Anthony in NZ Posted January 16, 2021 Author Share Posted January 16, 2021 6 minutes ago, vvwse4 said: Hi Anthony, Great work as usual. Maybe use a empty beercan for the vents? Cheers Rick Thanks, and that's a good idea Rick! Might have to drink a few in case I make mistakes AlbertD, Rainer Hoffmann and Derek B 3 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted January 17, 2021 Author Share Posted January 17, 2021 Couldnt see what I was doing with the white plastic card, so shot Mr Surfacer and....whoa, there goes a whole pile of areas that now need sorting out... In case you are wondering...most of those openings are different sizes Cheers Anthony Basta, chuck540z3, HerculesPA_2 and 20 others 23 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 17, 2021 Share Posted January 17, 2021 First class work, Anthony! Kev Anthony in NZ 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted January 23, 2021 Author Share Posted January 23, 2021 On 1/17/2021 at 7:51 PM, LSP_Kevin said: First class work, Anthony! Kev Thanks Kev! Well work continues at a glacial pace right now as I am STILL working on these intakes! Because the kit intakes were shortened a little the corresponding lower wing needed modification to keep everything in it's place. Just behind the edge of where the intakes are glued there are a row of rivets. According to my calculations and offering the parts all up together taped together I need to shorten to the rivet line. The pic below should illustrate showing one side already done. Another update soon, just got to take a couple of pics for you all. Cheers Anthony Landrotten Highlander, airscale, Greg W and 8 others 11 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted January 23, 2021 Author Share Posted January 23, 2021 Here we are at the intakes...did I mention this is a massive job???LOL. But I think if you see how I have tackled it, then it might make it a little easier and quicker. As I say there are probably other ways, but this is just how I have decided to go about it. Both top vent boxes are done (and match-phew) but I still need to add the louvers. But I am just finishing up the lower ones before I tackle that. I have taped them to the WH resin fuse to see where I need to be as I know this area is going to be a mess due to the fact this area was widened too much. I can slowly see the more accurate 'coke bottle' shape starting to emerge However you will start to see the issue between the resin fuselage and accurate (I believe) intakes. Notice the 'dip between the 2? The actual shape is somewhere between the two here it is close up Interestingly what I can now see is how the Spey engine thrust line must effect the intake trunking. and structure shape, and why the shoulder is higher at its junction with the upper fuse spine area on Brit Phantoms. I will address those shapes in another post As always thanks for tuning in Anthony Rainer Hoffmann, Derek B, Kagemusha and 18 others 19 2 Link to comment Share on other sites More sharing options...
airscale Posted January 23, 2021 Share Posted January 23, 2021 simply a masterclass Peter AlbertD, Anthony in NZ, Greg W and 1 other 4 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted January 23, 2021 Author Share Posted January 23, 2021 2 minutes ago, airscale said: simply a masterclass Peter Awww thanks Link to comment Share on other sites More sharing options...
AlbertD Posted January 24, 2021 Share Posted January 24, 2021 You sure do some nice work Anthony. Derek B and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
Derek B Posted January 24, 2021 Share Posted January 24, 2021 That is looking fantastic Anthony (and certainly does appear to capture the look of a Spey Phantom); from memory, I think that the Spey thrust line inclination is something like 6 degrees 45 minutes. As for vents, this must be occupying your thoughts on how to do that? I do not know which is best (there are several ways), but one approach which could provide consistency is to make a large batch of them as a single set (as a separate item) and then cut them to fit the vent box shape afterwards. By stacking oversize wide (but thin) plastic strips of plastic in between much narrower strips (of the correct spacing thickness), they can then be set (by clamping or supporting in some manner) at the correct angle and be glued together. Once dried, the angled vents can be sanded at the bottom (to thin out the narrower plastic strip thickness), and be cut to shape to match the vent box - you can the sand the top of the vents flush with the surface of the vent boxes after they have been glued in place. This only one approach, there are many others! Great work and good luck Derek Anthony in NZ 1 Link to comment Share on other sites More sharing options...
KiwiZac Posted January 27, 2021 Share Posted January 27, 2021 I haven't commented here Ant but I've been watching and thoroughly enjoying this undertaking. This will be a spectacular model!! Derek B and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted January 27, 2021 Author Share Posted January 27, 2021 5 hours ago, KiwiZac said: I haven't commented here Ant but I've been watching and thoroughly enjoying this undertaking. This will be a spectacular model!! Hey buddy! I saw that you had been liking my posts and was wondering when you were going to pipe up...great to hear from you and great to have you along! Although as you will know...my NZ Aviation builds are suffering with this one On 1/25/2021 at 3:21 AM, Derek B said: That is looking fantastic Anthony (and certainly does appear to capture the look of a Spey Phantom); from memory, I think that the Spey thrust line inclination is something like 6 degrees 45 minutes. As for vents, this must be occupying your thoughts on how to do that? I do not know which is best (there are several ways), but one approach which could provide consistency is to make a large batch of them as a single set (as a separate item) and then cut them to fit the vent box shape afterwards. By stacking oversize wide (but thin) plastic strips of plastic in between much narrower strips (of the correct spacing thickness), they can then be set (by clamping or supporting in some manner) at the correct angle and be glued together. Once dried, the angled vents can be sanded at the bottom (to thin out the narrower plastic strip thickness), and be cut to shape to match the vent box - you can the sand the top of the vents flush with the surface of the vent boxes after they have been glued in place. This only one approach, there are many others! Great work and good luck Derek Thanks Derek I like your idea, I have a bit of time later tonight which I hope to finish off boxing the lower ones, then I might have a play with your idea and see if anything transpires...thank you Cheers Anthony KiwiZac and Derek B 2 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted January 27, 2021 Author Share Posted January 27, 2021 On 1/24/2021 at 1:33 PM, AlbertD said: You sure do some nice work Anthony. Thanks Al....thats a real compliment coming from you which I appreciate. Thanks go to you all for the comments and likes, I really struggle to stay focused on a subject for longer periods of time due to the standards and striving for accuracy I impose on myself Hopefully we will see the intakes epoxied on before too long...I need the visual progress myself right now Cheers all Anthony Derek B 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted January 31, 2021 Author Share Posted January 31, 2021 Ugh...I think I have hit the wall with this conversion. As you can see I have got half way through boxing in the second bleed air section and I cannot seem to find the energy to finish it Some of my other projects are starting to look rather inviting right now.... Paul in Napier, USMC Herc, LSP_Kevin and 12 others 13 2 Link to comment Share on other sites More sharing options...
Troy Molitor Posted January 31, 2021 Share Posted January 31, 2021 NO NO NO....Focus mate. Anthony in NZ 1 Link to comment Share on other sites More sharing options...
IainM Posted January 31, 2021 Share Posted January 31, 2021 Don't you dare! Push through that wall....we're loving this build!!! Landrotten Highlander, Anthony in NZ and Paul in Napier 3 Link to comment Share on other sites More sharing options...
