dodgem37 Posted January 31, 2021 Share Posted January 31, 2021 Great. You're beginning to look a bit like a Matchbox kit with those different plastic colors! Not worth mentioning at this point, and it's a micro detail, but sometimes even I can't help myself, anyway. To the right where the two arms intersect with the hollow cylinder, the cylinder should have a horizontal line running thru it, otherwise, the arm won't swivel. Just sayin'. Sincerely, Mark GMK and USMC Herc 1 1 Link to comment Share on other sites More sharing options...
GMK Posted January 31, 2021 Author Share Posted January 31, 2021 2 minutes ago, dodgem37 said: Great. You're beginning to look a bit like a Matchbox kit with those different plastic colors! Not worth mentioning at this point, and it's a micro detail, but sometimes even I can't help myself, anyway. To the right where the two arms intersect with the hollow cylinder, the cylinder should have a horizontal line running thru it, otherwise, the arm won't swivel. Just sayin'. Sincerely, Mark Thanks Mark - certainly almost ready for paint! I appreciate the detail feedback. I’m lucky enough to have been provided with references from the manufacturer....but made some compromises to insert rods for strength & due to limitations of detail. With the resin printer up & running, I can make details a little truer to reality. Link to comment Share on other sites More sharing options...
GMK Posted February 9, 2021 Author Share Posted February 9, 2021 Well, the resin printer (Elegoo Mars) delivered, both a steep learning curve & an uptick in quality. Here is the improved design details of the wire cutters, adding nuts, bolts, cotter pins, & rings. Here’s the print, still with supports. Other side: Very happy with the additional detail. Starfighter, Anthony in NZ, dodgem37 and 2 others 5 Link to comment Share on other sites More sharing options...
GMK Posted February 10, 2021 Author Share Posted February 10, 2021 Looks like Murphy’s law of modelling is partially coming true - a kit will become available once a scratch build is more or less complete. Dragon has announced a couple of 1/72 Bushmasters, a British SAS one & an Australian one. Meanwhile, on my 4.5 times larger version, I’ve had a crack at the windscreen frame. Anthony in NZ, Rockie Yarwood, USMC Herc and 3 others 6 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 11, 2021 Share Posted February 11, 2021 'Dragon has announced a couple of 1/72 Bushmasters, a British SAS one & an Australian one.' They found your work inspirational and needed to do one themselves. Good show. Sincerely, Mark GMK 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted February 11, 2021 Share Posted February 11, 2021 Yours is in the right scale and utterly superb! Your printer seems to be really hi-resolution? Nice smooth print surface looking at the pics on my screen Loving this, keep up the great work! GMK 1 Link to comment Share on other sites More sharing options...
GMK Posted February 11, 2021 Author Share Posted February 11, 2021 8 hours ago, dodgem37 said: 'Dragon has announced a couple of 1/72 Bushmasters, a British SAS one & an Australian one.' They found your work inspirational and needed to do one themselves. Good show. Sincerely, Mark Too kind, Mark. Wish they’d scale theirs up a little, tbh. 20 minutes ago, Anthony in NZ said: Yours is in the right scale and utterly superb! Your printer seems to be really hi-resolution? Nice smooth print surface looking at the pics on my screen Loving this, keep up the great work! Thanks Anthony. My resin printer is an Elegoo Mars, quoting a Google search has a “...standard XY resolution of 0.047 mm & a minimum layer height of 0.01 mm.” This contrasts with the resolution of the Snapmaker A350 (the big printer) of 0.05mm (XYZ axes). Anthony in NZ 1 Link to comment Share on other sites More sharing options...
GMK Posted February 13, 2021 Author Share Posted February 13, 2021 More small part work today. Hinges for the front grill, antennae for the VHF radios, & blanking plates for the AMU mounts. (of course) Australia had unusual VHF antenna. Onto the truck, which also has the blanking plates & window frames. Fit check on the BFT adaptor with a blanking plate on the rear left antenna riser. And the hinges & handles on the front end. patricksparks, Uncarina and dodgem37 3 Link to comment Share on other sites More sharing options...
Robthepom Posted February 13, 2021 Share Posted February 13, 2021 wow i have not logged on for few months.....great progress, cant wait to see it with AUSCAM I cant remember seeing a post of how you did the tyres? are they printed? GMK 1 Link to comment Share on other sites More sharing options...
GMK Posted February 13, 2021 Author Share Posted February 13, 2021 17 minutes ago, Robthepom said: wow i have not logged on for few months.....great progress, cant wait to see it with AUSCAM I cant remember seeing a post of how you did the tyres? are they printed? G’day Rob, thanks for commenting. I’m looking forward to painting, that’s for sure. Lucky I’ve got good references. This is less a scratch build & more a “build your own kit”. I’ve cheated with the tyres & stole them from the Trumpeter M-ATV kit. Lucky they’re the same as what the PMV uses Uncarina 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 13, 2021 Share Posted February 13, 2021 Good show. What did you use as your non-skid? Thank you. Sincerely, Mark Link to comment Share on other sites More sharing options...
GMK Posted February 14, 2021 Author Share Posted February 14, 2021 On 2/13/2021 at 8:10 PM, dodgem37 said: Good show. What did you use as your non-skid? Thank you. Sincerely, Mark Thanks Mark. I used Tamiya textured sand paint for the non-skid coating. Some more progress, looking more & more like a Bushmaster. Uncarina 1 Link to comment Share on other sites More sharing options...
Robthepom Posted February 15, 2021 Share Posted February 15, 2021 (edited) On 2/13/2021 at 5:59 PM, GMK said: G’day Rob, thanks for commenting. I’m looking forward to painting, that’s for sure. Lucky I’ve got good references. This is less a scratch build & more a “build your own kit”. I’ve cheated with the tyres & stole them from the Trumpeter M-ATV kit. Lucky they’re the same as what the PMV uses AHHH nice work with the wheels I'm guessing thats an 'official' camo layout document Its funny when I painted my 1/35 Bushmaster I used the Showcase Models instuctions for the paint scheme, which some very unkind, sad soul ripped to pieces on another forum , I didnt care because it was close enough for me Edited February 15, 2021 by Robthepom GMK 1 Link to comment Share on other sites More sharing options...
GMK Posted February 15, 2021 Author Share Posted February 15, 2021 1 hour ago, Robthepom said: AHHH nice work with the wheels I'm guessing thats an 'official' camo layout document Its funny when I painted my 1/35 Bushmaster I used the Showcase Models instuctions for the paint scheme, which some very unkind, sad soul ripped to pieces on another forum , I didnt care because it was close enough for me Looks official enough to me! Seems to match the layout on the 1:1 truck. My name is on the instructions for that kit. It was a good first effort for a new model kit company. Sadly, the owner died a few years ago before the LRPV was released. Link to comment Share on other sites More sharing options...
Robthepom Posted February 16, 2021 Share Posted February 16, 2021 21 hours ago, GMK said: Looks official enough to me! Seems to match the layout on the 1:1 truck. My name is on the instructions for that kit. It was a good first effort for a new model kit company. Sadly, the owner died a few years ago before the LRPV was released. I thought it was actually a lot better than a 'good first effort', its cracking kit to build, plus i have a real soft spot for the bushie after being involved in the fabrication of the bullet proof windows, i have 2 more in my stash GMK 1 Link to comment Share on other sites More sharing options...
