1 Link to comment Share on other sites More sharing options...
phantomdriver Posted September 12, 2020 Share Posted September 12, 2020 I was sadly disappointed with the SH cans, after having had a lot of success with their stuff previously. The flameholders, which were cast integral to the can itself, were moulded blank at the rear, with no way to cleanly hollow the gaps. After 3 unanswered emails over 2 months, I dumped them in a box. These ones look a lot better to work with.. Link to comment Share on other sites More sharing options...
Dave Williams Posted September 12, 2020 Share Posted September 12, 2020 Since they say they are made for the Revell kit, I wonder how they would fit in the Tamiya kit? Link to comment Share on other sites More sharing options...
Ben Brown Posted September 12, 2020 Share Posted September 12, 2020 4 hours ago, Dave Williams said: Since they say they are made for the Revell kit, I wonder how they would fit in the Tamiya kit? Many years ago I adapted some Revell nozzles to my Tamiya F-4E. I had to remove the bar that connected the two burner tubes, thin the plastic all around the aft fuselage, and I think I also had to cut a chunk out on each side of the most forward part of the keel between the engines. I would guess that these nozzles could be adapted with a little bit of work. Ben Link to comment Share on other sites More sharing options...
Marcel111 Posted September 13, 2020 Author Share Posted September 13, 2020 (edited) On 9/12/2020 at 4:58 PM, phantomdriver said: I was sadly disappointed with the SH cans, after having had a lot of success with their stuff previously. The flameholders, which were cast integral to the can itself, were moulded blank at the rear, with no way to cleanly hollow the gaps. After 3 unanswered emails over 2 months, I dumped them in a box. These ones look a lot better to work with.. I have built a total of four Sierra Hotel exhausts and to me they remain the gold standard. Accurate and easy to assemble, I've never had an issue. The cradle Erik cleverly designed ensures that the cans can be gently press-fit into the back without requiring glue: If the SH exhausts were readily available I'd for sure choose those for the Tamiya kit but since that is not the case I think it's great to have what at first glance seems to be a very nice alternative. Cheers, Marcel Edited September 14, 2020 by Marcel111 Tony T and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
