blackbetty Posted July 22, 2020 Share Posted July 22, 2020 cool it is! Dandiego and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 22, 2020 Share Posted July 22, 2020 Indeed! Dandiego 1 Link to comment Share on other sites More sharing options...
Oldbaldguy Posted July 23, 2020 Share Posted July 23, 2020 If this thing had made it to operational status, I wonder if it would have acquired those prominent vents in the rocket pods like those found on regular F-89s - a salvo of all those little HVARs would have made a bunch of blast/exhaust that would have to go somewhere. Great fan of Scorpions since I was a wee lad. Looking forward to seeing how this turns out. Link to comment Share on other sites More sharing options...
Dandiego Posted July 23, 2020 Author Share Posted July 23, 2020 2 hours ago, Oldbaldguy said: If this thing had made it to operational status, I wonder if it would have acquired those prominent vents in the rocket pods like those found on regular F-89s - a salvo of all those little HVARs would have made a bunch of blast/exhaust that would have to go somewhere. Great fan of Scorpions since I was a wee lad. Looking forward to seeing how this turns out. OBG, Yes I am sure that these blast vents would have been part of the design. As soon as I figure out how to make them in my 3d printer I will add them. Currently I am working on removing the existing wing roots from the fuselage. Also am figuring out how to get the re-designed aft fuselage done. Dan Link to comment Share on other sites More sharing options...
Dandiego Posted July 23, 2020 Author Share Posted July 23, 2020 Small progress. Pennies super glued into the nose. And wooden supports bolted to the plastic fuselage blank. Dan Troy Molitor, blackbetty, patricksparks and 2 others 5 Link to comment Share on other sites More sharing options...
Dandiego Posted July 24, 2020 Author Share Posted July 24, 2020 I have cut off the old wing root fairings and have filled in the opening with sheet plastic. Oh.... and just the slightest smear of putty. Thats it, Dan LSP_Kevin, themongoose, johncrow and 4 others 7 Link to comment Share on other sites More sharing options...
Dandiego Posted July 29, 2020 Author Share Posted July 29, 2020 A little work on the weapons pods. There are exhaust ports on the pods to expel rocket gases when they are fired. I determined where the exhaust ring should go and, using a miter box, cut the pods. I then 3d printed a slightly smaller ring which could be pushed into the main pod. There will be a gap between front and back sections to represent the exhaust ports. Easy..... as... pie. I have also glued one half of the fuselage to the keel. Dan Landrotten Highlander, blackbetty, Out2gtcha and 5 others 8 Link to comment Share on other sites More sharing options...
Dandiego Posted August 2, 2020 Author Share Posted August 2, 2020 Hey everyone.... I received a Set of cockpit parts from John, Thanks John. I have been working on the jet intakes and compressor faces. Here are some parts with black primer. Also sprayed the interior of the intakes. And some preliminary work on getting the cockpit parts situated. Here I have gotten the 3D printed wheel wells into the center pod. Dan Landrotten Highlander, blackbetty, MikeMaben and 6 others 9 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 2, 2020 Share Posted August 2, 2020 Wow Dan, impressive as always!! Dandiego 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted August 2, 2020 Share Posted August 2, 2020 Looking good Dan. Dandiego 1 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted August 3, 2020 Share Posted August 3, 2020 Nice progress Dan! Link to comment Share on other sites More sharing options...
Dandiego Posted August 7, 2020 Author Share Posted August 7, 2020 Working on the ejection seats and cockpits. Here is the Phantom seat next to the modified Scorpion seat. Rear cockpit, Here is the completed seat in the rear pit. Front office and seat. 3D printed console and radar scope. Gray panels are from some cut up side consoles. Dan chrish, Starfighter, Landrotten Highlander and 6 others 9 Link to comment Share on other sites More sharing options...
Dandiego Posted August 11, 2020 Author Share Posted August 11, 2020 Work continues. I have 3D printed the canopy frames. These were rather thick so I printed another set at half the thickness. I plan to glue the vac canopy on top of the frame. Here is the painted backseat radar setup. And the phantom cowling, still some changes to be made. Laminations to thicken up the tail. Some details of the cockpits. Dan Scotsman, Landrotten Highlander, Troy Molitor and 8 others 11 Link to comment Share on other sites More sharing options...
MikeMaben Posted August 11, 2020 Share Posted August 11, 2020 Link to comment Share on other sites More sharing options...
Dandiego Posted August 12, 2020 Author Share Posted August 12, 2020 More...... 3D printed exhaust cones, to replace the molded on examples. Printed fuselage spine. Fuselage finally closed up. And just the slightest smear of Bondo to blend in the wing. Dan blackbetty, scvrobeson, Out2gtcha and 4 others 7 Link to comment Share on other sites More sharing options...
