JimRice 392 Posted August 21, 2020 Share Posted August 21, 2020 Received my ICM Stearman today and did a quick down and dirty side-by-side comparison. Below is a quick summary and some pictures. Pardon errors in grammar and spelling as this was a quick effort. While I really like the Roden offering and thought it built up well, I think the ICM is even better. Initial thoughts... Naturally, the are quite similar in breakdown and general appearance. Wings match up with exception of curve on rear of upper wing center sections are a bit different, fuselages match up, tail surfaces seem to match. Aileron are a bit different. N struts on Roden were a bit longer, while ICM were a bit thicker and looked better. They also have substantial locating stubs which will fit sockets on the wing. The ICM lower wing is better engineered and should help with alignment and consequently fit of top wing. Roden's was a bit of a fight to get mounted in proper alignment and get all struts fitted due to tiny alignment holes/pins. Very similar breakdown and assembly per instructions. Overall, the engineering seems much nicer on the ICM. The engine has less tiny parts which require assembly, but similar level of detail. ICM landing gear is a bit heavier using a rectangular stub to insert into the fairing, but is still fairly small for the size of the model. The axles are a cone shape which should help with alignment vertically and longitudinally. Absolutely no flash found on ICM vs some minor flash on Roden. Fabric over ribs and stringers more subdued on ICM with no visibible rib stitch bumps or wide flat rib tops of Roden. Same for fabric on fuselage over stringers. While Roden looked fine when finished, I expect the ICM will look even better. Neither have over done fabric weave so often seen. ICM internal fuselage framing is thinner and more scale appearing, though I expect it will be quite fragile. Detail on interior parts seem more crisp and defined. ICM clear parts are much more crisp, smooth and crystal clear. ICM also provides both McCauley steel prop and Sensenich wood props. ICM does not have the over thick cabane strut X brace wires molded in between front and rear struts on each side of fuselage as does Roden, but it also doesn't have the fuel lines included at all, which are highly visible on a Stearman. I look forward to building this one too and will try to have an in progress post as well once I begin. In photo, Roden is on left/top and ICM is right/bottom in comparison shots. Hopefully they show sufficient detail for everyone to get an idea. Basta, LSP_Kevin, Lothar and 8 others 7 4 Link to post Share on other sites
JimRice 392 Posted August 21, 2020 Author Share Posted August 21, 2020 Just a note, I bought both Roden (2x) and ICM kit from Ukraine. Both had shipping included. One ICM kit cost same as I paid for two Roden kits, about $80. They were possibly premium prices because I ordered them both as soon as I found them, before either was showing officially released anywhere. It will be interesting to see what actual prices are once initial rush is over. Out2gtcha and Stefano 1 1 Link to post Share on other sites
LSP_Kevin 31,502 Posted August 21, 2020 Share Posted August 21, 2020 Thanks for the comparison, Jim! Very interesting indeed. Kev Link to post Share on other sites
Pup7309 579 Posted August 21, 2020 Share Posted August 21, 2020 Great! Seems like a popular subject Link to post Share on other sites
Jennings Heilig 15,028 Posted August 21, 2020 Share Posted August 21, 2020 Thanks for the comparison. Quite interesting! Link to post Share on other sites
Out2gtcha 35,209 Posted August 21, 2020 Share Posted August 21, 2020 Thanks for that. It confirms I'd really like to get a copy of the ICM kit. Link to post Share on other sites
Bradleygolding 350 Posted August 21, 2020 Share Posted August 21, 2020 The ICM does look better in general and detail, but it lacks the very popular Jacobs front ignition type harness seen on may Stearmans. The Roden kit has it and I guess I could scratch one. Steve Link to post Share on other sites
Jennings Heilig 15,028 Posted August 21, 2020 Share Posted August 21, 2020 37 minutes ago, Bradleygolding said: The ICM does look better in general and detail, but it lacks the very popular Jacobs front ignition type harness seen on may Stearmans. The Roden kit has it and I guess I could scratch one. Steve ICM has a long history of boxing its kits in multiple variants (I’ve lost track of the number of I-16 kits). Given that all of the Lycoming parts are on a separate sprue, it’s 100% guaranteed they’ll do a Jacobs powered PT-13. Link to post Share on other sites
JimRice 392 Posted August 21, 2020 Author Share Posted August 21, 2020 50 minutes ago, Bradleygolding said: The ICM does look better in general and detail, but it lacks the very popular Jacobs front ignition type harness seen on may Stearmans. The Roden kit has it and I guess I could scratch one. Steve I didn’t use it on my Roden. They weren’t used in Military service. Several modern restorations have them. They were popular before shielded wires became the norm and a radio was needed. Now a days, the ignition shielding is inside the wiring harness negating the need for the forward mounted shilling harness. Kagemusha 1 Link to post Share on other sites
AlbertD 1,414 Posted August 21, 2020 Share Posted August 21, 2020 Thanks for the comparison. I have the Roden kit and will pick up an ICM version. Link to post Share on other sites
JimRice 392 Posted August 21, 2020 Author Share Posted August 21, 2020 (edited) 23 hours ago, Jennings Heilig said: ICM has a long history of boxing its kits in multiple variants (I’ve lost track of the number of I-16 kits). Given that all of the Lycoming parts are on a separate sprue, it’s 100% guaranteed they’ll do a Jacobs powered PT-13. The PT-13 was Lycoming powered. The PT-18 was a Jake powered version but was not produced in volume. The Stearmans flying today with the R-755 are mostly all PT-13/17 or N2S which have been transplanted with Jakes. Pete Jones Of Air Repair fame obtained the STC IIRC and holds the Type Certificate for the R-755. FWIW, my dad used a Jake on his Stearman dusters. While only 25more horsepower, the extra 85 cubic inch displacement is what made the difference and could swing a bigger prop or at least a ground adjustable set to higher pitch. He wasn’t a big fan of R-985 Stearmans. They burned too much gas and were too heavy on the controls. And he had over 10.000 hours in them. Edited August 22, 2020 by JimRice Kagemusha and MikeC 2 Link to post Share on other sites
esarmstrong 461 Posted August 21, 2020 Share Posted August 21, 2020 One thing I see on the Roden Kit that appears absent on the ICM Kit:. Rib tape detail. Link to post Share on other sites
RadBaron 989 Posted August 21, 2020 Share Posted August 21, 2020 Very interesting post! Link to post Share on other sites
Kagemusha 9,175 Posted August 21, 2020 Share Posted August 21, 2020 Thanks Jim. Link to post Share on other sites
mozart 12,224 Posted August 21, 2020 Share Posted August 21, 2020 ICM gets my vote, they really are the company of the moment. Forget all these speculative posts on Tamiya, they’re has-beens! MikeC, Lothar and Rick Griewski 2 1 Link to post Share on other sites
