Pup7309 Posted June 23, 2020 Posted June 23, 2020 (edited) Hi. Was looking at a few Japanese 1/32 Hasegawa kits. Plenty of positive online reviews. Any recommendations? How do they compare to the 90s 1/48 kits and recent 1/32nd kits from other companies, if you know. I believe Tamiya are a slight cut above but the recent Hasegawa 1/32 kits are nice, simple but also have great fit and detail. Happy to hear your thoughts... Edited June 23, 2020 by Pup7309
thierry laurent Posted June 23, 2020 Posted June 23, 2020 The Ki 44, Ki 61, Ki 84, N1K2J, J2M and recent A6M5/A6M7 are good, accurately shaped and quite often easy to build if a little bit basic kits. However, out of Japan, they are proportionally more expensive than similar kits from other manufacturers. The old A6M5 and Ki 43 are now quite outdated. Pup7309 1
dennismcc Posted June 23, 2020 Posted June 23, 2020 (edited) I'm just finishing up the 1/32 scale Hasegawa N1K2-J kit the third Japanese WW2 kit that I have been building this year, the other two were the Raiden and Hayate, all are really nice to build, well engineered and a pleasure to build. Cheers Dennis Edited June 23, 2020 by dennismcc Pup7309 1
Pup7309 Posted June 23, 2020 Author Posted June 23, 2020 (edited) 7 minutes ago, thierry laurent said: The Ki 44, Ki 61, Ki 84, N1K2J, J2M and recent A6M5/A6M7 are good, accurately shaped and quite often easy to build if a little bit basic kits. However, out of Japan, they are proportionally more expensive than similar kits from other manufacturers. The old A6M5 and Ki 43 are now quite outdated. Hi yes thanks. Tamiya is best pick for a Zero I believe. The online reviews were done in the nineties and naughtiest so I guess they were cutting edge then. I’m looking for something less complicated than the ZM/ WNW kits as a break. Fuselages that just close up around the engine in a few pieces etc. Hopefully won’t be let down by the surface details but from what I can see looks pretty decent Edited June 23, 2020 by Pup7309
Pup7309 Posted June 23, 2020 Author Posted June 23, 2020 4 minutes ago, dennismcc said: I'm just finishing up the 1/32 scale Hasegawa N1K2-J kit the third Japanese WW2 kit that I have been building this year, the other two were the Raiden and Hayate, all are really nice to build, well engineered and a pleasure to build. Cheers Dennis Good to know! I was thinking of the ki84, ki44 and Raiden
Pup7309 Posted June 23, 2020 Author Posted June 23, 2020 Just out of interest how do their Fw 19Os go? Do they stack up or are there better builds out there?
thierry laurent Posted June 23, 2020 Posted June 23, 2020 Their A and F are less detailed than the recent Revell ones (e.g. no full engines). So they are easier to build but if you want some fine details, you will need aftermarket items (e.g. new exhausts). For the D, there are no other "recent" option. Pup7309 1
hworth18 Posted June 23, 2020 Posted June 23, 2020 I'm pretty sure that most of the Hasegawa 1/32 molds besides the new tool A6m5c and George are over 20 years old. But I think the Hasegawa molds still stand up to the newer molds when it comes to accuracy and build. LSP_K2 and Pup7309 2
Juggernut Posted June 23, 2020 Posted June 23, 2020 (edited) I think the oldest, “new tool” Japanese kit is the Ki-84 Hayate. That may be getting close to 20 but I don’t think it’s there yet. I’d have to check the database to see though. Yep, the Ki-84 was originally released in 2005, so only 15 years. All the rest are newer. Edited June 23, 2020 by Juggernut hworth18 and Pup7309 2
Brad-M Posted June 23, 2020 Posted June 23, 2020 I think their Ki-84 Frank kit is their best kit in 1/32 scale. Fit is Tamiya quality, and detail is perfect. Just add a new seat and you are good to go. Pup7309, LSP_K2, coogrfan and 1 other 4
LSP_K2 Posted June 23, 2020 Posted June 23, 2020 I've built two; Ki-61 and N1K2 and really liked them both. Both ended up mangled to one degree or another, but that was a reflection of my own ham fistedness, no fault of the kits. Pup7309 1
Neo Posted June 26, 2020 Posted June 26, 2020 (edited) I built the ki-84 years back and i have to say was a very enjoyable build. Has to be in my top 5 kit/results The only thing i put was the eduard pe set My only redo would be the antena Edited June 26, 2020 by Neo Pup7309 1
AdamR Posted June 30, 2020 Posted June 30, 2020 Ki-84 was my favorite. Very low-stress build. Needs a teeny bit of AM help in the cockpit, but overall a fine kit.
