mozart Posted September 6, 2020 Share Posted September 6, 2020 Definitely the right decision to open her up Kev, you’d have been kicking yourself forever if you hadn’t! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
dennismcc Posted September 6, 2020 Share Posted September 6, 2020 Go for it Kev, just don't get bogged down. Cheers Dennis LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 6, 2020 Author Share Posted September 6, 2020 36 minutes ago, dennismcc said: Go for it Kev, just don't get bogged down. That's what I'm worried about! However, cockpit detailing has begun... Kev Anthony in NZ and dennismcc 2 Link to comment Share on other sites More sharing options...
VW Chris 1969 Posted September 6, 2020 Share Posted September 6, 2020 Hi Kev Oooo this looks good and is a very interesting project. Good luck with your build and I think tge opendd up side hinged canopy would certainly look great.are you opening the back too? It's a great kit and a bit of work can make it pop. Thank you @mozart (Max) for your kind words fella. I am grateful for your support throughout the build. All the best Chris LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Simmo.b Posted September 8, 2020 Share Posted September 8, 2020 Nice work Kev, good to see you back at it!!! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 8, 2020 Author Share Posted September 8, 2020 31 minutes ago, Simmo.b said: Nice work Kev, good to see you back at it!!! Thanks, Brent. My enthusiasm is now back full bore. As I always say: modelling is like sex - more fun doing it than watching it. Kev mozart, BiggTim and D.B. Andrus 2 1 Link to comment Share on other sites More sharing options...
RadBaron Posted September 8, 2020 Share Posted September 8, 2020 (edited) That's looking excellent, Kev! Edited September 8, 2020 by RadBaron LSP_Kevin 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted September 8, 2020 Share Posted September 8, 2020 Nice technique Kevin LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Derek B Posted September 8, 2020 Share Posted September 8, 2020 Good stuff Kev Derek LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 8, 2020 Author Share Posted September 8, 2020 Right, time for an update! I've spent most of the last 3 days scratch-building a replacement instrument panel, having already decided to go to town in the cockpit. And yes, I did check to see if there were any aftermarket options available, first! Sadly, not to be. In fact, apart from the odd decal sheet, there's virtually no dedicated aftermarket for this kit at all. I elected to go with the tried-and-true 'sandwich' method, whereby you sandwich a sheet of acetate (or other clear plastic) between a back plate and the instrument panel itself. Here's the result: I'll let you guys figure out which is the kit part. Remember, this is several times larger than the actual item! I relied heavily on the wondrous gift to superdetailers and scratch-builders that is airscale's range of decals and photo-etch sets. I did set out describing how I built this in some detail, but started to bore even myself, so if you have any questions, just sing out. I've also been working on improvements to the empennage, and have started rebuilding the cockpit interior, but will leave that for another update. Kev Chris Wimmer, Len Turner, Trak-Tor and 21 others 23 1 Link to comment Share on other sites More sharing options...
Derek B Posted September 8, 2020 Share Posted September 8, 2020 Very convincing, well done Kev Derek LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 8, 2020 Author Share Posted September 8, 2020 7 minutes ago, Derek B said: Very convincing, well done Kev Derek Thanks, Derek! Given my faltering eyesight and wavering confidence after a layoff, I'm pretty happy with it. It's definitely not perfect, but infinitely better than what Matchbox would have you use. Sure, I could've dressed up the kit part, and both Max and Eric did that to pretty good effect, but I figured if I'm going all out, then I had to do better. Kev BiggTim, Whitey and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
Derek B Posted September 8, 2020 Share Posted September 8, 2020 5 minutes ago, LSP_Kevin said: Thanks, Derek! Given my faltering eyesight and wavering confidence after a layoff, I'm pretty happy with it. It's definitely not perfect, but infinitely better than what Matchbox would have you use. Sure, I could've dressed up the kit part, and both Max and Eric did that to pretty good effect, but I figured if I'm going all out, then I had to do better. Kev Your increase in modelling skills and self confidence will thank you for it! Derek LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Whitey Posted September 8, 2020 Share Posted September 8, 2020 Very nice work with that panel Kev. Looks very convincing indeed. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
mozart Posted September 8, 2020 Share Posted September 8, 2020 Infinitely better Kev than the Matchbox pig’s ear of a panel! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
