kensar Posted September 13, 2020 Author Share Posted September 13, 2020 I have made the tail surfaces by laminating 0.010" skins embossed with the rib detail onto 0.020" cores. I have cut the ailerons free from the wing and made the pulleys for the aileron cable system. The ailerons are operated by an external cable system. The pulleys were made on my lathe. Thanks for looking. Derek B, Anthony in NZ, Rockie Yarwood and 12 others 14 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 13, 2020 Share Posted September 13, 2020 Great work, Ken! I've edited the image links in your post, as they were using bbCode, and with the latest upgrade to the forum software, bbCode is no longer supported. All you have to do from now on is copy/paste the direct image URL, which should look something like so: https://i.postimg.cc/ZK4PSwg8/Avro504-37.jpg Just paste that in and hit enter/return, and your image will display! Kev Link to comment Share on other sites More sharing options...
kensar Posted September 13, 2020 Author Share Posted September 13, 2020 Thanks, Kevin. I was wondering why it wasn't working. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Sabre F-86 Posted September 16, 2020 Share Posted September 16, 2020 I've been looking at the A-Model Dornier Wal I picked up a couple of weeks ago and comparing it to my scratch built Wal built using the Wilhelmshaven paper model as a pattern. The new wing I rough sanded out of pink foam is going to be the basis for the ongoing build. I like your method, especially for dealing with the camber. I suspect I will be doing something similar, but using the foam core with a solid leading edge and .010 sheet with the embossing. Going to be a while before I get to it, but the core as made is about 7 inches too long so I can shorten it and use the off cut to experiment on. Derek B 1 Link to comment Share on other sites More sharing options...
kensar Posted September 22, 2020 Author Share Posted September 22, 2020 (edited) I have gotten the lower wings to a point where I need the fuselage to align some details, so I have started on the fuselage. The seats are mounted on two rails running through the fuselage. The seat backs are aluminum and the rest is wood, except for the control stick assembly. The basic fuse sides. Don't know why these links are showing and not the pictures? Edited September 22, 2020 by LSP_Kevin Fixed image links MikeMaben, Derek B, nicolas96 and 9 others 12 Link to comment Share on other sites More sharing options...
kensar Posted September 22, 2020 Author Share Posted September 22, 2020 Thanks, Kevin. What did I miss in the posting? Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 22, 2020 Share Posted September 22, 2020 23 minutes ago, kensar said: Don't know why these links are showing and not the pictures? I've fixed them by using the 'Insert image from URL' feature, available from the 'Other Media' drop-down menu at the bottom right of the post edit window. But to answer your question, I think I've figured out this particular edge case now. It seems that you're copying a rich text URL from somewhere, which contains hyperlink formatting. The forum software sees this as a generic URL, rather than a link to an image, and so only gives you a URL, rather than an embedded image. Using the 'Insert image from URL' feature gets around this, but the secret to avoiding it in the first place is to make sure you only copy a plain text URL. The main way to tell the difference is that if the one you're copying already has an underline beneath it, then it's rich text, rather than plain text. Kev kensar 1 Link to comment Share on other sites More sharing options...
Bobs Buckles Posted September 23, 2020 Share Posted September 23, 2020 Superb work vB Link to comment Share on other sites More sharing options...
kensar Posted September 29, 2020 Author Share Posted September 29, 2020 (edited) Thanks, Bob. Okay, I'll try this again. A couple of pictures with a little color. I've painted the sides their basic colors. Now waiting for the oils to dry. Here is the seat assembly in a darker wood color. I switched to the lighter color, which I believe is more accurate. Thanks for looking in. Edited September 29, 2020 by kensar MikeMaben, scvrobeson, LSP_Kevin and 8 others 11 Link to comment Share on other sites More sharing options...
RadBaron Posted September 29, 2020 Share Posted September 29, 2020 Stellar work! Link to comment Share on other sites More sharing options...
kensar Posted October 10, 2020 Author Share Posted October 10, 2020 (edited) Continuing with the interior. Basic colors. Adding more details. The fuel tank and intake pipes are unpainted as yet. Will be joining the two sides together soon. Edited October 10, 2020 by kensar nicolas96, Brett M, Rockie Yarwood and 7 others 10 Link to comment Share on other sites More sharing options...
Kagemusha Posted October 10, 2020 Share Posted October 10, 2020 Coming on a treat, thoroughly enjoying the process, but can't wait to see it finished. Link to comment Share on other sites More sharing options...
VW Chris 1969 Posted October 11, 2020 Share Posted October 11, 2020 Oh wow this is fantastic work. Looks absolutely stunning. Great job. Chris Link to comment Share on other sites More sharing options...
kensar Posted October 20, 2020 Author Share Posted October 20, 2020 Working on the interior still. I made footboards. On the real thing these are stamped aluminum covering wood cores. Here I glued wire on shaped styrene and coated with fiberglass resin before painting. Made a belt from masking tape. A simple design - not like a modern harness. I have the two fuse sides together with a few more details added. The air pump that can be operated by either occupant is prominent on the right side. A few more things to do on the bottom, then the IP is next. LSP_Kevin, Basta, Rockie Yarwood and 3 others 6 Link to comment Share on other sites More sharing options...
kensar Posted November 1, 2020 Author Share Posted November 1, 2020 More progress. The rear fuselage is boxed in and I have the IP completed. Installing the IP is next. Thanks for looking in on this project. geedubelyer, Derek B, Brett M and 10 others 13 Link to comment Share on other sites More sharing options...
