thierry laurent Posted July 5, 2020 Author Share Posted July 5, 2020 And now we will have a look at the additional components. This TM view is showing the ducts that were added to heat the machine guns. The initial Mk.Is had problems of gun freeze and an ad hoc solution had to be found quickly as this was not really a mundane issue in dogfight! Later the system was hidden in the wings and the wing structure was modified to avoid that problem. However, this must be added on Spitfires from the late Mk.I to the Mk.II and if my memory's right some Mk.V. For a mysterious reason, kit manufacturers are systematically omitting that system in spite of the fact it is quite bulky! The duct and the fixing collar parts were made with my punch and die or were are made from corners of HK B-17 engine sprues! I would have preferred sprues with acute corners. However, as I'm only having large scale kits at home, I do not have a lot of thin sprues! To be 100% accurate, the angle should be more acute but with the flap, this will not be visible as you have to be under or above them to see it. Here you can see them glued in the radiator. And here you can see this is quite visible: Then, I added the longer duct supporting arm with a leftover Eduard part: Pete Roberts, Starfighter, Landrotten Highlander and 5 others 8 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 5, 2020 Author Share Posted July 5, 2020 Then, I went back to the rear flap. First, I thinned the rear edges before making a round notch with a file in the port side. The notch is actually corresponding to the heating duct they added. Then, I added a reinforcing strip and two strengthening arms linking the main sheet and the sides. The last item to add was the actuating arm. It is required to dry fit a lot of times to be sure all the parts will join correctly when the final radiator assembly will be done after painting. You can see here the actuating part of the arm glued on the wall: Here's an assembly attempt intended to ensure everything will be correctly aligned: And this one is showing the arm with its actuating part: I did not really detail the actuating part of the flap arm as this will be close to totally invisible. The rear end is now finished up to the final assembly of that section. A row of screw heads is very visible close to the end of the ramp but there is no way to add it now without damaging it later. Kais, Starfighter, Gazzas and 7 others 10 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 5, 2020 Author Share Posted July 5, 2020 And to end that area, we will now add the tube visible in front of the front face of the radiator: This is just a small section of bent plastic rod added on a short length of Slater plastic strip. Again, a row of screw heads should be visible (close the the front edge of the ramp). However, for the same reason, I will only add them later. I will now look at the oil cooling system. Fortunately, this will be far easier to recreate! Dpgsbody55, Starfighter, Kais and 9 others 12 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 5, 2020 Author Share Posted July 5, 2020 The pictures are quite useful as the parts are so much enlarged I can better see some small areas deserving a better clean-up! Link to comment Share on other sites More sharing options...
crobinsonh Posted July 5, 2020 Share Posted July 5, 2020 Superb work - this one is going to be a classic thierry laurent 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted July 6, 2020 Share Posted July 6, 2020 Very interesting work on the radiator. I had no knowledge of all that piping! Alain thierry laurent 1 Link to comment Share on other sites More sharing options...
RBrown Posted July 6, 2020 Share Posted July 6, 2020 Brilliant...absolutely brilliant! thierry laurent 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 7, 2020 Author Share Posted July 7, 2020 Hi folks. Correcting the oil cooling system looks to be quite simple, so I'm considering the next step: the outlets at the end of each wing heating system. I found pictures of the covers but none of what should be under such covers. As one is noticeably larger than the other one, I doubt there is simply one basic round hole in each wing. I'm rather thinking about a slot but who knows? Without looking at a preserved full scale plane equiped with such a system, it is quite difficult to know for sure! Gazzas 1 Link to comment Share on other sites More sharing options...
Greif8 Posted July 7, 2020 Share Posted July 7, 2020 Wow, simply awesome work Thierry! Ernest thierry laurent 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 8, 2020 Author Share Posted July 8, 2020 Now, we will have a look at the oil cooler. With regard to that area, the kit is quite simple: you just have front and rear holes! Nothing more. So, it was required to build it completely. Fortunately, the actual system was simple and globally made of a cylinder with a front and a rear mesh. The oil was circulating in a duct going through the cylinder and was cooled by the air going through the meshes. Note the full scale cylinder had actually an oval cross-section but the difference is not really visible and just to prove it all photoetched sets are giving round mesh parts! I was fortunate enough to have such meshes amongst my leftover Eduard photoetched parts. However, as this is too often the case, Eduard is proposing in their instructions to glue paper thin fragile parts without anything to support them! Useless to say if you dare doing that the probability to get a mess is extremely high! For some reason probably linked to kit plastic thickness-based limitations, the rear mesh is smaller than the front one. Fortunately, this is not a problem as you can always see only one of the two! With regard to the support, finding the best solution asked for some head-scratching exercice but finally I went back to the shape of the full-scale part while complying with the round shape of the meshes: a cylinder! And as both meshes had different diameters, I looked after two cylinders with corresponding diameters. I was quite lucky as I found two Evergreen ones and the smaller could even slide in the larger one! This picture shows the parts in the wing. As often, it is required to sand a little bit the walls as well as the leading and trailing edges to get something that is more in line with metal sheet thickness. Another problem is solved! dodgem37, Greif8, Starfighter and 6 others 9 Link to comment Share on other sites More sharing options...
Gazzas Posted July 8, 2020 Share Posted July 8, 2020 I'm quite impressed by the level of extra detail being put into the wings! I didn't even know the spitfires guns were warmed. thierry laurent 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 8, 2020 Author Share Posted July 8, 2020 A bad boy would say this was actually normal considering the British weather... Scotsman 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted July 8, 2020 Share Posted July 8, 2020 Great show, Thierry. Sincerely, Mark thierry laurent 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted July 8, 2020 Share Posted July 8, 2020 Wow. Lovely build going on here. thierry laurent 1 Link to comment Share on other sites More sharing options...
Greif8 Posted July 9, 2020 Share Posted July 9, 2020 If only all scratch building dilemmas were as simple and straight forward as the oil cooler I would do more of it! <grin> Continued outstanding work Thierry! Ernest thierry laurent 1 Link to comment Share on other sites More sharing options...
