marcio bernardi Posted July 9, 2020 Share Posted July 9, 2020 thanks for the helping Out2gtcha 1 Link to comment Share on other sites More sharing options...
Steve Eagle Posted July 9, 2020 Share Posted July 9, 2020 In light of the winter setting, I have always thought this is snow or slush thrown up by the mainwheels. I had looked for info. about whether there was any equipment mounted over the years . The only thing I could postulate was some sort of frozen material . marcio bernardi and MikeMaben 2 Link to comment Share on other sites More sharing options...
marcio bernardi Posted July 10, 2020 Author Share Posted July 10, 2020 15 hours ago, Steve Eagle said: In light of the winter setting, I have always thought this is snow or slush thrown up by the mainwheels. I had looked for info. about whether there was any equipment mounted over the years . The only thing I could postulate was some sort of frozen material . in many places that I asked unfortunately nobody knows what it is your hypothesis is the most likely thanks for your helping Link to comment Share on other sites More sharing options...
Isar 30/07 Posted July 10, 2020 Share Posted July 10, 2020 I´ve never noticed this bright object on this F-8 Würger. I checked my "library" and found a note on page 542 on "Fw 190 vol two" from J. Richard Smith and Eddie J. Creek: This could have been an (experimental) camera pod, which was mounted outside the main landing gear leg. I never heard of such pods and this note is the only one I found so far. To me it is the most likely explanation of this thing as there are no bomb racks mounted on the wings (ice and/or frozen snow prior to take off when a mechanic did accompany the a/c makes no sense to me as the rest of the Würger shows no snow adhering). Why not using a camera pod on low level bombing raids to get more informations on advancing enemy troops? I will later post some pics. Reimund marcio bernardi and Gazzas 2 Link to comment Share on other sites More sharing options...
marcio bernardi Posted July 10, 2020 Author Share Posted July 10, 2020 (edited) 1 hour ago, Isar 30/07 said: I´ve never noticed this bright object on this F-8 Würger. I checked my "library" and found a note on page 542 on "Fw 190 vol two" from J. Richard Smith and Eddie J. Creek: This could have been an (experimental) camera pod, which was mounted outside the main landing gear leg. I never heard of such pods and this note is the only one I found so far. To me it is the most likely explanation of this thing as there are no bomb racks mounted on the wings (ice and/or frozen snow prior to take off when a mechanic did accompany the a/c makes no sense to me as the rest of the Würger shows no snow adhering). Why not using a camera pod on low level bombing raids to get more informations on advancing enemy troops? I will later post some pics. Reimund the shape resembles a camera thanks Edited July 10, 2020 by marcio bernardi Link to comment Share on other sites More sharing options...
mywifehatesmodels Posted July 11, 2020 Share Posted July 11, 2020 To my eye, it looks like the underwing panel for the outboard cannon is flipped open. As to why, I'm not sure, since I believe this particular aircraft didn't carry the outboard guns? John marcio bernardi 1 Link to comment Share on other sites More sharing options...
Wackyracer Posted July 11, 2020 Share Posted July 11, 2020 External mounted camera pod, need to check through my references. marcio bernardi 1 Link to comment Share on other sites More sharing options...
Isar 30/07 Posted July 11, 2020 Share Posted July 11, 2020 Sorry, no photos from my reference due to copyright regulations, but have a look here: http://www.luftarchiv.de/index.htm?/bordgerate/behalter.htm Different shape(s) and slightly different mounted comparing to Marcios photo, but maybe there were some more fairings built. Reimund Martinnfb, Lothar and marcio bernardi 2 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 12, 2020 Share Posted July 12, 2020 This cannot be ice for four reasons: 1. The shape is far too regular. 2. You should have the same ice on the other side. 3. Mechanics and pilots would never leave that on a plane before take-off. 4. An enlargement of the picture shows what looks like fixings between that item and the wing. I agree regarding the camera pod probability. This was immediately what I thought. marcio bernardi and Lothar 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 12, 2020 Share Posted July 12, 2020 3 hours ago, Jennings Heilig said: Use of copyrighted photos to illustrate something like the question in this thread is fair use. There's no reason not to use them. Absolutely. Folks here on LSP (including myself), as well as dozens of other sites, have done it for years without any issues cropping up as a result. Isar 30/07 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted July 12, 2020 Share Posted July 12, 2020 Cannon access hatch open and hinged down. Ice build up looks very different. Cheers Alan Link to comment Share on other sites More sharing options...
Oldbaldguy Posted July 15, 2020 Share Posted July 15, 2020 Lots of pix out there of G-8s with three hard points -- one on the centerline for a BFB and one outboard of each gear that is ensconced in a whopping big fairing and often sports a drop tank. There is a BFB on the centerline rack of the a/c in question; irrelevant, just sayin'. The gizmo in question looks to me like a damaged whopping big fairing outboard of the main gear (See above) torn in half longways with the bottom part hanging by a thread, as it were. Could be battle damage, could have been damaged by ground equipment, or maybe the guy taxied into something and banged it up. We don't know why, but sure as the world it is damaged/crushed/ripped/torn sheet metal that is no longer streamlined and it sure ain't no Leica. And don't tell me you can't see it once you really look at the photo. Link to comment Share on other sites More sharing options...
Martinnfb Posted July 16, 2020 Share Posted July 16, 2020 Ziess camera pod. had several variations throughout the war, that is one of them. https://i.pinimg.com/originals/74/62/99/746299fb2a60129aa52a9484eaeb85af.jpg Out2gtcha and TAG 2 Link to comment Share on other sites More sharing options...
Martinnfb Posted July 16, 2020 Share Posted July 16, 2020 TAG 1 Link to comment Share on other sites More sharing options...
Oldbaldguy Posted July 16, 2020 Share Posted July 16, 2020 Hmmm. I'm considering the unimaginable possibility that I might be wrong. Could very well be a camera pod that is configured a little differently than the ones in the photos above and not a wrecked pylon fairing after all. Okay. You win. Martinnfb 1 Link to comment Share on other sites More sharing options...
