daveoh Posted August 7, 2020 Share Posted August 7, 2020 Hello fellow large scale modellers, I'm building a hobbyboss 1/18 harrier. And I'm after putting a map in the windscreen. I've looked on the internet for a model map but I'm struggling to find any. Also my printer isn't playing ball while I try to print one. I'm thinking surely some model company does maps in various scales for diorama's. As I'm in the UK I'm not really wanting to buy abroad. Any help much appreciated. Link to comment Share on other sites More sharing options...
Kagemusha Posted August 7, 2020 Share Posted August 7, 2020 Verlinden did some, and there's a couple here, ah it doesn't give a direct link, if you put map in search you'll find a couple. Link to comment Share on other sites More sharing options...
thierry laurent Posted August 7, 2020 Share Posted August 7, 2020 Quite simple: Do it yourself! Save a navigation map from the web (e. g. http://legacy.lib.utexas.edu/maps/onc/middle_east.html). Insert it in a Word page, re-dimension it and print it. Done! It is not even required finding one from one specific area as when folded, any map will look ok as far as the type is ok. Hth Thierry LSP_K2, MikeC, R Palimaka and 3 others 6 Link to comment Share on other sites More sharing options...
R Palimaka Posted August 7, 2020 Share Posted August 7, 2020 As Thierry says, very easy to print your own. I did the same for my 1/24 Mustang, searching online I was able to find an air navigation map from the 1950s that worked perfectly. Just resize it, print it on a colour printer/copier, and cut it out. Make sure you fold it properly when you tuck it away. Richard MikeC and Jack 1 1 Link to comment Share on other sites More sharing options...
JimRice Posted August 8, 2020 Share Posted August 8, 2020 I have several old aeronautical charts ranging from 40-60s and several expired recent sectionals. They are all Central US. I can take some photos you could reduce and print if you like. thierry laurent 1 Link to comment Share on other sites More sharing options...
JimRice Posted August 9, 2020 Share Posted August 9, 2020 Yes, they are still available. I keep a couple (because I live in an area on edge of two charts) in both my planes Piper J-3 and Van’s RV-4. Occasionally the electronics quit or GPS signal is disrupted. For actual inflight use, I typically use my iPhone or a dedicated iPad Mini. I also keep a paper Memphis Terminal Area chart (TAC) handy because of the large scale is frequently quicker and easier to grab and use tha paging through the electronic gizmo. I will admit, the moving map on dedicated GPS and iPad makes navigation easy...and can make one lazy. Sometimes practicing old school pilotage and visual navigation is good to stay in practice. Link to comment Share on other sites More sharing options...
oldthudman5 Posted August 27, 2020 Share Posted August 27, 2020 Seems I ran across a few, but that was 10-15 years ago.......I'll see if I can find them to get suppliers name......... In the mean time, here's what I've used..........Go to cigarette counter at grocery store, or a Walmart gas pump station, etc, etc, check local stop n shop...anywhere the sell cigarettes. Look for/ask for roll your own cig ""Papers""....Very thin white paper.....you can draw your map on it color them.....you can make them look pretty convincing Link to comment Share on other sites More sharing options...
Bob MDC Posted August 27, 2020 Share Posted August 27, 2020 You could try the model truck sites they have all sorts for cab interiors 1/24 or 1/25 but it could be a start. Bob Link to comment Share on other sites More sharing options...
Hawkwrench Posted August 28, 2020 Share Posted August 28, 2020 On 8/8/2020 at 5:31 PM, JimRice said: I have several old aeronautical charts ranging from 40-60s and several expired recent sectionals. They are all Central US. I can take some photos you could reduce and print if you like. Along with the color sectional chart, can you send a pic of an approach plate too? Please? Thanks Tim Link to comment Share on other sites More sharing options...
JimRice Posted August 28, 2020 Share Posted August 28, 2020 Would you like old sectional or modern? Old ones from 40-60s are here at home. Modern ones are mostly at the airport in my hangar. Link to comment Share on other sites More sharing options...
Hawkwrench Posted August 28, 2020 Share Posted August 28, 2020 In 1/35 and folded, I don't think it will be noticable. Tim Link to comment Share on other sites More sharing options...
coogrfan Posted August 28, 2020 Share Posted August 28, 2020 On 8/7/2020 at 2:23 PM, daveoh said: Hello fellow large scale modellers, I'm building a hobbyboss 1/18 harrier. And I'm after putting a map in the windscreen. I've looked on the internet for a model map but I'm struggling to find any. Also my printer isn't playing ball while I try to print one. I'm thinking surely some model company does maps in various scales for diorama's. As I'm in the UK I'm not really wanting to buy abroad. Any help much appreciated. https://duplicata-productions.myshopify.com/collections/toys-hobbies-models-kits-military-armour They make maps in a variety of scales. I purchased a couple sets of these a while back for a 1/48 project and was quite please with the results. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Sabre F-86 Posted September 1, 2020 Share Posted September 1, 2020 BTW, I was once at an Armor workshop, and the instructor showed us how to make posters and map appear more like paper that like a sheet of plywood. Soak them in water first and then gently rub the back paper off of them. Practice on any printed item, it takes a gentle touch. coogrfan 1 Link to comment Share on other sites More sharing options...
JimRice Posted September 2, 2020 Share Posted September 2, 2020 Here are three sectionals. You can see the difference between the three. I thought I had some current ones now my truck but must have put them in the hangar. Memphis airspace is vastly different than fifty years ago. Memphis 1969 Little Rock 1966 Little Rock 1943 coogrfan 1 Link to comment Share on other sites More sharing options...
